    Bltouch setup need help
    Firmware installation
    3.8k
    • Elvis0zundefined
      Elvis0z
      M401
      M402
      Both these commands work
      • JoergS5undefined
        JoergS5 @Elvis0z
        @Elvis0z did it have a bit of distance to the bed? There are some documentation to the installation. The Z height in reference to the nozzle is important.
        The image right lower on page 1 in the https://locxess.de/3d/BLTouch_Anleitung_englisch.pdf
        document, the 8mm.
        • Elvis0zundefined
          Elvis0z
          Yep it probes way above the bed.
          • JoergS5undefined
            JoergS5 @Elvis0z
            @Elvis0z can you please republish config and homeall like it is now, so I can recheck?
            • Elvis0zundefined
              Elvis0z
              ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 09 2020 17:58:51 GMT-0700 (Mountain Standard Time)
              M550 P"Elvis Oz Tevo Black Widow" ; set printer name
              ;M551 P"" ; set password
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S1 ; enable FTP
              M586 P2 S0 ; disable Telnet
              M569 P1 S0 ; physical drive 1 goes forwards
              M569 P3 S0 ; physical drive 3 goes forwards
              M92 X80.00 Y80.00 Z1600.00 E400.00 ; set steps per mm
              M566 X500.00 Y500.00 Z18.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
              M201 X1000.00 Y1000.00 Z100.00 E1000.00 ; set accelerations (mm/s^2)
              M906 X1300 Y1300 Z1200 E1300 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X360 Y230 Z280 S0 ; set axis maxima
              M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
              M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
              ; Elvis, The following Z-Probe below is where you will have to configure your BLTouch
              M558 P9 C"^zprobe.in" H5 F60 T6000 A10 R0.5
              M950 S0 C"exp.heater3"
              G31 P25 X+41 Y+10 Z0.0 ; set Z probe trigger value, offset and trigger height
              M557 X25:360 Y15:220 S20 ; define mesh bed level
              M307 H0 A346.2 C140 D5.3 B0 S2.0 V23.8 ; enable bang-bang mode for the bed heater and set PWM limit
              ;M307 H0 B1 S1.00 ; Previous Command
              M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermistor on pin e0temp
              M307 H3 A-1 C-1 D-1 ; Disable the 3rd Heater to free up PWM channel
              M106 P0 S0.5 H1 T45 ; Elvis, The S0.5 is setup for a 12V Fan, set fan 0 value. Thermostatic control is turned off
              M106 P1 S0.20 H-1 ; Elvis, The 0.20 is setup for a 5V Fan, set fan 1 value. Thermostatic control is turned on
              G10 P0 X0 Y0 Z0.0 ; set tool 0 axis offsets
              M575 P1 S1 B115200 ; Elvis, Go into the setup of your PanalDue and set the baud rate to 115200, enable support for PanelDue
              ; homeall.g
              ; called to home all axes
              ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 09 2020 17:58:52 GMT-0700 (Mountain Standard Time)
              G91 ; relative positioning
              G1 H1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
              G1 H2 X5 Y5 F6000 ; go back a few mm
              G1 H1 X-235 Y-215 F360 ; move slowly to X and Y axis endstops once more (second pass)
              G90 ; absolute positioning
              G1 X100 Y100 F6000 ; go to first bed probe point and home Z
              G30 ;home Z by probing the bed
              • JoergS5undefined
                JoergS5 @Elvis0z
                @Elvis0z to be sure: your BLtouch is right and behind the nozzle?
                • Elvis0zundefined
                  Elvis0z
                  Yep right and behind
                  • JoergS5undefined
                    JoergS5 @Elvis0z
                    @Elvis0z are you sure G31 Z is 0? This would mean the BLtouch triggers when the nozzle touches the bed.
                    Please recheck steps 5-7 in https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height . You could trial and error some values for Z also... (Z positive) - I would do that 😉
                    I don't see other problems, I would only remove the + signs from
                    they will probably be interpreted correctly, but I didn't see + signs in the examples, so to be sure, I would remove them.
                    • Elvis0zundefined
                      Elvis0z
                      I cant go down on the z
                      As it won't home z
                      Should I just manually move the hotend to the bed
                      JoergS5undefined 2 Replies Last reply Reply Quote 0
                      • JoergS5undefined
                        JoergS5 @Elvis0z
                        @Elvis0z you can of course move Z carefully down with the small G1 Z movements (+Z0.1 etc) until you have the famous one-sheet-paper-distance, then say G92 Z0 to set 0 position. But this is no general solution. There must be a reason why it is not working as expected.
                        Maybe someone other has an idea what's wrong.
                        • JoergS5undefined
                          JoergS5 @Elvis0z
                          @Elvis0z @Phaedrux is here to the rescue! (I hope)
                            Phaedrux Moderator @Elvis0z
                            @Elvis0z said in Bltouch setup need help:
                            Error: Z probe was not triggered during probing move
                            Error: Homing failed
                            Double check your white wire.
                            You can try removing the ^ in front of zprobe.in
                            • Elvis0zundefined
                              Elvis0z
                              Thanks heaps hey. I'm futher ahead than I have been. At least its moving and the probe works with M401 and 2. That did not work befor
                                Hey guys need help to set this up its a v1.0 bltouch.
                                Is this a version with the trace to cut or does it come with the resistor? It's been a long time since I've seen anyone with a V1, so I'm wondering if it matters in this case. If it's a new Duet 1.04 it can't be hurt by 5v, but perhaps there is something in the BLtouch that will not trigger. If removing the ^ and checking your white wire is fruitless, maybe look into the trace/resistor
                                • Elvis0zundefined
                                  Elvis0z
                                  No I replaced it with a v3.1 that I had
                                  • Elvis0zundefined
                                    Elvis0z
                                    If I send command M401 and M402 it triggers
                                      You mean it deploys and retracts?
                                      When you send G30 does the pin deploy?
                                      Elvis0zundefined 1 Reply Last reply Reply Quote 0
                                      • Elvis0zundefined
                                        Elvis0z
                                        I get this error when sending G30
                                        G30
                                        Error: G30: Insufficient axes homed for bed probing
                                        • Elvis0zundefined
                                          Elvis0z @Phaedrux
                                          @Phaedrux
                                          Yep deploys and retracts that is for the M401 M402 commands
                                            Ok home X and Y first, move the print head to the center and then send G30. Does the pin deploy? Does the Z axis move? If you touch the pin does the Z axis stop?
