Bltouch setup need help
@Elvis0z can you please republish config and homeall like it is now, so I can recheck?
; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 09 2020 17:58:51 GMT-0700 (Mountain Standard Time); General preferences
M550 P"Elvis Oz Tevo Black Widow" ; set printer name; Network
;M551 P"" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M569 P1 S0 ; physical drive 1 goes forwards
M569 P3 S0 ; physical drive 3 goes forwards
M92 X80.00 Y80.00 Z1600.00 E400.00 ; set steps per mm
M566 X500.00 Y500.00 Z18.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z100.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1300 Y1300 Z1200 E1300 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X360 Y230 Z280 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Elvis, The following Z-Probe below is where you will have to configure your BLTouch
M558 P9 C"^zprobe.in" H5 F60 T6000 A10 R0.5
M950 S0 C"exp.heater3"
G31 P25 X+41 Y+10 Z0.0 ; set Z probe trigger value, offset and trigger height
M557 X25:360 Y15:220 S20 ; define mesh bed level; Heaters
M307 H0 A346.2 C140 D5.3 B0 S2.0 V23.8 ; enable bang-bang mode for the bed heater and set PWM limit
;M307 H0 B1 S1.00 ; Previous Command
M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermistor on pin e0temp
M307 H3 A-1 C-1 D-1 ; Disable the 3rd Heater to free up PWM channel
M106 P0 S0.5 H1 T45 ; Elvis, The S0.5 is setup for a 12V Fan, set fan 0 value. Thermostatic control is turned off
M106 P1 S0.20 H-1 ; Elvis, The 0.20 is setup for a 5V Fan, set fan 1 value. Thermostatic control is turned on; Tools
G10 P0 X0 Y0 Z0.0 ; set tool 0 axis offsets
M575 P1 S1 B115200 ; Elvis, Go into the setup of your PanalDue and set the baud rate to 115200, enable support for PanelDue
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 09 2020 17:58:52 GMT-0700 (Mountain Standard Time)
G91 ; relative positioning
G1 H1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-235 Y-215 F360 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X100 Y100 F6000 ; go to first bed probe point and home Z
G30 ;home Z by probing the bed -
@Elvis0z to be sure: your BLtouch is right and behind the nozzle?
Yep right and behind
@Elvis0z are you sure G31 Z is 0? This would mean the BLtouch triggers when the nozzle touches the bed.
Please recheck steps 5-7 in https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height . You could trial and error some values for Z also... (Z positive) - I would do thatI don't see other problems, I would only remove the + signs from
they will probably be interpreted correctly, but I didn't see + signs in the examples, so to be sure, I would remove them. -
I cant go down on the z
As it won't home z
Should I just manually move the hotend to the bed -
@Elvis0z you can of course move Z carefully down with the small G1 Z movements (+Z0.1 etc) until you have the famous one-sheet-paper-distance, then say G92 Z0 to set 0 position. But this is no general solution. There must be a reason why it is not working as expected.
Maybe someone other has an idea what's wrong. -
@Elvis0z said in Bltouch setup need help:
Error: Z probe was not triggered during probing move
Error: Homing failedDouble check your white wire.
You can try removing the^
in front of zprobe.in -
Thanks heaps hey. I'm futher ahead than I have been. At least its moving and the probe works with M401 and 2. That did not work befor
Hey guys need help to set this up its a v1.0 bltouch.
Is this a version with the trace to cut or does it come with the resistor? It's been a long time since I've seen anyone with a V1, so I'm wondering if it matters in this case. If it's a new Duet 1.04 it can't be hurt by 5v, but perhaps there is something in the BLtouch that will not trigger. If removing the ^ and checking your white wire is fruitless, maybe look into the trace/resistor
No I replaced it with a v3.1 that I had
If I send command M401 and M402 it triggers
You mean it deploys and retracts?
When you send G30 does the pin deploy?
I get this error when sending G30
G30
Error: G30: Insufficient axes homed for bed probing
Yep deploys and retracts that is for the M401 M402 commands
Ok home X and Y first, move the print head to the center and then send G30. Does the pin deploy? Does the Z axis move? If you touch the pin does the Z axis stop?
Yep deployed and red light went out and got the error
@Elvis0z please remove
M307 H3 A-1 C-1 D-1
this not valid in RRF3 any more.Edit: this is the source: https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M307
@JoergS5
Yep removed
