    Bltouch setup need help
    Firmware installation
    3.9k
    • Elvis0zundefined
      Elvis0z
      M98 P"config.g"
      HTTP is enabled on port 80
      FTP is enabled on port 21
      TELNET is disabled
      Error: bad model parameters
      • Elvis0zundefined
        Elvis0z @JoergS5
        @JoergS5 CRLF not sure what that is
        A Former User? JoergS5undefined 2 Replies Last reply Reply Quote 0
          A Former User @Elvis0z
          @Elvis0z carriage return and line feed. In other words press enter.
          • JoergS5undefined
            JoergS5 @Elvis0z
            @Elvis0z please try
            G31 P25 X41.0 Y10.0 Z0.0
            instead of
            G31 P25 X+41 Y+10 Z0.0
            and run M98 P"config.g" again whether the bad model parameters is still there.
            • Elvis0zundefined
              Elvis0z
              TELNET is disabled
              • JoergS5undefined
                JoergS5 @Elvis0z
                @Elvis0z ok, somewhere is a syntax error in the config.g, but I cannot see it.
                • Elvis0zundefined
                  Elvis0z
                  @JoergS5 said in Bltouch setup need help:
                  Should I have P9 or P25
                  • JoergS5undefined
                    JoergS5 @Elvis0z
                    @Elvis0z for BLTouch in most cases the value is P25. P9 was the parameter for M558. G31 P25 means sensitivity.
                    • Elvis0zundefined
                      Elvis0z
                      Think that I have P9 for the bltouch
                      • Elvis0zundefined
                        Elvis0z
                        ahhhh ok don't understand gcode that well at all
                        • JoergS5undefined
                          JoergS5 @Elvis0z
                          @Elvis0z you will get used to it, it is not so complicated. One G-Code one line, the explanation is in https://duet3d.dozuki.com/Wiki/Gcode#main
                          It's only a bit complicated with the change from RRF2 to RRF3, because several G-Codes changed with the parameter meanings. Some were deprecated, some added.
                          • JoergS5undefined
                            JoergS5 @Elvis0z
                            @Elvis0z I know only one method to find the reason of the error: throw out parts of the config, test M98 again, throw out next until you find the reason. Throw out will be possible only for the parts which are not essential, like the heaters, fans, tools, miscellaneous. Then Z-Probe, Axis Limits. Please make a backup first!
                            • Elvis0zundefined
                              Elvis0z
                              Will have a go
                              • JoergS5undefined
                                JoergS5 @Elvis0z
                                @Elvis0z I forgot: the forum here is the backup.
                                • Elvis0zundefined
                                  Elvis0z
                                  Can I post a video here of what it is doing?
                                  • JoergS5undefined
                                    JoergS5 @Elvis0z
                                    @Elvis0z most people make a youtube video and post the link here. Don't know whether you can post video directly, I suspect not.
                                    • Elvis0zundefined
                                      Elvis0z
                                      Ok I will try That
                                      • Elvis0zundefined
                                        Elvis0z
                                        https://youtu.be/Y6CVXsrzRvk
                                        Here is the video of what is happening
                                        • JoergS5undefined
                                          JoergS5 @Elvis0z
                                          @Elvis0z maybe its the
                                          M203 X6000.00 Y6000.00 Z180.00 E6000.00
                                          setting, because Z moves with maximum 3 mm/second, which will take forever at this distance on the video. Please set higher and try again.
                                          PS the video was very helpful, this was a good idea!!
                                          • Elvis0zundefined
                                            Elvis0z
                                            should I put the same as x and y?
