    Bltouch setup need help
    Firmware installation
    3.9k
    • Elvis0zundefined
      Elvis0z
      Will have a go
      • JoergS5undefined
        JoergS5 @Elvis0z
        @Elvis0z I forgot: the forum here is the backup.
        • Elvis0zundefined
          Elvis0z
          Can I post a video here of what it is doing?
          • JoergS5undefined
            JoergS5 @Elvis0z
            @Elvis0z most people make a youtube video and post the link here. Don't know whether you can post video directly, I suspect not.
            • Elvis0zundefined
              Elvis0z
              Ok I will try That
              • Elvis0zundefined
                Elvis0z
                https://youtu.be/Y6CVXsrzRvk
                Here is the video of what is happening
                • JoergS5undefined
                  JoergS5 @Elvis0z
                  @Elvis0z maybe its the
                  M203 X6000.00 Y6000.00 Z180.00 E6000.00
                  setting, because Z moves with maximum 3 mm/second, which will take forever at this distance on the video. Please set higher and try again.
                  PS the video was very helpful, this was a good idea!!
                  • Elvis0zundefined
                    Elvis0z
                    should I put the same as x and y?
                    • JoergS5undefined
                      JoergS5 @Elvis0z
                      @Elvis0z you have trapezoid at Z, the stepper turns 5 rotations per second, your trapezoid has 2 mm for every rotation, so 10 mm/s, the value for Z should be 600 mm/min. The stepper could run 16 rotations/s maximum, but better be on the safe side.
                      • Elvis0zundefined
                        Elvis0z
                        Thanks for your help.
                        • Elvis0zundefined
                          Elvis0z
                          So just to make sure I have to home z before I can do anything else?
                          • Elvis0zundefined
                            Elvis0z
                            Ahhhhh gets to the same point and deploys probe then nothing like in the video
                            • JoergS5undefined
                              JoergS5 @Elvis0z
                              @Elvis0z please see above, take 600. 6000 ist too much for the stepper.
                              • JoergS5undefined
                                JoergS5 @Elvis0z
                                @Elvis0z said in Bltouch setup need help:
                                the printer want to have homed all axes before it proceeds.
                                • Elvis0zundefined
                                  Elvis0z
                                  G28
                                  Error: Z probe was not triggered during probing move
                                  Error: Homing failed
                                  Just keep getting this error
                                  • JoergS5undefined
                                    JoergS5 @Elvis0z
                                    @Elvis0z can you make a M122 after the G28 test please and show?
                                    An does G1 Z10 and G1 Z-10 move as expected when you run this commands directly?
                                    • Elvis0zundefined
                                      Elvis0z
                                      @JoergS5 said in Bltouch setup need help:
                                      G1 Z-10
                                      M122
                                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                                      Board ID: 08DGM-9T6BU-FG3SD-6J9D0-3S86Q-1AMBF
                                      Used output buffers: 3 of 24 (10 max)
                                      Static ram: 27980
                                      Dynamic ram: 93712 of which 44 recycled
                                      Exception stack ram used: 264
                                      Never used ram: 9072
                                      Tasks: NETWORK(ready,384) HEAT(blocked,1224) MAIN(running,1880) IDLE(ready,80)
                                      Owned mutexes:
                                      Last reset 00:00:35 ago, cause: software
                                      Last software reset at 2020-07-09 19:59, reason: User, spinning module GCodes, available RAM 8584 bytes (slot 1)
                                      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                                      Error status: 0
                                      MCU temperature: min 30.6, current 31.7, max 32.0
                                      Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                      Date/time: 2020-07-09 19:59:45
                                      Cache data hit count 60372819
                                      Slowest loop: 4.74ms; fastest: 0.13ms
                                      === Storage ===
                                      Free file entries: 10
                                      SD card longest read time 3.1ms, write time 0.0ms, max retries 0
                                      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                                      === MainDDARing ===
                                      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                      === AuxDDARing ===
                                      Segments left: 0
                                      Movement lock held by null
                                      HTTP is idle in state(s) 0
                                      Telnet is idle in state(s) 0
                                      File is idle in state(s) 0
                                      USB is idle in state(s) 0
                                      Aux is idle in state(s) 0
                                      Trigger is idle in state(s) 0
                                      Queue is idle in state(s) 0
                                      Daemon is idle in state(s) 0
                                      Code queue is empty.
                                      === Network ===
                                      Slowest loop: 41.57ms; fastest: 0.00ms
                                      Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                                      HTTP sessions: 1 of 8
                                      • WiFi -
                                        Network state is active
                                        WiFi firmware version 1.23
                                        WiFi MAC address ec:fa:bc:2d:b3:11
                                        WiFi Vcc 3.36, reset reason Unknown
                                        WiFi flash size 4194304, free heap 20056
                                        WiFi IP address 192.168.50.68
                                        WiFi signal strength -46dBm, reconnections 0, sleep mode modem
                                      09/07/2020, 20:00:48 G1 Z10
                                      Error: G0/G1: insufficient axes homed
                                      09/07/2020, 20:01:17 G1 Z-10
                                      • Elvis0zundefined
                                        Elvis0z
                                        When I do a G28 command once z probe deploys the console just spins around and I can't put any commands in till I restart control board
                                        • JoergS5undefined
                                          JoergS5 @Elvis0z
                                          @Elvis0z first sorry for my G1 Z-10 and G1 Z10. This will not work because Z is not homed. The correct commands are G1 H2 Z-10 and H1 H2 Z10 to move even when the Z is not homed. Just to check Z can move at all at this position.
                                          I was searching what this fast white LED blinking means, but I can only find fast red blinking (which would be eg white and black cables switched).
                                          Can you please make an image of the wiring of the Duet Wifi and the cables at the 5-pin connector of the BLTouch?
                                          • Elvis0zundefined
                                            Elvis0z
                                            G1 H2 Z-10
                                            Yep moves up and down with new commands
