    Duet 3 6HC - Short to ground issue.
    51
    3.0k
    • tony73undefined
      tony73 @Erika de la Cruz
      @Erika-de-la-Cruz
      hello are you powering the card at 24volt?
      Erika de la Cruzundefined 1 Reply Last reply Reply Quote 0
        Phaedrux Moderator @Erika de la Cruz
        @Erika-de-la-Cruz Please email info@duet3d.com if you have not already done so. Thanks.
          T3P3Tony administrators @tony73
          @tony73 thanks, helpful to track the boards that are working well as well.
          Ralmsundefined 1 Reply Last reply Reply Quote 0
          • Ralmsundefined
            Ralms @T3P3Tony
            @T3P3Tony said in Duet 3 6HC - Short to ground issue.:
            Hi there,
            I have one of these matching boards, serial number WD41269 with those KAXS4 diodes.
            Right now I'm using a 12V power supply and the board is working fine, no errors or anything using 5 of the 6 drivers.
            My question considering warranty as I do plan switching to 24V in the future.
            Will I need to rush upgrading the printer to 24V so I don't miss the warranty time?
            I bought the board from E3D a couple weeks back, so it's mostly so I can manage things and plan ahead.
            • Erika de la Cruzundefined
              Erika de la Cruz @Phaedrux
              @Phaedrux Hi, thank you! I've already contacted filastruder, in fact, I posted here because they sent me a form to fill, which asked to do so.
                Erika de la Cruz @tony73
                @tony73 Hi, yes, I have a 24v system and was trying to upgrade from a Duet 2, I've contacted filastruder support, and I'll send the board back soon for a replacement. Thank you.
                  T3P3Tony administrators @Ralms
                  @Ralms please contact info@duet3d.com I don't want to rush the upgrade for you.
                  • aldialloundefined
                    aldiallo
                    Hi all,
                    I'm a noob with the Duet hardware and just got my first duet card with the Duet 3 6HC which I received a couple of weeks ago but haven't get the time to install it yet.
                    Here's my card serial, D3MB6HCV1.01 / WD41551; are you able to let me know if the card is impacted by the issue and if so should I reach out to the reseller for a replacement?
                    Thanks
                      T3P3Tony administrators @aldiallo
                      @aldiallo the only way to tell for sure is test the drivers on 24V power. You are covered by warranty so its worth testing it before returning it as only part of this batch is affected.
                      aldialloundefined 1 Reply Last reply Reply Quote 0
                      • aldialloundefined
                        aldiallo @T3P3Tony
                        Thanks T3P3Tony, I'll make some time this weekend and will give it a try and advise
                        • plague_dog32undefined
                          plague_dog32
                          Hi also having the issue with short to ground, already emailed support and needed to post on the forum to start the replacement process with filastruder. Serial number WD41384 with KAXS4 diodes short to ground on all drivers with 24v
                          • maxspongebobundefined
                            maxspongebob @T3P3Tony
                            @T3P3Tony
                            It has been a learning experience. I will be patient though. Is the problem fixed on boards being produced now?
                            Is there something I can do to fix the circuit or is it the PCB itself?
                            This board was purchased from PrintedSolid.com (good vendor BTW).
                            Board SN WD41585...
                              T3P3Tony administrators @maxspongebob
                              @maxspongebob thanks for your email. and to answer the specific question. it was an issue with a specific batch of diodes. Other boards are not affected.
                              • aleohlundefined
                                aleohl
                                Is this issue resolved?
                                Do you have any ETA on resume of sale?
                                I need to order some boards!
                                  @aleohl We are working with our resellers to exchange boards with the fault. depending on where you are your local reseller may already have replacements boards.
                                    maxspongebob
                                    This post is deleted!
                                    • wikipedia_Brownundefined
                                      wikipedia_Brown
                                      I am experiencing short to ground fault on all but driver output that I have tested. I purchased my board through Printed Solid and the Serial # is WD4159.
                                      maxspongebobundefined 1 Reply Last reply Reply Quote 0
                                        maxspongebob @wikipedia_Brown
                                        @wikipedia_Brown You will need to provide the SN of your board along with a copy of the results of the M122 command and send it to info@duet3d.com. They should confirm that it is to be replaced.
                                        Once you have that confirmation from duet3d, send a message to support@printedsolid.com. Include the confirmation and then they will send you an RMA#.
                                        I got a message from Dustin at Printed Solid today saying that they do not yet have replacement boards.
                                        Hopefully soon.
                                          maxspongebob
                                          @T3P3Tony, Can you tell us what vendors have the new corrected boards already?
                                          • Thaliosundefined
                                            Thalios
                                            3 boards here, no issues. 41030, 41115, 41xxx that I can't see the sticker as it is in a case, but was bought in April.
                                            All running 24V, one on an upgraded Ender 3 Pro, one on a Railcore II 300ZL, one (latest) on a upgraded Tronxy X5SA-500 Pro.
                                            Let me know if you need me to test something or inspect something on them.
                                            Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
                                            Heavily modified Ender 3 Pro (Duet 3 6HC)
                                            Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
                                            CR-10S Pro V2 (Duet 3 Mini 5+)
                                            and a bunch of SLA printers..
