    Bltouch setup need help
    Firmware installation
    3.8k
    • Elvis0zundefined
      Elvis0z
      Think that I have P9 for the bltouch
      • Elvis0zundefined
        Elvis0z
        ahhhh ok don't understand gcode that well at all
        JoergS5undefined 2 Replies Last reply Reply Quote 0
        • JoergS5undefined
          JoergS5 @Elvis0z
          @Elvis0z you will get used to it, it is not so complicated. One G-Code one line, the explanation is in https://duet3d.dozuki.com/Wiki/Gcode#main
          It's only a bit complicated with the change from RRF2 to RRF3, because several G-Codes changed with the parameter meanings. Some were deprecated, some added.
          • JoergS5undefined
            JoergS5 @Elvis0z
            @Elvis0z I know only one method to find the reason of the error: throw out parts of the config, test M98 again, throw out next until you find the reason. Throw out will be possible only for the parts which are not essential, like the heaters, fans, tools, miscellaneous. Then Z-Probe, Axis Limits. Please make a backup first!
            • Elvis0zundefined
              Elvis0z
              Will have a go
              • JoergS5undefined
                JoergS5 @Elvis0z
                @Elvis0z I forgot: the forum here is the backup.
                • Elvis0zundefined
                  Elvis0z
                  Can I post a video here of what it is doing?
                  • JoergS5undefined
                    JoergS5 @Elvis0z
                    @Elvis0z most people make a youtube video and post the link here. Don't know whether you can post video directly, I suspect not.
                    • Elvis0zundefined
                      Elvis0z
                      Ok I will try That
                      • Elvis0zundefined
                        Elvis0z
                        https://youtu.be/Y6CVXsrzRvk
                        Here is the video of what is happening
                        • JoergS5undefined
                          JoergS5 @Elvis0z
                          @Elvis0z maybe its the
                          M203 X6000.00 Y6000.00 Z180.00 E6000.00
                          setting, because Z moves with maximum 3 mm/second, which will take forever at this distance on the video. Please set higher and try again.
                          PS the video was very helpful, this was a good idea!!
                          • Elvis0zundefined
                            Elvis0z
                            should I put the same as x and y?
                            • JoergS5undefined
                              JoergS5 @Elvis0z
                              @Elvis0z you have trapezoid at Z, the stepper turns 5 rotations per second, your trapezoid has 2 mm for every rotation, so 10 mm/s, the value for Z should be 600 mm/min. The stepper could run 16 rotations/s maximum, but better be on the safe side.
                              • Elvis0zundefined
                                Elvis0z
                                Thanks for your help.
                                • Elvis0zundefined
                                  Elvis0z
                                  So just to make sure I have to home z before I can do anything else?
                                  • Elvis0zundefined
                                    Elvis0z
                                    Ahhhhh gets to the same point and deploys probe then nothing like in the video
                                    • JoergS5undefined
                                      JoergS5 @Elvis0z
                                      @Elvis0z please see above, take 600. 6000 ist too much for the stepper.
                                      • JoergS5undefined
                                        JoergS5 @Elvis0z
                                        @Elvis0z said in Bltouch setup need help:
                                        the printer want to have homed all axes before it proceeds.
                                        • Elvis0zundefined
                                          Elvis0z
                                          G28
                                          Error: Z probe was not triggered during probing move
                                          Error: Homing failed
                                          Just keep getting this error
                                          • JoergS5undefined
                                            JoergS5 @Elvis0z
                                            @Elvis0z can you make a M122 after the G28 test please and show?
                                            An does G1 Z10 and G1 Z-10 move as expected when you run this commands directly?
