    Bltouch setup need help
    Firmware installation
    4.1k
      In the /sys folder select the files and then right click and download. Then drag the files onto the post text box in the forum to upload.
      • Elvis0zundefined
        Elvis0z
        config.g
        deployprobe.g
        homeall.g
        homex.g
        homey.g
        homez.g
        retractprobe.g
        • Elvis0zundefined
          Elvis0z
          Thank you for all the help. I have to go out for a while will be back
          Cheers
            Can you send M98 P"config.g" in the gcode console and report the results?
            Elvis0zundefined 1 Reply Last reply Reply Quote 0
            • Elvis0zundefined
              Elvis0z @Phaedrux
              @Phaedrux yep will do soon as I'm back home
              • JoergS5undefined
                JoergS5
                I am not sure whether it's a problem that retractprobe.g doesn't have a CRLF at the last line.
                • Elvis0zundefined
                  Elvis0z
                  M98 P"config.g"
                  HTTP is enabled on port 80
                  FTP is enabled on port 21
                  TELNET is disabled
                  Error: bad model parameters
                  • Elvis0zundefined
                    Elvis0z @JoergS5
                    @JoergS5 CRLF not sure what that is
                    A Former User? JoergS5undefined 2 Replies Last reply Reply Quote 0
                      A Former User @Elvis0z
                      @Elvis0z carriage return and line feed. In other words press enter.
                      • JoergS5undefined
                        JoergS5 @Elvis0z
                        @Elvis0z please try
                        G31 P25 X41.0 Y10.0 Z0.0
                        instead of
                        G31 P25 X+41 Y+10 Z0.0
                        and run M98 P"config.g" again whether the bad model parameters is still there.
                        • Elvis0zundefined
                          Elvis0z
                          TELNET is disabled
                          • JoergS5undefined
                            JoergS5 @Elvis0z
                            @Elvis0z ok, somewhere is a syntax error in the config.g, but I cannot see it.
                            • Elvis0zundefined
                              Elvis0z
                              @JoergS5 said in Bltouch setup need help:
                              Should I have P9 or P25
                              • JoergS5undefined
                                JoergS5 @Elvis0z
                                @Elvis0z for BLTouch in most cases the value is P25. P9 was the parameter for M558. G31 P25 means sensitivity.
                                • Elvis0zundefined
                                  Elvis0z
                                  Think that I have P9 for the bltouch
                                  • Elvis0zundefined
                                    Elvis0z
                                    ahhhh ok don't understand gcode that well at all
                                    • JoergS5undefined
                                      JoergS5 @Elvis0z
                                      @Elvis0z you will get used to it, it is not so complicated. One G-Code one line, the explanation is in https://duet3d.dozuki.com/Wiki/Gcode#main
                                      It's only a bit complicated with the change from RRF2 to RRF3, because several G-Codes changed with the parameter meanings. Some were deprecated, some added.
                                      • JoergS5undefined
                                        JoergS5 @Elvis0z
                                        @Elvis0z I know only one method to find the reason of the error: throw out parts of the config, test M98 again, throw out next until you find the reason. Throw out will be possible only for the parts which are not essential, like the heaters, fans, tools, miscellaneous. Then Z-Probe, Axis Limits. Please make a backup first!
                                        • Elvis0zundefined
                                          Elvis0z
                                          Will have a go
                                          • JoergS5undefined
                                            JoergS5 @Elvis0z
                                            @Elvis0z I forgot: the forum here is the backup.
