Bltouch setup need help
@Elvis0z said in Bltouch setup need help:
Error: Z probe was not triggered during probing move
Error: Homing failedDouble check your white wire.
M558 P9 C"^zprobe.in" H5 F60 T6000 A10 R0.5
You can try removing the^
in front of zprobe.in -
Thanks heaps hey. I'm futher ahead than I have been. At least its moving and the probe works with M401 and 2. That did not work befor
Hey guys need help to set this up its a v1.0 bltouch.
Is this a version with the trace to cut or does it come with the resistor? It's been a long time since I've seen anyone with a V1, so I'm wondering if it matters in this case. If it's a new Duet 1.04 it can't be hurt by 5v, but perhaps there is something in the BLtouch that will not trigger. If removing the ^ and checking your white wire is fruitless, maybe look into the trace/resistor
No I replaced it with a v3.1 that I had
If I send command M401 and M402 it triggers
You mean it deploys and retracts?
When you send G30 does the pin deploy?
I get this error when sending G30
G30
Error: G30: Insufficient axes homed for bed probing
Yep deploys and retracts that is for the M401 M402 commands
Ok home X and Y first, move the print head to the center and then send G30. Does the pin deploy? Does the Z axis move? If you touch the pin does the Z axis stop?
Yep deployed and red light went out and got the error
@Elvis0z please remove
M307 H3 A-1 C-1 D-1
this not valid in RRF3 any more.Edit: this is the source: https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M307
@JoergS5
Yep removed -
Just to make sure, the files you are editing are in the /sys folder, right?
Yep
Can you upload the actual files to your post? config.g homeall.g homex.g homey.g homez.g deployprobe.g retractprobe.g
And maybe a photo of your wiring?
Not sure what you mean "Actual files" or how to do it not copy paste?
In the /sys folder select the files and then right click and download. Then drag the files onto the post text box in the forum to upload.
Thank you for all the help. I have to go out for a while will be back
Cheers
