Zaribo / Prusa i3 MK3s - Duet 2 WiFi - RRF 3.11
My Duet controlled machine
bear duet 2 wifi duet wifi duetwifi mk3s pinda prusa zaribo
4.4k
    Kolbi
    Zaribo/Prusa i3 MK3s - Duet 2 WiFi - RRF 3.11
    This is a dump from my GitHub. I figured people in search of doing similar to their i3 MK3s might have a better chance finding it here.
    ! Wiring guide: Duet2-compressed.pdf
    ! Always look here for latest revisions of all code and settings: My GitHub
    Hardware changes from stock MK3s:
    Note: The config.g file contains notes to facilitate easy adaptation to stock Prusa MK3s.
    • Bondtech Mosquito Extruder
    • 0.9 Stepper motors on X & Y axis
    • Duet WiFi
    • Zaribo 10mm Upgrade
    • PanelDue 5i
    • PT1000 hotend thermistor
    • BLTouch v3.1
    ⁉What do those hardware changes mean for your config?
    šŸ”§Motors, microstepping resolution, and steps/mm.
    Unless you have the same setup as referenced above, you may have to change the microstepping resolution and the steps per millimeter located in the 'config.g' file. To retrieve your current machine's configuration, issue a M503 command in the terminal connected to the running printer. Pay attention to the microstepping assigned to the axis as that can change your steps per millimeter. Read through the /sys/config.g file comments and make the applicable changes as needed. More about this can be read here: https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors, here: https://www.linearmotiontips.com/microstepping-basics/, and here: https://blog.prusaprinters.org/calculator3416/.
    ⚠Once you have changed/verified the motor settings, review the networking top portion of the file. When completed, copy all the files located in the 'sys', 'macros', and 'filaments' directory over to your sd-card. The 'www' and 'gcode' folder are present in the repository for reference and should not be needed to copy over to the sd-card in normal circumstances. More can be read about sd-card here: https://duet3d.dozuki.com/Wiki/SDCard, more can be read about macros here: https://duet3d.dozuki.com/Wiki/Macros.
    šŸ”§Sensorless Homing / Stallguard sensitivity.
    The TMC2660 drivers used on the Duet WiFi support the stallGuard feature. This feature allows the driver to detect motor stalls under some circumstances. Stall detection may be useful for detecting when a motor has skipped steps due to the nozzle hitting an obstruction, and for homing the printer without using endstop switches.
    As the given configuration files were authored while using 0.9 degree stepper motors on the X and Y axis, you may need to adjust your stallguard sensitivity and sensorless homing. For stallguard sensitivity, look for the "M915" in the current-sense-homing.g and current-sense-normal.g files. Read the full documentation here: https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing.
    šŸ’”Use the included Macros for filament handling.
    To make filament loading, unloading, and changing the most straightforward and simplistic possible evolution, I have made a macro set that is readily accessible from the PanelDue. To take full advantage of the duet filament system you will need to make the system filaments PLA, PETG, ABS, and PC. This will allow you to have custom instructions for each different filament, by adding such to the filament's config.g file. !Note: Based on my current macro version, it is required that each filament's load.g and unload.g remain empty. Placing code into these files will make these macro fail.
    "Set Filament Type" asks what type filament you are going to use; PLA, PETg, ABS, or PC. Based on the selection, this macro rewrites the "Heat Nozzle" macro to heat the nozzle for the selected filament type. !Note: This macro only has to be executed once for the given filament type change as it's settings are nonvolatile, regardless of reset or power off. !Note: The script will not let you change the filament type while filament is loaded.
    "Filament Handling" is for any filament unloading, loading, and changing regardless of the printer's state, printing or not. This macro will load, unload, and change filament based on two conditions; whether it detects filament is currently loaded or not, and if a print is in progress or not. !Note: The logic function in the macro retrieves the current status of the filament sensor to base the perceived desired action to enact. If your printer's filament is currently empty and you intend to load filament, please do not place it into the extruder until requested to do so by the macro. Else the macro will determine that filament is loaded and that you desire to unload filament, instead of load.
    "Heat Nozzle" is created by the "Set Filament Type" macro and can be selected to heat the hotend to the set temperature for the last chosen filament type. You do not need to run this to change filament, the "Filament Handling" macro automatically runs this macro to perform the heating of the hotend to carry out the filament handling, whether it be loading, unloading, or changing.
    Print flow events:
    When initiating a print, the following sequence of events occur in this order.
    /sys/start.g is the first codeset that starts at the beginning of each print. This contains the generic processes that apply to all filament types. From this codeset, the fillament's config.g is called.
    /filaments/PETG/config.g is the second codeset that get initiated from the "M703" command in the "start.g" file. As written in this example, we are set to use the PETG "config.g" file, located in the "filaments/PETG" directory. This contains the gcode commands that are particular to PETG filament type.
    Slicer's Start GCode is the last bit of codeset to be executed before the object's sliced gcode starts. This contains the settings particulr to the actual print and the exact PETG filament loaded. This would be your 'fine' settings, where PETG/config.g could be considered your 'medium' settings, and start.g would be the 'rough' - performing evaluations to get the printer ready.
    The part's actual gcode made by the slicer.
    Slicer's End GCode follows the printed object's gcode. This codeset lets the duet know that the print is finished which calls
    /sys/stop.g, the very last codeset that is executed. This last part commonly shutdowns heaters, retracts a bit of filament, and positions the machine to easily retrieve the printed part.
    Additional notes:
    šŸ’”Electrically independent Z motors: On printers, such as MK3, which uses two Z motors to raise/lower the bed or gantry, you can have the firmware probe the bed and adjust the motors individually to eliminate tilt. The auto calibration uses a least squares algorithm that minimises the sum of the height errors. The deviation before and expected deviation after calibration is reported. Run G32 to initiate the process. Read the full documentation here: https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors.
    šŸ’”PINDA v2: Pinda version 2 is upgraded from the previous version in that it now has an integrated thermistor, which this configuration electrically ties to thermistor E1 on the duet. Pinda temperature compensation has to be mitigated via g-code macro but will be handled via integrated function within the duet firmware shortly. Read @Argo's posting in the Duet forums: https://forum.duet3d.com/topic/16972/pinda-2-probe-with-temperature-compensation?_=1593546022132.
    šŸ’”BLTouch v3.1: The config.g has comment sections for using this probe and the wiring guide covers the electrical installation of the BLTouch v3.1 in the last few pages. Read the full documentation here: https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
    Example start gcode for ideaMaker Slicer:
    ; ideaMaker Start G-Code
    ; Set nozzle and bed to the specific temperatures declared within this slicer
    M140 S{temperature_heatbed}              ; set bed temp
    M104 S{temperature_extruder1}            ; set extruder temp
    M116                                     ; wait for all temperatures
    ; Run macro to print primeline at a 'randomized' Y positon from -1.1 to -2.9
    M98 P"0:/sys/primeLine.g"                ; primeline macro
    ; Set pressure advance
    M572 D0 S0.07                            ; set pressure advance
    Example end gcode for ideaMaker Slicer:
    ; ideaMaker End G-Code
    M400                                     ; Make sure all moves are complete
    M0                                       ; Stop everything and run sys/stop.g
    Example start gcode for Simplify3D Slicer:
    ; Simplify3D Start G-Code
    M140 S[bed0_temperature]                         ; set bed temp
    M104 S[extruder0_temperature]                    ; set extruder temp
    Example end gcode for Simplify3D Slicer:
    ; Simplify3D End G-Code
    M0
    Example start gcode for Prusa Slicer:
    ; PrusaSlicer Start G-Code:
    M140 S[first_layer_bed_temperature]      ; set bed temp
    M104 S[first_layer_temperature]          ; set extruder temp
    Example end gcode for Prusa Slicer:
    ; PrusaSlicer End G-Code
    *It is highly recommend to read through the very detailed Duet Wiki pages at https://duet3d.dozuki.com. RepRapFirmware supported G-code reference can be found here https://duet3d.dozuki.com/Wiki/Gcode#main.
    1 Reply Last reply Reply Quote 5
      Kolbi
      DUET System (sd-card contents) files follow:
      0:/sys/
      bed.g - v08/04/20
      ; 0:/sys/bed.g
      ; Called to perform automatic bed compensation via G32
      M561                                                       ; Clear any bed transform
      G28                                                        ; Home
      while iterations <=2                                       ; Perform 3 passes
         G30 P0 X25 Y107 Z-99999                                 ; Probe near a leadscrew, half way along Y axis
         G30 P1 X235 Y107 Z-99999 S2                             ; Probe near a leadscrew and calibrate 2 motors
         G90                                                     ; Set to Absolute Positioning
         G1 X100                                                 ; Move to center
         G30                                                     ; Probe the bed at the current XY position
         M400                                                    ; Finish moves, clear buffer
      while move.calibration.initial.deviation >= 0.002          ; perform additional tramming if previous deviation was over 0.002mm
         if iterations = 5                                       ; Perform 5 addition checks, if needed
            M300 S3000 P500                                      ; Sound alert, required deviation could not be achieved
            abort "!!! ABORTED !!! Failed to achieve < 0.002 deviation. Current deviation is " ^ move.calibration.initial.deviation ^ "mm."
      echo "Gantry deviation of " ^ move.calibration.initial.deviation ^ "mm obtained."
      G1 Z8                                                      ; Raise head 8mm to ensure it is above the Z probe trigger height
      cancel.g - v08/04/20
      ; 0:/sys/cancel.g
      ; called when a print is canceled after a pause.
      M83                                                        ; Makes the extruder interpret extrusion values as relative positions
      M104 S-273                                                 ; turn off hotend
      M140 S-273                                                 ; turn off heatbed
      M107                                                       ; turn off fan
      G1 F1000.0                                                 ; set feed rate
      G1 E-2                                                     ; retract 2mm
      M18 YXE                                                    ; unlock X, Y, E axis
      config.g - v08/04/20
      ; 0:/sys/config.g
      ; Configuration file for MK3s Duet WiFi, firmware version 3.11
      ; Go to https://github.com/rkolbi/RRF-machine-config-files/blob/master/Prusa%20MK3s/Duet-MK3s.pdf
      ; for corresponding wiring information.
      G90                                                        ; Send absolute coordinates
      M83                                                        ; Relative extruder moves
      M550 P"ZMK3-BMGm"                                          ; Set printer name
      M551 P"3D"                                                 ; Set password
      M552 S1                                                    ; Enable network
      M586 P0 S1                                                 ; Enable HTTP
      M586 P1 S0                                                 ; Disabled FTP
      M586 P2 S0                                                 ; Disabled Telnet
      M575 P1 S1 B38400                                          ; Enable support for PanelDue
      ; Drive Mappings S0 = backwards, S1 = forwards
      M569 P0 S1                                                 ; Drive 0 goes forwards: X Axis
      M569 P1 S1                                                 ; Drive 1 goes forwards: Y Axis
      M569 P2 S1                                                 ; Drive 2 goes forwards: Z Axis
      M569 P3 S0                                                 ; Drive 3 goes backwards: E Axis (Bondtech BMGm)
      M569 P4 S1                                                 ; Drive 4 goes forwards: Z Axis (at E1)
      ; Motor Configuration
      ; !!! For stock motors, use the following as a starting point:
      ; M906 X620.00 Y620.00 Z560.00 E650.00 I10.                ; Set motor currents (mA) and motor idle factor in percent
      ; M350 X16 Y16 Z16 I1                                      ; Microstepping with interpolation
      ; M350 E32 I0                                              ; Microstepping without interpolation
      ; M92 X100.00 Y100.00 Z400.00 E280.00                      ; Steps per mm
      ; !!! Also note that you should edit the current-sense-homing.g file and increase current to 50 on X and Y, 100 on Z.
      ; !!! M913 X20 Y20 Z60   --->   M913 X50 Y50 Z100
      M350 X16 Y16 E16 Z16 I1                                    ; Configure microstepping with interpolation
      M92 X200.00 Y200.00 Z400.00 E415.00                        ; Set steps per mm
      M566 X480.00 Y480.00 Z24.00 E1500.00 P1                    ; Set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z750.00 E1500.00                  ; Set maximum speeds (mm/min)
      M201 X2500.00 Y2500.00 Z1000.00 E5000.00                   ; Set accelerations (mm/s^2)
      M906 X1340.00 Y1600.00 Z650.00 E650.00 I10                 ; Set initial motor currents (mA) and motor idle factor in percent
      M84 S30                                                    ; Set idle timeout
      ; Motor remapping for dual Z and axis Limits
      M584 X0 Y1 Z2:4 E3                                         ; two Z motors connected to driver outputs Z and E1
      M671 X-37:287 Y0:0 S10                                     ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      M208 X0:250 Y-4:215 Z-0.1:205                              ; X carriage moves from 0 to 250, Y bed goes from 0 to 210
      M564 H0                                                    ; allow unhomed movement
      ; Endstops for each Axis
      M574 X1 S3                                                 ; Set endstops controlled by motor load detection
      M574 Y1 S3                                                 ; Set endstops controlled by motor load detection
      ; Stallgaurd Sensitivy
      M98 P"current-sense-normal.g"                              ; Current and Sensitivity for normal routine
      ; Z-Probe Settings for BLTouch
      M558 P9 C"^zprobe.in" H5 F600 T5000                        ; BLTouch, connected to Z probe IN pin
      M950 S0 C"exp.heater3"                                     ; BLTouch, create servo/gpio 0 on heater 3 pin on expansion
      G31 P1000 X22.8 Y3.8 Z1.24                                 ; BLTouch, Z offset with MICRO SWISS NOZZLE
      M574 Z1 S2                                                 ; Set endstops controlled by probe
      M557 X25:235 Y10:195 P9                                    ; Define mesh grid for probing
      ; Z-Probe Setting for PINDA v2
      ; 1 - If using PindaV2, Remove above M558 & M950 lines, replace with the following M558 & M308 line
      ; 2 - Uncomment one of the Z-Offsets below, follow the wiki guide steps to get the proper Z-offset for your printer
      ; 3 - Comment out the 2 BLTouch lines in the homez and homeall files
      ; M558 P5 C"^zprobe.in" I1 H1 F1000 T6000 A20 S0.005              ; Prusa PindaV2
      ; M308 S2 P"e1_temp" A"Pinda V2" Y"thermistor" T100000 B3950      ; Prusa PindaV2
      ; Z-Offsets - Read here: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
      ; G31 P1000 X23 Y5 Z0.985                                  ; PEI Sheet (Prusa) Offset Spool3D Tungsten Carbide
      ; G31 P1000 X23 Y5 Z0.440                                  ; PEI Sheet (Prusa) Offset MICRO SWISS NOZZLE
      ; G31 P1000 X23 Y5 Z1.285                                  ; Textured Sheet (Prusa) Offset MICRO SWISS NOZZLE
      ; G31 P1000 X23 Y5 Z0.64                                   ; Textured Sheet (thekkiinngg) Offset MICRO SWISS NOZZLE
      ; Heatbed Heaters and Thermistor Bed
      M308 S0 P"bed_temp" Y"thermistor" A"Build Plate" T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0 Bed
      M950 H0 C"bedheat" T0                                      ; Creates Bed Heater
      M307 H0 A117.2 C337.4 D9.1 S1.00 V24.0 B0                  ; Bed PID Calibration - updated 01AUG2020
      M140 H0                                                    ; Bed uses Heater 0
      M143 H0 S120                                               ; Set temperature limit for heater 0 to 120C Bed
      ; Filament Sensor
      M591 D0 P2 C"e0stop" S1                                    ; Filament Runout Sensor
      ; HotEnd Heaters and Thermistor HotEnd
      ; !!! Use this line for stock thermisotr: M308 S1 P"e0_temp" Y"thermistor" A"Nozzle" T100000 B4725 R4700  ; Set thermistor + ADC parameters for heater 1 HotEnd
      M308 S1 P"e0_temp" Y"pt1000" A"Mosquito"                   ; Set extruder thermistor for PT1000
      M950 H1 C"e0heat" T1                                       ; Create HotEnd Heater
      M307 H1 A444.4 C181.6 D3.9 S1.00 V24.1 B0                  ; Hotend PID Calibration - updated 01AUG2020
      M143 H1 S285                                               ; Set temperature limit for heater 1 to 285C HotEnd
      M302 S190 R190                                             ; Allow cold extrudes, S-Minimum extrusion temperature, R-Minimum retraction temperature
      M950 F1 C"Fan1" Q250                                       ; Creates HOTEND Fan
      M106 P1 T45 S255 H1                                        ; HOTEND Fan Settings
      M950 F0 C"Fan0" Q250                                       ; Creates PARTS COOLING FAN
      M106 P0 H-1                                                ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off PARTS COOLING FAN
      ; The following lines are for auto case fan control, attached to 'fan2' header on duet board
      M308 S4 Y"drivers" A"TMC2660"                              ; Case fan - configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
        ; !!! Reports 0C when there is no warning, 100C if any driver reports over-temperature
        ; !!! warning , and 150C if any driver reports over temperature shutdown
      M308 S3 Y"mcu-temp" A"Duet2Wifi"                           ; Case fan - configure sensor 3 as thermistor on pin e1temp for left stepper
      M950 F2 C"fan2" Q100                                       ; Case fan - create fan 2 on pin fan2 and set its frequency
      M106 P2 H4:3 L0.15 X1 B0.3 T40:70                          ; Case fan - set fan 2 value
      M912 P0 S-5.5                                              ; MCU Temp calibration - default reads 7.5c higher than ambient
      M563 P0 D0 H1 F0                                           ; Define tool 0
      G10 P0 X0 Y0 Z0                                            ; Set tool 0 axis offsets
      G10 P0 R0 S0                                               ; Set initial tool 0 active and standby temperatures to 0C
      T0                                                         ; Set Tool 0 active
      ; Relase X, Y, and E axis
      M18 YXE                                                    ; Unlock X, Y, and E axis
      current-sense-homing.g - v08/04/20
      ; 0:/sys/current-sense-homing.g
      ; Current and Sensitivity for homing routines
      M915 X S2 F0 H400 R0                                       ; Set X axis Sensitivity
      M915 Y S2 F0 H400 R0                                       ; Set y axis Sensitivity
      M913 X20 Y20 Z60                                           ; set X Y Z motors to X% of their normal current
      current-sense-normal.g - v08/04/20
      ; 0:/sys/current-sense-normal.g
      M913 X100 Y100 Z100                                        ; set X Y Z motors to 100% of their normal current
      M915 X S3 F0 H200 R0                                       ; Set X axis Sensitivity
      M915 Y S3 F0 H200 R0                                       ; Set y axis Sensitivity
      deployprobe.g - v08/04/20
      ; 0:/sys/deployprobe.g
      ; called to deploy a physical Z probe
      M280 P0 S10                                                ; deploy BLTouch
        Kolbi
        filament-change.g - v08/04/20
        ; 0:/sys/filament-change.g
        ; called when a print from SD card runs out of filament
        M25
        G91                                                        ; Relative Positioning
        G1 Z20 F360                                                ; Raise Z
        G90                                                        ; Absolute Values
        G1 X200 Y0 F6000                                           ; Parking Position
        M300 S800 P8000                                            ; play beep sound
        M98 P"0:/macros/Filament Handling"                         ; unload and load filament using macro
        M400                                                       ; clear moves
        M291 P"Press OK to recommence print." R"Filament Handling" S2
        M98 P"0:/macros/Heat Nozzle"                               ; Get nozzle hot and continue print
        filaments.csv - v08/04/20
        RepRapFirmware filament assignment file v1 generated at 2020-08-01 15:01
        extruder,filament
        0,PETG
        filaset - v08/04/20
        T0 M702
        T0 M701 S"PETG"
        homeall.g - v08/04/20
        ; 0:/sys/homeall.g
        ; home x, y, and z axis
        M98 P"current-sense-homing.g"                              ; Current and Sensitivity for homing routines
        ; !!! If using Pinda, comment-out the following two lines
        M280 P0 S160                                               ; BLTouch, alarm release
        G4 P100                                                    ; BLTouch, delay for release command
        G91                                                        ; relative positioning
        G1 Z3 F800 H2                                              ; lift Z relative to current position
        ; HOME X
        G1 H0 X5 F1000                                             ; move slowly away
        G1 H1 X-255 F3000                                          ; move quickly to X endstop
        G1 H1 X-255 F3000                                          ; move quickly to X endstop, second check
        ; HOME Y
        G1 H0 Y5 F1000                                             ; move slowly away
        G1 H1 Y-215 F3000                                          ; move quickly to Y endstop
        G1 H1 Y-215 F3000                                          ; move quickly to Y endstops, second check
        ; HOME Z
        G1 H2 Z2 F2600                                             ; raise head 2mm to ensure it is above the Z probe trigger height
        G90                                                        ; back to absolute mode
        G1 X15 Y15 F6000                                           ; go to first probe point
        G30                                                        ; home Z by probing the bed
        G90                                                        ; absolute positioning
        G1 H0 Z5 F400                                              ; lift Z relative to current position
        homex.g - v08/04/20
        ; 0:/sys/homex.g
        ; home the x axis
        G1 Z-3 F800 H2                                             ; place Z back to starting position
        homey.g - v08/04/20
        ; 0:/sys/homey.g
        ; home the y axis
        G1 H1 Y-215 F3000                                          ; move quickly to Y endstop, second check
        homez.g - v08/04/20
        ; 0:/sys/homez.g
        ; home the z axis
        G1 H0 Z3 F6000                                             ; lift Z relative to current position
        pause.g - v08/04/20
        ; 0:/sys/pause.g
        ; called when a print from SD card is paused
        M120                                                       ; Push the state of the machine onto a stack
        if sensors.filamentMonitors[0].filamentPresent = false
           G1 E-3 F3000                                            ; if filament has run out, retract 6mm of filament
        M83                                                        ; relative extruder moves
        G1 E-3 F3000                                               ; retract 3mm of filament
        G1 Z10 F360                                                ; Raise Z
        G1 X10 Y0 F6000                                            ; Parking Position
        M300 S80 P2000                                             ; play beep sound
        primeline.g - v08/04/20
        ; 0:/sys/primeline.g
        ; Print prime-line at a 'randomized' Y positon from -1.1 to -2.9
        G1 X0 Z0.6 Y{-2+(0.1*(floor(10*(cos(sqrt(sensors.analog[0].lastReading * state.upTime))))))} F3000.0;
        G92 E0.0                                                   ; set E position to 0
        G1 Z0.2 X100.0 E30.0 F1000.0                               ; prime line
        M400                                                       ; finish all current moves / clear the buffer
        resume.g - v08/05/20
        ; 0:/sys/resume.g
        ; called before a print from SD card is resumed
        G1 E3 F400                                                ; extract 3mm of filament
        G1 R1 X0 Y0 Z5                                             ; go back to the last print position with Z 5mm above
        G1 R1 Z0                                                   ; go to Z position of the last print move
        M121                                                       ; Recover the last state pushed onto the stack
        retractprobe.g - v08/04/20
        ; 0:/sys/retractprobe.g
        ; called to retract a physical Z probe
        M280 P0 S90                                                ; retract BLTouch
        sleep.g - v08/04/20
        ; 0:/sys/sleep.g
        ; called when M1 (Sleep) is being processed
        M107                                                       ; turn off fan
        M18 XEZY                                                   ; unlock all axis
        start.g - v08/04/20
        ; 0:/sys/start.g
        ; Executed before each print - BEFORE ANY SLICER CODE IS RAN
        ;M280 P0 S160                                              ; BLTouch, alarm release
        ;G4 P100                                                   ; BLTouch, delay for release command
        M572 D0 S0.0                                               ; clear pressure advance
        M703                                                       ; Execute loaded filement's config.g
        G28                                                        ; Home all
        ; if using BLTouch probe, use the following line:
        G1 Z100                                                    ; Last chance to check nozzle cleanliness
        ; if using Pinda type probe, use the following line to place probe center of bed to heat the probe
        ;G1 Z5 X100 Y100                                           ; Place nozzle center of bed, 5mm up
        M220 S100                                                  ; Set speed factor back to 100% in case it was changed
        M221 S100                                                  ; Set extrusion factor back to 100% in case it was changed
        M290 R0 S0                                                 ; Clear babystepping
        M106 S0                                                    ; Turn part cooling blower off if it is on
        G32                                                        ; Level bed
        G29                                                        ; Bed mesh
        G90                                                        ; Absolute Positioning
        M83                                                        ; Extruder relative mode
        M98 P"0:/sys/current-sense-normal.g"                       ; Ensure that motor currents and sense are set for printing
        G1 X0 Y0 Z2                                                ; Final position before slicer's temp is reached and primeline is printed.
        ; The primeline macro is executed by the slicer gcode to enable direct printing
        ; of the primeline at the objects temp and to immediately print the object
        ; following primeline completion.
        ; Slicer generated gcode takes it away from here
        stop.g - v08/04/20
        ; 0:/sys/stop.g
        ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
        M83                                                        ; Set extruder to relative mode
        M106 S255                                                  ; Turn fan fully on
        M104 S-273                                                 ; Turn off hotend
        M140 S-273                                                 ; Turn off heatbed
        G1 F1000.0                                                 ; Set feed rate
        G1 E-2.5                                                   ; Retract 2.5mm
        G1 X0 Y215 Z205 F1000                                      ; Place nozzle to left side, build plate to front, Z at top
        M400                                                       ; Clear queue
        M107                                                       ; Turn off fan
        ; Play a triumphant tune to celebrate a successful print.
        G4 S1
        M300 P250 S750
        G4 P251
        M300 P200 S1250
        G4 P201
        M300 P250 S750
        G4 P251
        M300 P200 S1250
        G4 P201
        M300 P250 S2500
        G4 P251
        M300 P150 S2000
        G4 P151
        M300 P150 S2500
        G4 P151
        M300 P350 S3700
        G4 P351
        M400
        0:/macros/
        Filament Handling - v08/04/20
        ; 0:/macros/Filament Handling
        ; Macro used for all filament handling evolutions
        if state.status != "processing"                            ; Printer is not currently printing!
           if sensors.filamentMonitors[0].filamentPresent = true   ; Filament is detected, currently loaded
              M291 P"Press OK to begin filament UNLOADING, else press CANCEL to exit." R"Filament Handling" S3
              M291 P"Please wait while the nozzle is being heated." T5
              M98 P"0:/macros/Heat Nozzle"                         ; Heat nozzle to predetermined temp
              M291 P"Ready for filament unloading. Gently pull filament and press OK." R"Filament Handling" S2
              M291 P"Retracting filament..." T5                    ; Display another message
              G1 E-150 F5000                                       ; Retract filament
              M400                                                 ; Wait for the moves to finish
              T0 M702                                              ; Select tool 0, set filament is unloaded
              M98 P"0:/macros/Filament Handling"; run again        ; Now that filament is unloaded, lets ask to load filament
           else
              M291 P"Press OK to begin filament LOADING, else press CANCEL to exit." R"Filament Handling" S3
              M291 P"Ready for filament loading. Insert filament and press OK." R"Filament Handling" S2
              M291 P"Feeding filament..." T5                       ; Display new message
              G1 E150 F450                                         ; Feed 150mm of filament at 600mm/min
              G1 E20 F100                                          ; Feed 20mm of filament at 100mm/min
              G4 P1000                                             ; Wait one second
              G1 E-1 F1800                                         ; Retract 10mm of filament at 1800mm/min
              M400                                                 ; Wait for moves to complete
              M98 P"0:/sys/filaset"                                ; Set system filament type
        else
           M291 P"Press OK to begin filament CHANGE, else press CANCEL to exit." R"Filament Handling" S3
           M98 P"0:/sys/filament-change.g"                         ; Call filament-change.g
           M24                                                     ; Start/resume SD print
        Heat Nozzle - v08/04/20
        ; 0:/macros/Heat Nozzle
        ; Heat nozzle to set temp
        M291 R"Filament Handling" P"Heating nozzle for PETg, please wait." S0 T5
        T0                                                         ; Select Tool 0
        M109 S230                                                  ; set temp to 230c and wait
        Set Filament Type - v08/04/20
        ; 0:/macros/Set Filament Type
        ; Macro used to set system's loaded filament type
        if sensors.filamentMonitors[0].filamentPresent = false        ; if filament is loaded then reject action to change filament type
          M291 P{"System filament is currently set to " ^ move.extruders[0].filament ^ ". Press OK to change filament type, else press CANCEL to exit."} R"Filament Handling" S3
          ; Set PLA temp
          M28 "0:/macros/Heat Nozzle"                                 ; Begin writing to SD card file
          M291 R"Filament Handling" P"Heating nozzle for PLA, please wait." S0 T5
          T0                                                          ; Activate Hotend
          M109 S200                                                   ; set temp to 200c and wait
          M29                                                         ; Stop writing to SD card
          M28 "0:/sys/filaset"                                        ; Begin writing to SD card file
          T0 M702                                                     ; Set system filament as UNLOADED
          T0 M701 S"PLA"                                              ; Set system filament as PLA
          M291 S3 R"Filament Handling" P"Filament type currently set to PLA. Press cancel to save this selection or OK to proceed to next filament type."
          ; Set PETg temp
          T0 M701 S"PETG"                                             ; Set system filament as PETG
          M291 S3 R"Filament Handling" P"Filament type currently set to PETg. Press cancel to save this selection or OK to proceed to next filament type."
          ; Set ABS temp
          M291 R"Filament Handling" P"Heating nozzle for ABS, please wait." S0 T5
          M109 S250                                                   ; set temp to 250c and wait
          T0 M701 S"ABS"                                              ; Set system filament as ABS
          M291 S3 R"Filament Handling" P"Filament type currently set to ABS. Press cancel to save this selection or OK to proceed to next filament type."
          ; Set PC temp
          M291 R"Filament Handling" P"Heating nozzle for PC, please wait." S0 T5
          M109 S270                                                   ; set temp to 270c and wait
          T0 M701 S"PC"                                               ; Set system filament as PC
          M291 S3 R"Filament Handling" P"Filament type currently set to PC. Press cancel to save this selection or OK to proceed to next filament type."
        else
          M291 S3 R"Filament Handling" P"Filament is currently loaded. Please unload filament before changing filament type."
          Kolbi
          0:/filaments/ABS/
          ; 0:/filaments/ABS/config.g
          ; Macro use to set 'basic' setting for filament type
          M300 S1000 P200 G4 P500 M300 S3000 P300                     ; play some tones
          M140 S75                                                    ; set bed temp
          M104 S150                                                   ; set extruder warm-up temp
        ; active temp set from slicer gcode
          ; Insert additional filament specific settings here
          load.g - v08/04/20
          ; LEAVE EMPTY
          unload.g - v08/04/20
          ; LEAVE EMPTY
          0:/filaments/PC/
          ; 0:/filaments/PC/config.g
          load.g - v08/04/20
          ; LEAVE EMPTY
          ; LEAVE EMPTY
          0:/filaments/PETG/
          ; 0:/filaments/PETG/config.g
          load.g - v08/04/20
          ; LEAVE EMPTY
          ; LEAVE EMPTY
          0:/filaments/PLA/
          ; 0:/filaments/PLA/config.g
          M140 S65                                                    ; set bed temp
          load.g - v08/04/20
          ; LEAVE EMPTY
          ; LEAVE EMPTY
          undefined 1 Reply Last reply 5 Aug 2020, 20:11 Reply Quote 2
            Kolbi @Kolbi
            Updated primeline:
            ; Print prime-line at a 'randomized' Y position from -1.1 to -2.9
            ; Charge! tune
            M400
            G4 S1
            M300 P200 S523.25
            G4 P200
            M300 P200 S659.25
            G4 P200
            M300 P200 S739.99
            G4 P250
            M300 P285 S880.00
            G4 P450
            M300 P285 S880.00
            G4 P285
            M300 P625 S1108.73
            G4 S1
            M400
            G92 E0.0                                                   ; Reset extrusion distance
            G1 E8                                                      ; Purge Bubble
            G1 X60.0 E11.0 F1000.0                                     ; intro line
            G1 X120.0 E16.0 F1000.0                                    ; intro line
            M400                                                       ; Finish all current moves / clear the buffer
              Kolbi
              I added a new macro, Hotmesh.
              "Hotmesh" preforms bed a mesh probing routine with a heat stabilized bed. This macro will heat the bed based on the currently set system filament type, wait 5 minutes for the bed temperature to stabilize, and then perform mesh probe. Once initiated, the nozzle will rise to 150mm and then lower 15mm for every 30 seconds elapsed - about 5 minutes in total. Once the nozzle is at the bed, the mesh probing cycle will commence.
              ; 0:/macros/hotmesh.g
              ; Called to perform automatic heated bedmesh compensation
              T0                                                         ; Ensure tool is selected
              M703                                                       ; Heat bed to set temp based off current system filament type
              M291 P{"Performing bed heatup per " ^ move.extruders[0].filament ^ " profile. This process will take approximately 6 minutes."} R"Hotmesh" S0 T10
              G28                                                        ; Home
              G1 X100 Y100                                               ; Place nozzle center of bed
              ; Give 5 minutes for stabilization
              G91                                                        ; Set to Rel Positioning
              while iterations <=9                                       ; Perform 10 passes
                  G1 Z15                                                 ; Move Z 15mm up
                  G4 S0.5                                                ; Wait .5 seconds
              M116                                                       ; Wait for all temperatures
              M291 P"Bed temperature at setpoint. Please wait 5 minutes for stabilization, Z indicates countdown." R"Hotmesh" S0 T10
              ; Start countdown - use Z as indicator
                  G4 S30                                                 ; Wait 30 seconds
                  G1 Z-15                                                ; Move Z 15mm down
              M291 P"Performing homing, gantry alignment, and mesh probing. Please wait." R"Hotmesh" S0 T10
              G32                                                        ; Home and Level gantry
              M400                                                       ; Clear queue
              G29                                                        ; Perfrom bed mesh
              M291 P"Hotmesh complete. Hotend and Heatbed are turned off. Performing final homing routine. Please wait." R"Hotmesh" S0 T10
              G28                                                        ; Home
                Kolbi
                Alternative setup to load bedmesh from the system's set filament type directory, and if start.g fails load the file (because it doesn't exist) it will create one.
                Alternative Hotmesh.g:
                This saves the heightmap to the system's set filament type directory (0:/filaments/PETG/heightmap.csv)
                ; Alternative Hotmesh.g - This saves the heightmap to the system's set filament's type directory (0:/filaments/PETG/heightmap.csv)
                if state.status = "processing"                             ; Printer is currently printing!
                   M99                                                     ; Abort this macro
                G28                                                        ; Home
                    G1 Z15 F300                                            ; Move Z 15mm up
                    G1 Z-15 F300                                           ; Move Z 15mm down
                M400                                                       ; Clear queue
                G29 S3 [P{"0:/filaments/" ^ move.extruders[0].filament ^ "/heightmap.csv"}] ; Save heightmap.csv to filament type's directory
                G28                                                        ; Home
                M18                                                        ; Free all
                Alternative Start.g:
                Alternative Start.g - This loads the heightmap from the system's set filament type directory (0:/filaments/PETG/heightmap.csv), if the heightmap does not exist, create one, and then save in the filament's directory.
                ; 0:/sys/start.g
                ; Alternative Start.g - This loads the heightmap from the system's set filament
                ; type directory (0:/filaments/PETG/heightmap.csv), if the heightmap does not
                ; exist, create one, and then save in the filament's directory.
                ;G4 P100                                                   ; BLTouch, delay for the release command
                M703                                                       ; Execute loaded filament's config.g
                G28                                                        ; Home all
                ;G1 Z5 X100 Y100                                           ; [PINDA] Place nozzle center of bed, 5mm up
                G1 Z160 F300                                               ; [BLTouch] Last chance to check nozzle cleanliness
                M300 S4000 P100 G4 P200 M300 S4000 P100                    ; Give a double beep
                M300 S4000 P100                                            ; Give a single beep
                ; [BLTouch] Start countdown - use Z as indicator
                G91                                                        ; [BLTouch] Set to Relative Positioning
                while iterations <=9                                       ; [BLTouch] Perform 10 passes
                    G4 S12                                                 ; [BLTouch] Wait 12 seconds
                    G1 Z-15 F300                                           ; [BLTouch] Move Z 15mm down
                G90                                                        ; [BLTouch] Set to Absolute Positioning
                ;G4 S120                                                   ; [PINDA] wait additional 2 minutes for the bed to stabilize
                G32                                                        ; Level bed
                G29 S1 [P{"0:/filaments/" ^ move.extruders[0].filament ^ "/heightmap.csv"}] ; Load bed mesh for the system's set filament type
                if result > 1                                              ; If file doesn't exist, perform mesh and save
                   G29                                                     ; Perform mesh now
                  Kolbi
                  Latest README: README.pdf
                  Latest sd-card dump: README above contains dump.
                  Latest wiring guide: Duet2.pdf
                  Archive file containing the full set of sd-card files, wiring guide, readme, and ideaMaker example profile set.
                  The next meaningful revision of my files will most likely occur once variables are enabled within the gcode macros.
                  If you find any issues or have any suggestions please let me know so I can take the appropriate actions and make this a better guide/code for the public.
                  Many thanks Duet forum people!
                  Cheers,
                  Kolbi
                    Thanks for the excellent reference examples.
                    Also just a heads up it looks like the forum software or copy paste error is inserting some random {1} to your blocks.
                    undefined 1 Reply Last reply 11 Aug 2020, 04:34 Reply Quote 0
                      Kolbi @Phaedrux
                      @Phaedrux Thanks much!
                      I saw the {1} and tried to get rid of them but for some reason, it didn't work.
                      I did attach my dump-list.pdf so people could view it there also - I keep this one updated too.
                      I'll give it a shot once I get some time this evening. Do you know what causes them?
                      Cheers,
                      Kolbi
                      Phaedruxundefined 1 Reply Last reply 11 Aug 2020, 04:45 Reply Quote 0
                        Phaedrux Moderator @Kolbi
                        @Kolbi said in Zaribo / Prusa i3 MK3s - Duet 2 WiFi - RRF 3.11:
                        They seem to show up on line breaks within the code blocks for some reason. It's a forum issue.
                        undefined A Former User? 2 Replies Last reply 11 Aug 2020, 04:59 Reply Quote 0
                          Kolbi @Phaedrux
                          @Phaedrux said in Zaribo / Prusa i3 MK3s - Duet 2 WiFi - RRF 3.11:
                          Ah! Just add a space after a line break and that gets rid of it.
                            Good to know!
                              A Former User @Phaedrux
                              not for all types of code interestingly enough, but haven't experimented with the complete list of language highlighting.
                              • Kolbiundefined
                                Kolbi
                                Updated stop.g, focused on getting rid of spider web / hair like stringing from nozzle while leaving nothing on nozzle.
                                ; 0:/sys/stop.g
                                G1 E-2                                                     ; Retract 2mm
                                M98 P"current-sense-homing.g"                              ; Adjust current and sensitivity for homing routines
                                ; Let cool and wiggle for bit to reduce end stringing
                                G91                                                        ; Set to Relative Positioning
                                G1 Z2 F400                                                 ; Move Z up 3mm
                                ; Start countdown - use X/Y as indicators of counting
                                    G4 S6                                                  ; Wait 6 seconds
                                    G1 X1 Y1 F1000                                         ; Wiggle +1mm
                                    G1 Z0.5 X-1 Y-1 F1000                                  ; Wiggle -1mm, Z +0.5
                                G1 X220 Y205 Z205 F1000                                    ; Place nozzle to the right side, build plate to front, Z at top
                                M400                                                       ; Clear queue
                                M107                                                       ; Turn off fan
                                G4 S1
                                M300 P250 S750
                                G4 P251
                                M300 P200 S1250
                                G4 P201
                                M300 P250 S750
                                G4 P251
                                M300 P200 S1250
                                G4 P201
                                M300 P250 S2500
                                G4 P251
                                M300 P150 S2000
                                G4 P151
                                M300 P150 S2500
                                G4 P151
                                M300 P350 S3700
                                G4 P351
                                M400
                                • Kolbiundefined
                                  Kolbi
                                  Attached modified BMGm-BLTouch.
                                  Offsets at X22.8, Y3.8, Z1.32.
                                  10068-6 Prusa Housing Rear MK3s MosquitoV1.4.STL 10068-7 Prusa Housing Front MK3s MosquitoV1.4.STL 1596246771954-screen-shot-2020-08-01-at-10.40.16-am-resized.jpg preview.JPG 1596083183516-bmgm-bltouch-actual-resized.jpg
                                  • Kolbiundefined
                                    Kolbi
                                    Forgot the bltouch wire cover.
                                    bltouch-wirecover.STL
                                    *The front and back parts require threaded inserts.
                                    • jdebuhrundefined jdebuhr referenced this topic 9 May 2022, 02:44
                                    • T3P3Tonyundefined T3P3Tony unpinned this topic 27 Sept 2022, 11:24
                                    • e4dundefined
                                      e4d
                                      Hello @Kolbi do you have an enclosure for Duet wifi that mount to the printer ? I’d love to have an STL if you mind sharing
                                      Kolbiundefined 1 Reply Last reply 15 Jul 2023, 19:51 Reply Quote 0
                                      • Kolbiundefined
                                        Kolbi @e4d
                                        @e4d Sorry, It's been a while and I don't have that on my latest laptop. I'll give a search on my home server when I get a chance to see if I may have backed it up.
                                        But, give a look at the caribou github - variants from duet 2 and 3mini exist.
                                        https://github.com/Caribou3d/CaribouCartesian/tree/master/STL/01_full-kits/Frame/Duet
                                        Hope that helps!
