    Issues with print quality, wall surface rough.
    138
    14.9k
      Can you try a vase mode print?
      CorvoDewittV2undefined 2 Replies Last reply Reply Quote 0
      • CorvoDewittV2undefined
        CorvoDewittV2 @Phaedrux
        @Phaedrux Yep! give me 15 min.
        • mwolterundefined
          mwolter
          Here's what leads me to believe the part cooling ducting can be improved. This is from his earlier video. Working on new ducts now.
          CorvoDewittV2undefined 1 Reply Last reply Reply Quote 1
            CorvoDewittV2 @mwolter
            @mwolter You are amazing thank you!!!!!!
              @Phaedrux Not a good look. 75% fan, 200C 30mm/s 90%flow
              Corexyundefined 1 Reply Last reply Reply Quote 0
                Have you done any prints larger than tiny cubes? The heat from the bed and hot nozzle can have a big effect. Try a scaling that up to a 100x100 cube with 10% infill.
                  @Phaedrux how many walls? Can I still do 20mm high?
                    @Phaedrux Also slow still? or can I speed things back up a bit?
                    • SAtechundefined
                      SAtech
                      I have seen this before on my old and new printers. I believe what I did was calibrate the XY esteps to VERY high precision, like 0.02 mm precise. I did this with digital calipers, directly measuring the movement traveled and averaging it over 5 trials. You say you have a dial indicator, that would be very helpful. Also, improved part cooling helped as well.
                      I'm pretty sure that fixed the issue, but it was a while ago, and I could be remembering wrong.
                      CorvoDewittV2undefined 1 Reply Last reply Reply Quote 0
                        CorvoDewittV2 @SAtech
                        @SAtech If the esteps are a little bit off, why cant that be compensated for with the extrusion multiplier?
                        SAtechundefined 1 Reply Last reply Reply Quote 0
                        • SAtechundefined
                          SAtech @CorvoDewittV2
                          @CorvoDewittV2
                          I'm talking about the X and Y esteps, as yes, extruder esteps can be compensated with exctrusion multiplier.
                          My theory is that very slight deviations in the X and Y axes can stack up, creating slight and varying position offsets. That's just my thinking, so correct me if I'm wrong.
                            @SAtech I'm not sure, I have always heard that messing with xy esteps isn't a good idea, but I don't know for sure.
                            • mwolterundefined
                              mwolter
                              Here's a quick mockup using a duct from a previous project. Obviously the mount will need to be changed to work with your hotend but would something like this work? The fan tilts outward a little, wanted to make sure this won't interfere with the frame or anything else close by.
                                @mwolter yeah that should be perfect! You can mount it however, or just make it part of the front piece. Oh I'm so excited you are awesome!
                                  Phaedrux Moderator @CorvoDewittV2
                                  @CorvoDewittV2 said in Issues with print quality, wall surface rough.:
                                  Yeah it's generally not a good idea, especially for corexy. Use the calculated steps and then see if there is some geometric inaccuracy after everything else is tuned. If the Corexy is properly designed and well built it shouldn't be an issue. I'd be surprised if that was a problem with the ratrig kit.
                                    I'd do full height. Something large that's more representative of an actual object you'd print. I'd also try a vase close to the max of your height to see if the extrusion pattern stays the same.
                                    • Corexyundefined
                                      Corexy
                                      @Phaedrux
                                      Vase mode is a good idea, I should have thought of that....I rarely print vases lol.
                                      @CorvoDewittV2
                                      Did you try those 3 steps for getting it into the ballpark?
                                      I agree that messing with the XY steps shouldn't be necessary, and really should be avoided IMHO.
                                      My extra parts for my v-core were sitting on the table when I got home. I really need to make a start now, out of excuses.
                                      @mwolter
                                      Yes those fans are too high when you look at them from that angle.
                                      That's a nice looking duct! May I enlist some of your skills when I've got my BMG/Mosquito in place on my v-core?
                                      • Corexyundefined
                                        Corexy @CorvoDewittV2
                                        Geez that's awful.
                                        It still looks like over extrusion, but combined with a Z binding issue...you can see the regular intervals up the walls that suggest a Z screw wobble.
                                        But it's not just that, there's a slicer/config setting issue of some sort going on there.
                                        Once you've done those 3 steps, you could try just a large tall cylinder in vase mode with zero infill and single wall thickness, something like 100 diameter by the full 300 tall.
                                        That would be worth a look.
                                        • DIY-O-Sphereundefined
                                          DIY-O-Sphere
                                          @CorvoDewittV2
                                          Can you please provide information for the thermistors you are using?
                                          Your config is set up for the generic ones, which is uncommon.
                                          (UTC+1)
                                          Corexyundefined 1 Reply Last reply Reply Quote 1
                                          • Corexyundefined
                                            Corexy @DIY-O-Sphere
                                            @DIY-O-Sphere said in Issues with print quality, wall surface rough.:
                                            @CorvoDewittV2
                                            Can you please provide information for the termistors you are using?
                                            There we go...
                                            That could very well explain why it looks like it's been printed at way too hot a temperature.
