    BLV Mgn Cube Motion
    1.1k
    • mrenz999undefined
      mrenz999
      I am using 3.1.1. Everything moves fine when the machine is turned off. I have the motors set at 800. Checking with the manufacturer on what it should be. M112 says
      8/10/2020, 6:28:50 PM m112
      8/10/2020, 6:28:50 PM Emergency stop, attemping to reconnect...
      8/10/2020, 6:28:50 PM Warning: Firmware halted
      8/10/2020, 6:28:14 PM Warning: M307: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 667C
      • mrenz999undefined
        mrenz999 @Phaedrux
        @Phaedrux I used the wires that came with the stepper motors. I now have the specs for them. I'm sure some of the issues are coming from using 3 z motors.
        Phase A 1.7 Phase B 1.5 Inductance 2.8. From the stepper motor manufacturer. Not sure what I should change them to.
        • I_Jediundefined
          I_Jedi
          Grinding noise and no motion is what happened to me when I had motors working against each other or didn't have the two coils hooked up correctly.
          I would start by unplugging one motor at a time and then moving a little bit in each direction just to see that the motor responds.
          And make sure you have the two coils properly identified -- DONT go by wire color. The BLV MGN instructions based on color has lead many astray -- there is no standard for color or order
          mrenz999undefined 1 Reply Last reply Reply Quote 0
          • mrenz999undefined
            mrenz999 @I_Jedi
            @I_Jedi I bought a kit and it can with wires already with ends on them... So I am just assuming the are correct.
              M112 is emergency stop. M122 is diagnostic report.
              Use this method to identify your motor phase pairs. Each phase should be connected to either side of the motor connector.
              https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
              For the stepper motor current you should target to use between 60-85% of their rated max current.
              Make sure you don't unplug the motors while the board is powered.
              @mrenz999 said in BLV Mgn Cube Motion:
              There is no standard. If the motors came with a spec sheet that shows the wire pairs, then make sure you are wiring those pairs correctly to the board. If it doesn't show which pair is which wires, use the test linked above.
              And here: https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Using_the_internal_drivers
              • whopping pochardundefined
                whopping pochard
                Adding my voice to the recommendations to test your motor phases. My BLV cube kit came with inconsistent wire colors on the motors and I burned out one of my Duet2 drivers before I learned better!
                I also think it’s likely that you have motors working against each other. Try (IIRC) G1 Y20 F500 S2 and see if just one motor turns.
                • mrenz999undefined
                  mrenz999 @Phaedrux
                  @Phaedrux Ok. You were of course correct. Rewired the stepper motors. Going through the setups to get the motors working together correctly. Right now when I go to home x it heads for y home. And then on to getting the 3 Z motors to work together.
                  whopping pochardundefined dhusoloundefined 2 Replies Last reply Reply Quote 0
                    whopping pochard @mrenz999
                    @mrenz999 Congrats!! πŸ‘ And you didn't even burn a driver out in the process. πŸ˜…
                    • mrenz999undefined
                      mrenz999 @whopping pochard
                      @whopping-pochard I sure hope not LOL
                      • dhusoloundefined
                        dhusolo @mrenz999
                        @mrenz999 If you're homing is messed up you need to verify your drive assignments in config.g and your wiring on the physical board.
                        Have you checked the BLV Facebook page? I'm a moderator on the page and there's a lot of good information on there.
                        • mrenz999undefined
                          mrenz999 @dhusolo
                          @dhusolo I have everything homing correctly now. Thank you. I will go to the facebook though. I am now messing with getting the triple z motors working together. Also, I need to figure out setup correctly for speeds, steps and amps for the motors. One step at a time. Too much work and not enough time to play lol.
                          I_Jediundefined 1 Reply Last reply Reply Quote 0
                          • I_Jediundefined
                            I_Jedi @mrenz999
                            @mrenz999 what turned out to be the issue, in case someone with the same problem stumbles across this months/years from now...
                            • mrenz999undefined
                              mrenz999 @I_Jedi
                              @I_Jedi Phases of the motors were in fact wrong. It was pin 1 and pin and 3 and 2 and 6 that were the 2 phases.
                              • I_Jediundefined
                                I_Jedi @mrenz999
                                @mrenz999 good job tracking that down!
