    Duet 3 6HC - Short to ground issue.
    51
    3.0k
      dc42 administrators @elmoret
      @elmoret said in Duet 3 6HC - Short to ground issue.:
      You would see a short to ground error, and the affected motor not moving.
      To clarify: if any of the 4 diode packages associated with each driver is not properly soldered, then if you are using 24V power, you will get a short-to-ground report and the motor concerned will vibrate or not move at all. But if you use 12V power, you will most likely not get a short-to-ground report and the motor will move normally.
      At this stage we do not know whether all boards with KAXS4 marked diodes are likely to be affected, however it does appear that the issue affects more than a single reel of diodes.
      tony73undefined 1 Reply Last reply Reply Quote 0
      • tony73undefined
        tony73 @dc42
        Hello everyone! as already said my duet 3 6ch card arrived a few days ago and one of those interested cod. (WD41xxx) diodes (kaxs4) I have tried all 24 volt drivers for now they all work no errors!
          T3P3Tony administrators
          Hi Tony, thanks for the info. That aligns with what we are seeing, not all diodes soldered badly.
          What is your board serial number?
          • tony73undefined
            tony73 @T3P3Tony
            @T3P3Tony
            Hello ! and this right?
            • Erika de la Cruzundefined
              Erika de la Cruz
              I received my Duet 3 last week; I had time to install it until Monday; unfortunately, Driver 0 and Driver 1 are not working, motors vibrate, and in the Duet Web Control there is a message saying "Short-to-ground reported by drivers #(number of driver)". I tested the same motors/wires in drivers 2-5, and they work perfectly, my system has dual Z and X-axis, so I really need the 6 driver channels. The serial number is WD41385.
              tony73undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
              • tony73undefined
                tony73 @Erika de la Cruz
                @Erika-de-la-Cruz
                hello are you powering the card at 24volt?
                Erika de la Cruzundefined 1 Reply Last reply Reply Quote 0
                  Phaedrux Moderator @Erika de la Cruz
                  @Erika-de-la-Cruz Please email info@duet3d.com if you have not already done so. Thanks.
                    T3P3Tony administrators @tony73
                    @tony73 thanks, helpful to track the boards that are working well as well.
                    Ralmsundefined 1 Reply Last reply Reply Quote 0
                    • Ralmsundefined
                      Ralms @T3P3Tony
                      @T3P3Tony said in Duet 3 6HC - Short to ground issue.:
                      Hi there,
                      I have one of these matching boards, serial number WD41269 with those KAXS4 diodes.
                      Right now I'm using a 12V power supply and the board is working fine, no errors or anything using 5 of the 6 drivers.
                      My question considering warranty as I do plan switching to 24V in the future.
                      Will I need to rush upgrading the printer to 24V so I don't miss the warranty time?
                      I bought the board from E3D a couple weeks back, so it's mostly so I can manage things and plan ahead.
                        Erika de la Cruz @Phaedrux
                        @Phaedrux Hi, thank you! I've already contacted filastruder, in fact, I posted here because they sent me a form to fill, which asked to do so.
                          Erika de la Cruz @tony73
                          @tony73 Hi, yes, I have a 24v system and was trying to upgrade from a Duet 2, I've contacted filastruder support, and I'll send the board back soon for a replacement. Thank you.
                            T3P3Tony administrators @Ralms
                            @Ralms please contact info@duet3d.com I don't want to rush the upgrade for you.
                            • aldialloundefined
                              aldiallo
                              Hi all,
                              I'm a noob with the Duet hardware and just got my first duet card with the Duet 3 6HC which I received a couple of weeks ago but haven't get the time to install it yet.
                              Here's my card serial, D3MB6HCV1.01 / WD41551; are you able to let me know if the card is impacted by the issue and if so should I reach out to the reseller for a replacement?
                              Thanks
                                T3P3Tony administrators @aldiallo
                                @aldiallo the only way to tell for sure is test the drivers on 24V power. You are covered by warranty so its worth testing it before returning it as only part of this batch is affected.
                                aldialloundefined 1 Reply Last reply Reply Quote 0
                                • aldialloundefined
                                  aldiallo @T3P3Tony
                                  Thanks T3P3Tony, I'll make some time this weekend and will give it a try and advise
                                  • plague_dog32undefined
                                    plague_dog32
                                    Hi also having the issue with short to ground, already emailed support and needed to post on the forum to start the replacement process with filastruder. Serial number WD41384 with KAXS4 diodes short to ground on all drivers with 24v
                                    • maxspongebobundefined
                                      maxspongebob @T3P3Tony
                                      @T3P3Tony
                                      It has been a learning experience. I will be patient though. Is the problem fixed on boards being produced now?
                                      Is there something I can do to fix the circuit or is it the PCB itself?
                                      This board was purchased from PrintedSolid.com (good vendor BTW).
                                      Board SN WD41585...
                                        T3P3Tony administrators @maxspongebob
                                        @maxspongebob thanks for your email. and to answer the specific question. it was an issue with a specific batch of diodes. Other boards are not affected.
                                        • aleohlundefined
                                          aleohl
                                          Is this issue resolved?
                                          Do you have any ETA on resume of sale?
                                          I need to order some boards!
                                            @aleohl We are working with our resellers to exchange boards with the fault. depending on where you are your local reseller may already have replacements boards.
