    Short to ground on drivers 0123
    63
    2.7k
    • Touchthebitumundefined
      Touchthebitum @A Former User
      @bearer said in Short to ground on drivers 0123:
      @Touchthebitum said in Short to ground on drivers 0123:
      On every drivers and without plugged motors ?
      driver 5 and 6 are okay arent they? and yes, the error will persist after unplugging the motor if you got the "correct" wrong combination.
      I didn't test the 5 and 6 drivers yet. I reflashed and erase everything to test again but always the same message.
      With my Duet2 wifi, it worked before
      Sparkcube XL V 1.1 300x300x190, Radds, Raspberry, Keenovo silicone bedheat 220v, Big Booster Extruder, DIY building
      BLV Cube 665mm Direct Drive with Duet3/SBC (RPi 4) Mosquito Magnum/Bond Tech Extruder/Vanadium Nozzle, Keenovo silicone bedheat 220v
        A Former User
        I think we can leave it at drivers 0-3 are damaged, and Duet people will determine the cause and potential remedy.
        (edit: 👇 shop will tell you to get Duet people to determine the cause, on this fourm)
        Touchthebitumundefined 1 Reply Last reply Reply Quote 0
          Ok I contacted the shop and see what we can do .
          Thanks for your help
            dc42 administrators @Touchthebitum
            I don't know whhat to do because I tried to swapped wires many times.
            Unfortunately, swapping stepper motor wires over so that they are no longer wired with one phase to each end of the connector is a recipe for blowing drivers. This is because the driver cannot control the output current when they are mis-wired in this way. Sometimes they survive, sometimes they don't - it depends on the VIN voltage and the type of motor.
              Touchthebitum @dc42
              @dc42 ok I understand but the problem was present at the first plug and I used the same working wiring than my working Duet2. And the message was telling that the driver 1 was short - ground and I had never plugged anything on the socket.
              I repeat, I swapped the wires because it didn't work with the same wiring as my Duet2.
                Phaedrux Moderator @Touchthebitum
                I forgot to mention that the error message is present without the motors plugged ...
                It is the Duet3 V1.01
                Here is a photo of the plug. I tested the phase before plugging it.
                Tape is provisory.
                What role does the tape play there? Is it possible the crimp was bad from the start and making a bad connection?
                Were you getting the error before plugging anything in or only after?
                  Touchthebitum @Phaedrux
                  @Phaedrux Tape is only a protection to avoid shorts contact. Contacts were good since I made continuity tests and resistance tests and I always had signal.
                    Were there any other error messages along with the short to ground errors?
                      @Phaedrux No, M122 had not error messages. Only those ground-short messages
                        When are where was the Duet 3 purchased?
                          @Phaedrux www.3dware.ch
                            Please send M122 and post the resulting output here.
                              Touchthebitum @dc42
                              m122
                              RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                              Board ID: 08DJM-956L2-G43S8-6J9F4-3S46N-TU2QD
                              Used output buffers: 1 of 40 (10 max)
                              Static ram: 154604
                              Dynamic ram: 162592 of which 44 recycled
                              Exception stack ram used: 224
                              Never used ram: 75752
                              Tasks: NETWORK(ready,1968) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4952) IDLE(ready,76)
                              Owned mutexes:
                              Last reset 00:00:44 ago, cause: power up
                              Last software reset at 2020-07-27 15:14, reason: User, spinning module LinuxInterface, available RAM 75704 bytes (slot 0)
                              Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0443c000 BFAR 0x00000000 SP 0xffffffff Task MAIN
                              Error status: 0
                              MCU temperature: min 19.4, current 27.7, max 27.8
                              Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                              12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                              Driver 0: standstill, reads 22474, writes 14 timeouts 0, SG min/max 0/0
                              Driver 1: standstill, reads 22474, writes 14 timeouts 0, SG min/max 0/0
                              Driver 2: standstill, reads 22475, writes 14 timeouts 0, SG min/max 0/0
                              Driver 3: standstill, reads 22475, writes 14 timeouts 0, SG min/max 0/0
                              Driver 4: standstill, reads 22478, writes 11 timeouts 0, SG min/max 0/0
                              Driver 5: standstill, reads 22479, writes 11 timeouts 0, SG min/max 0/0
                              Date/time: 2020-07-27 15:15:01
                              Slowest loop: 3.63ms; fastest: 0.14ms
                              === Storage ===
                              Free file entries: 10
                              === MainDDARing ===
                              Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                              === AuxDDARing ===
                              Segments left: 0
                              Movement lock held by null
                              HTTP* is ready with "M122" in state(s) 0
                              Telnet is idle in state(s) 0
                              File is idle in state(s) 0
                              USB is idle in state(s) 0
                              Aux is idle in state(s) 0
                              Queue is idle in state(s) 0
                              LCD is idle in state(s) 0
                              SBC is idle in state(s) 0
                              Daemon* is idle in state(s) 0
                              Aux2 is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Slowest loop: 1.02ms; fastest: 0.01ms
                              HTTP sessions: 0 of 8
                              • Ethernet -
                                State: disabled
                                Error counts: 0 0 0 0 0
                                === CAN ===
                                Messages sent 72, longest wait 0ms for type 0
                                === Linux interface ===
                                State: 0, failed transfers: 0
                                Last transfer: 18ms ago
                                RX/TX seq numbers: 583/584
                                SPI underruns 0, overruns 0
                                Number of disconnects: 0
                                Buffer RX/TX: 0/0-0
                                === Duet Control Server ===
                                Duet Control Server v3.1.1
                                Code buffer space: 4096
                                Full transfers per second: 30.27
                                Thanks. Please try commanding the motors to move (without any motors connected) and repeat that. I am looking for the driver status to change.
                                  Touchthebitum @dc42
                                  Error: short-to-ground reported by driver(s) 0 1
                                  27/07/2020 à 21:40:14 m122
                                  Static ram: 154604
                                  Exception stack ram used: 280
                                  Never used ram: 75696
                                  Tasks: NETWORK(ready,1968) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1452) TMC(blocked,68) MAIN(running,4952) IDLE(ready,76)
                                  Owned mutexes:
                                  Last reset 00:00:47 ago, cause: power up
                                  Error status: 0
                                  MCU temperature: min 20.8, current 29.0, max 29.1
                                  Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                  12V rail voltage: min 12.1, current 12.1, max 12.1, under voltage events: 0
                                  Driver 0: short-to-ground standstill, reads 39652, writes 17 timeouts 0, SG min/max 0/0
                                  Driver 1: short-to-ground standstill, reads 39652, writes 17 timeouts 0, SG min/max 0/63
                                  Driver 2: standstill, reads 39656, writes 14 timeouts 0, SG min/max 0/0
                                  Driver 3: standstill, reads 39656, writes 14 timeouts 0, SG min/max 0/0
                                  Driver 4: standstill, reads 39660, writes 11 timeouts 0, SG min/max 0/0
                                  Driver 5: standstill, reads 39660, writes 11 timeouts 0, SG min/max 0/0
                                  Date/time: 2020-07-27 20:36:50
                                  Slowest loop: 3.82ms; fastest: 0.14ms
                                  === Storage ===
                                  Hiccups: 0(0), FreeDm: 375, MinFreeDm: 373, MaxWait: 34018ms
                                  === MainDDARing ===
                                  Scheduled moves: 1, completed moves: 1, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                  === AuxDDARing ===
                                  Segments left: 0
                                  === Network ===
                                  Slowest loop: 0.88ms; fastest: 0.01ms
                                  • Ethernet -
                                    State: disabled
                                    === CAN ===
                                    Messages sent 100, longest wait 0ms for type 0
                                    Last transfer: 17ms ago
                                    RX/TX seq numbers: 808/809
                                    Buffer RX/TX: 0/0-0
                                    Full transfers per second: 3.50
                                  • percybundefined
                                    percyb
                                    I have a similar issue, getting "Warning: motor phase A may be disconnected reported by driver(s)" on all drive ports with what were working stepper motors. Only possible mistake i made is connect one stepper motor to 3 pins instead of 4 ie offset one pin. Would this cause all drivers to die?
                                    Touchthebitumundefined A Former User? 2 Replies Last reply Reply Quote 0
                                      Touchthebitum @percyb
                                      @percyb said in Short to ground on drivers 0123:
                                      Impossible because I tested all phases before plugging motor and I checked if these big crimps went on the right place when connectind them on the Duet,
                                        A Former User @percyb
                                        ref https://forum.duet3d.com/post/100507 and you should probably start your own topic if the error persist after disconnecting your motors (when powered down ofc)
                                          I think we should think about a warranty process. I don't know what to add to the discussion. I repeat, it is not the first printer I build and I'm aware of risks. Before this Duet3 I used a Duet2 and was perfect (no errors messages) with the same motors. This board never worked and I directly plugged the SAME motors that I plugged to my Duet2. So there is a problem.
                                          My shop told me to see with this forum, what I did.
                                          Now, I choosed a Genuine board because I believe in the right intelectual properties and know-how.
                                          Please, give me a clear answer and we can go on.
                                          Thanks
                                          A Former User? T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                                            A Former User @Touchthebitum
                                            that was not directed at you; I'm sure dc42 is trying to evaluate the information you've provided already
