Duet 3 Mini 5+ : Initial announcement
@bearer either through bridges or by soldering in the header and adding jumpers to easily reverse it, I don't mind either way.
@pipersw said in Duet 3 Mini 5+ : Initial announcement:
So if I have a Duet2wifi with 1.68A steppers for X Y E0, Dual Z 1.68 steppers in serial, bltouch and Rotating Magnet Filament Monitor, I could go to this board without issue ?
most likely quite soon, ref https://forum.duet3d.com/post/168488 (maybe i missread that too, I meant you could use existing board with klipper and sbc)
@pipersw You would probably use a separate driver for each Z, but yes.
Wow. This is going to be a release day purchase for sure. I love my Duet2 Wifi and have put RRF on my SKR boards because the Duet spoiled me so much with its ease of use.
I was reluctant to buy more Duets as I figured there'd be something like this coming soon.Can't wait. I'll take two!
Very excited about this with the three driver expansion board!
I've been deliberating what board I want to use for an upcoming project and the Duet 3 6HC was up there, although a little ott for my needs.
@gregsaun pointed out this upcoming board and it's actually a perfect match for the project. There is no longer any question as what board I'll be using -
100%
all day
... that green PCB confused me for a second.
Exciting!
It's only green because green prototypes are sometimes faster to get made and delivered than blue ones.
@dc42 Want one for my Delta time it had an upgrade lol
So far, testing shows that the wifi upload speed is about the same as the Duet WiFi, and the Ethernet upload speed is a little faster than the Duet Ethernet.
@dc42 I assume that the SBC support is there as that would be the way I would want to run it failing that the ethernet one would be my choice TBH. Once it is available.
Looking good!
SBC support is included, but not tested yet. I've currently disabled SBC support in firmware, because I identified an issue that causes problems when SBC support is included but no SBC is connected.
@dc42 said in Duet 3 Mini 5+ : Initial announcement:
Is that across the whole duet3 range or just the mini due to the different MCU?
This would be great to test on an IDEX I'm building
You get picked for the testing or will there be a way to apply? -
@dc42 There is a big difference of speed between wifi and ethernet speed ?
No, the Ethernet is currently only about 20% faster than the WiFi, although there is more scope for improvement with Ethernet.
I already have a Duet 2 Wifi. I would love to test this on my Delta, and Folgertech FT-5, that is likely going to be converted to corexy.
This looks awesome! I am especially interested in being able to use my 24v PS and then use 12v fans as they're so much easier to get ahold of!
Was the rumor I heard that Duet3 Mini will have both Ethernet and WiFi, true as well?
