    Short to ground on drivers 0123
    63
    2.7k
      A Former User @Touchthebitum
      @Touchthebitum said in Short to ground on drivers 0123:
      On every drivers and without plugged motors ?
      driver 5 and 6 are okay arent they? and yes, the error will persist after unplugging the motor if you got the "correct" wrong combination.
      Touchthebitumundefined 1 Reply Last reply Reply Quote 0
      • Touchthebitumundefined
        Touchthebitum @A Former User
        @bearer said in Short to ground on drivers 0123:
        I didn't test the 5 and 6 drivers yet. I reflashed and erase everything to test again but always the same message.
        With my Duet2 wifi, it worked before
        Sparkcube XL V 1.1 300x300x190, Radds, Raspberry, Keenovo silicone bedheat 220v, Big Booster Extruder, DIY building
        BLV Cube 665mm Direct Drive with Duet3/SBC (RPi 4) Mosquito Magnum/Bond Tech Extruder/Vanadium Nozzle, Keenovo silicone bedheat 220v
          A Former User
          I think we can leave it at drivers 0-3 are damaged, and Duet people will determine the cause and potential remedy.
          (edit: 👇 shop will tell you to get Duet people to determine the cause, on this fourm)
            Ok I contacted the shop and see what we can do .
            Thanks for your help
              dc42 administrators @Touchthebitum
              I don't know whhat to do because I tried to swapped wires many times.
              Unfortunately, swapping stepper motor wires over so that they are no longer wired with one phase to each end of the connector is a recipe for blowing drivers. This is because the driver cannot control the output current when they are mis-wired in this way. Sometimes they survive, sometimes they don't - it depends on the VIN voltage and the type of motor.
                Touchthebitum @dc42
                @dc42 ok I understand but the problem was present at the first plug and I used the same working wiring than my working Duet2. And the message was telling that the driver 1 was short - ground and I had never plugged anything on the socket.
                I repeat, I swapped the wires because it didn't work with the same wiring as my Duet2.
                  Phaedrux Moderator @Touchthebitum
                  I forgot to mention that the error message is present without the motors plugged ...
                  It is the Duet3 V1.01
                  Here is a photo of the plug. I tested the phase before plugging it.
                  Tape is provisory.
                  What role does the tape play there? Is it possible the crimp was bad from the start and making a bad connection?
                  Were you getting the error before plugging anything in or only after?
                    Touchthebitum @Phaedrux
                    @Phaedrux Tape is only a protection to avoid shorts contact. Contacts were good since I made continuity tests and resistance tests and I always had signal.
                      Were there any other error messages along with the short to ground errors?
                        @Phaedrux No, M122 had not error messages. Only those ground-short messages
                          When are where was the Duet 3 purchased?
                            @Phaedrux www.3dware.ch
                              Please send M122 and post the resulting output here.
                                Touchthebitum @dc42
                                m122
                                RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                                Board ID: 08DJM-956L2-G43S8-6J9F4-3S46N-TU2QD
                                Used output buffers: 1 of 40 (10 max)
                                Static ram: 154604
                                Dynamic ram: 162592 of which 44 recycled
                                Exception stack ram used: 224
                                Never used ram: 75752
                                Tasks: NETWORK(ready,1968) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4952) IDLE(ready,76)
                                Owned mutexes:
                                Last reset 00:00:44 ago, cause: power up
                                Last software reset at 2020-07-27 15:14, reason: User, spinning module LinuxInterface, available RAM 75704 bytes (slot 0)
                                Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0443c000 BFAR 0x00000000 SP 0xffffffff Task MAIN
                                Error status: 0
                                MCU temperature: min 19.4, current 27.7, max 27.8
                                Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                                Driver 0: standstill, reads 22474, writes 14 timeouts 0, SG min/max 0/0
                                Driver 1: standstill, reads 22474, writes 14 timeouts 0, SG min/max 0/0
                                Driver 2: standstill, reads 22475, writes 14 timeouts 0, SG min/max 0/0
                                Driver 3: standstill, reads 22475, writes 14 timeouts 0, SG min/max 0/0
                                Driver 4: standstill, reads 22478, writes 11 timeouts 0, SG min/max 0/0
                                Driver 5: standstill, reads 22479, writes 11 timeouts 0, SG min/max 0/0
                                Date/time: 2020-07-27 15:15:01
                                Slowest loop: 3.63ms; fastest: 0.14ms
                                === Storage ===
                                Free file entries: 10
                                === MainDDARing ===
                                Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                === AuxDDARing ===
                                Segments left: 0
                                Movement lock held by null
                                HTTP* is ready with "M122" in state(s) 0
                                Telnet is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Queue is idle in state(s) 0
                                LCD is idle in state(s) 0
                                SBC is idle in state(s) 0
                                Daemon* is idle in state(s) 0
                                Aux2 is idle in state(s) 0
                                Code queue is empty.
                                === Network ===
                                Slowest loop: 1.02ms; fastest: 0.01ms
                                HTTP sessions: 0 of 8
                                • Ethernet -
                                  State: disabled
                                  Error counts: 0 0 0 0 0
                                  === CAN ===
                                  Messages sent 72, longest wait 0ms for type 0
                                  === Linux interface ===
                                  State: 0, failed transfers: 0
                                  Last transfer: 18ms ago
                                  RX/TX seq numbers: 583/584
                                  SPI underruns 0, overruns 0
                                  Number of disconnects: 0
                                  Buffer RX/TX: 0/0-0
                                  === Duet Control Server ===
                                  Duet Control Server v3.1.1
                                  Code buffer space: 4096
                                  Full transfers per second: 30.27
                                  Thanks. Please try commanding the motors to move (without any motors connected) and repeat that. I am looking for the driver status to change.
                                    Touchthebitum @dc42
                                    Error: short-to-ground reported by driver(s) 0 1
                                    27/07/2020 à 21:40:14 m122
                                    Static ram: 154604
                                    Exception stack ram used: 280
                                    Never used ram: 75696
                                    Tasks: NETWORK(ready,1968) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1452) TMC(blocked,68) MAIN(running,4952) IDLE(ready,76)
                                    Owned mutexes:
                                    Last reset 00:00:47 ago, cause: power up
                                    Error status: 0
                                    MCU temperature: min 20.8, current 29.0, max 29.1
                                    Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                    12V rail voltage: min 12.1, current 12.1, max 12.1, under voltage events: 0
                                    Driver 0: short-to-ground standstill, reads 39652, writes 17 timeouts 0, SG min/max 0/0
                                    Driver 1: short-to-ground standstill, reads 39652, writes 17 timeouts 0, SG min/max 0/63
                                    Driver 2: standstill, reads 39656, writes 14 timeouts 0, SG min/max 0/0
                                    Driver 3: standstill, reads 39656, writes 14 timeouts 0, SG min/max 0/0
                                    Driver 4: standstill, reads 39660, writes 11 timeouts 0, SG min/max 0/0
                                    Driver 5: standstill, reads 39660, writes 11 timeouts 0, SG min/max 0/0
                                    Date/time: 2020-07-27 20:36:50
                                    Slowest loop: 3.82ms; fastest: 0.14ms
                                    === Storage ===
                                    Hiccups: 0(0), FreeDm: 375, MinFreeDm: 373, MaxWait: 34018ms
                                    === MainDDARing ===
                                    Scheduled moves: 1, completed moves: 1, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                    === AuxDDARing ===
                                    Segments left: 0
                                    === Network ===
                                    Slowest loop: 0.88ms; fastest: 0.01ms
                                    • Ethernet -
                                      State: disabled
                                      === CAN ===
                                      Messages sent 100, longest wait 0ms for type 0
                                      Last transfer: 17ms ago
                                      RX/TX seq numbers: 808/809
                                      Buffer RX/TX: 0/0-0
                                      Full transfers per second: 3.50
                                    • percybundefined
                                      percyb
                                      I have a similar issue, getting "Warning: motor phase A may be disconnected reported by driver(s)" on all drive ports with what were working stepper motors. Only possible mistake i made is connect one stepper motor to 3 pins instead of 4 ie offset one pin. Would this cause all drivers to die?
                                      Touchthebitumundefined A Former User? 2 Replies Last reply Reply Quote 0
                                        Touchthebitum @percyb
                                        @percyb said in Short to ground on drivers 0123:
                                        Impossible because I tested all phases before plugging motor and I checked if these big crimps went on the right place when connectind them on the Duet,
                                          A Former User @percyb
                                          ref https://forum.duet3d.com/post/100507 and you should probably start your own topic if the error persist after disconnecting your motors (when powered down ofc)
                                            I think we should think about a warranty process. I don't know what to add to the discussion. I repeat, it is not the first printer I build and I'm aware of risks. Before this Duet3 I used a Duet2 and was perfect (no errors messages) with the same motors. This board never worked and I directly plugged the SAME motors that I plugged to my Duet2. So there is a problem.
                                            My shop told me to see with this forum, what I did.
                                            Now, I choosed a Genuine board because I believe in the right intelectual properties and know-how.
                                            Please, give me a clear answer and we can go on.
                                            Thanks
                                            A Former User? T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
