Duet 3 Mini 5+ : Initial announcement
@bearer hence the suggestion to allow for this connection
@pixelpieper said in Duet 3 Mini 5+ : Initial announcement:
@T3P3Tony Klipper could if someone implements it, direct UART communication is just already available and would simplify the implementation.
If you have the space to allow for a 2x2 header to be soldered in@pixelpieper then you might want to change the wording - asking for additional space for a 2x2 header isn't the same thing, and doesn't even achieve the goal of using the same 26pin ribbon cable without custom wiring loom.
@bearer @pixelpieper
Thanks - I understand. The 2x2 header would be a pair of jumpers so that the UART was not always connected to the SBC (for example if you wanted to use a PanelDue instead.
I will look at this as part of the next design review.
@bearer good point, I meant 2x2 in order to add jumpers to RX and TX
d'oh - brain is being slow...
if its talk of a unpopulated headed then solder bridges are smaller and easier to place?
So if I have a Duet2wifi with 1.68A steppers for X Y E0, Dual Z 1.68 steppers in serial, bltouch and Rotating Magnet Filament Monitor, I could go to this board without issue ?
@bearer either through bridges or by soldering in the header and adding jumpers to easily reverse it, I don't mind either way.
@pipersw said in Duet 3 Mini 5+ : Initial announcement:
most likely quite soon, ref https://forum.duet3d.com/post/168488 (maybe i missread that too, I meant you could use existing board with klipper and sbc)
@pipersw You would probably use a separate driver for each Z, but yes.
Wow. This is going to be a release day purchase for sure. I love my Duet2 Wifi and have put RRF on my SKR boards because the Duet spoiled me so much with its ease of use.
I was reluctant to buy more Duets as I figured there'd be something like this coming soon.Can't wait. I'll take two!
Very excited about this with the three driver expansion board!
I've been deliberating what board I want to use for an upcoming project and the Duet 3 6HC was up there, although a little ott for my needs.
@gregsaun pointed out this upcoming board and it's actually a perfect match for the project. There is no longer any question as what board I'll be using -
100%
all day
... that green PCB confused me for a second.
Exciting!
It's only green because green prototypes are sometimes faster to get made and delivered than blue ones.
@dc42 Want one for my Delta time it had an upgrade lol
So far, testing shows that the wifi upload speed is about the same as the Duet WiFi, and the Ethernet upload speed is a little faster than the Duet Ethernet.
@dc42 I assume that the SBC support is there as that would be the way I would want to run it failing that the ethernet one would be my choice TBH. Once it is available.
Looking good!
SBC support is included, but not tested yet. I've currently disabled SBC support in firmware, because I identified an issue that causes problems when SBC support is included but no SBC is connected.
