Bltouch setup need help
Can you upload the actual files to your post? config.g homeall.g homex.g homey.g homez.g deployprobe.g retractprobe.g
And maybe a photo of your wiring?
Not sure what you mean "Actual files" or how to do it not copy paste?
In the /sys folder select the files and then right click and download. Then drag the files onto the post text box in the forum to upload.
Thank you for all the help. I have to go out for a while will be back
Cheers -
Can you send M98 P"config.g" in the gcode console and report the results?
@Phaedrux yep will do soon as I'm back home
I am not sure whether it's a problem that retractprobe.g doesn't have a CRLF at the last line.
M98 P"config.g"
HTTP is enabled on port 80
FTP is enabled on port 21
TELNET is disabled
Error: bad model parameters -
@JoergS5 CRLF not sure what that is
@Elvis0z carriage return and line feed. In other words press enter.
@Elvis0z please try
G31 P25 X41.0 Y10.0 Z0.0
instead of
G31 P25 X+41 Y+10 Z0.0
and run M98 P"config.g" again whether the bad model parameters is still there. -
TELNET is disabled
@Elvis0z ok, somewhere is a syntax error in the config.g, but I cannot see it.
@Elvis0z for BLTouch in most cases the value is P25. P9 was the parameter for M558. G31 P25 means sensitivity.
Think that I have P9 for the bltouch
ahhhh ok don't understand gcode that well at all
@Elvis0z you will get used to it, it is not so complicated. One G-Code one line, the explanation is in https://duet3d.dozuki.com/Wiki/Gcode#main
It's only a bit complicated with the change from RRF2 to RRF3, because several G-Codes changed with the parameter meanings. Some were deprecated, some added.
@Elvis0z I know only one method to find the reason of the error: throw out parts of the config, test M98 again, throw out next until you find the reason. Throw out will be possible only for the parts which are not essential, like the heaters, fans, tools, miscellaneous. Then Z-Probe, Axis Limits. Please make a backup first!
