    hbot homes correctly but prints mirrored ,
    8.8k
    • tracarundefined
      tracar @peter247
      @peter247
      https://spool3d.ca/duet-expansion-breakout-board/
      peter247undefined 1 Reply Last reply Reply Quote 0
      • tracarundefined
        tracar
        here is another clue, after initial power up test bltouch goes in and out a couple o times, then i issue a bltouch test, where its sposta cycle in and out,,, well it does not..... but at that point i can unplug it , plug it back in and it wont do a self test.
        • peter247undefined
          peter247 @tracar
          @tracar
          You have it easy, without the expansion board it is I think the 10th pin from the left on the top set of pins.
          It is midnight in the UK , so off to bed now , good luck and hope you find the problem.
          Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
          tracarundefined 1 Reply Last reply Reply Quote 0
          • tracarundefined
            tracar @peter247
            @peter247
            thanks for all the help. have a goodnight
            • tracarundefined
              tracar
              i have tried everything i can, except what works. and decided to revert back to 2.05.1
              everything works even the bltouch. im going to wait till a more streamlined 3xx comes along.
              want to say thanks to everyone for all the help along the way, it was not wasted as it showed me how to get the proper settings for homing and machine travel and set it all right in 2xx.
              last question, can the web interface be set up with keyboard commands, such as up , down , left , right arrow keys (keyboard input) to control motion on the printer?
              peter247undefined droftartsundefined 2 Replies Last reply Reply Quote 0
              • peter247undefined
                peter247 @tracar
                @tracar
                Sounds like something hasn't made the upgrade to 3.1 fully , so when you downgrade it back to version 2 you get it working .
                When I upgraded the firmware I first made a copy of my SD and put it on a new SD card so I could go back to the same configurations.
                If you keep swapping between the versions with different config files , you may be forgetting to change a setting.
                an the web interface be set up with keyboard commands, such as up , down , left , right arrow keys ?
                No idea , it need some sort of key mapping .
                  droftarts administrators @tracar
                  @tracar Can you post the probe section of your RRF2 config.g? And I know you have confirmed the wiring, but could you post a picture of your Duet with the wiring connected so we can check? When you are moving between RRF2 and RRF3, are you changing all the files (homing and deployprobe etc) or just config.g? Or just using separate SD cards?
                  • tracarundefined
                    tracar @droftarts
                    M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                    M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
                    M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                    G31 P500 X0 Y40.9 Z.445 ; set Z probe trigger value, offset and trigger height
                    M557 X50:400 Y50:400 S100 ; define mesh grid x50:400 starts at 50, ends at 400 SXX moves by what its set to between points
                      @tracar Wiring looks very nice! The only thing I would say is that it would be better to route the endstop and probe wiring further away from the ribbon cable. There have been instances, mainly with the Duex expansion boards, when cables are run over or along the ribbon cable (which is unshielded), it can pick up interference, particularly if you are using Normally Open endstops. The interference is often on the SPI bus, and causes issues with the Duet and Duex communications. I don't know if this issue may effect the driver expansion board too, but it can't hurt moving the wires away from the ribbon cable. I don't know of any change between RRF2 and 3 that may increase the chances of interference; I think it's more likely a configuration issue.
                      The probe config you posted is still RRF3 (the pins are defined), not the working RRF2 config.
                      • tracarundefined
                        tracar @droftarts
                        @droftarts
                        this z probe is what i currently have working in the printer right now . and it fully works with the bl touch.
                        the signal cables are all shielded, and when i get my 4ch optoisolator the machine will be updated to N/O endstops. and again all shielded cables. but for now they are not physically screwed to the machine for an earth ground till later, after its rebuilt and squared off. the wiring you see is temporary till i get everything installed and working, then everything will be shortend and , as you say some seperation of wires.
                          @tracar Okay, if this is the code running with RRF2, then please send M98 Pconfig.g and I think you'll see errors. M950 is only supported by RRF3, same with the C parameter in M558. Could you please send M558 and post the response?
                          What is the probe deploy command (M280) in your working RRF2 deployprobe.g? Is it M280 P7 S10 I1? If it is, for RRF3, try inverting the heater 7 output in M950, ie
                          M950 S0 C"!exp.heater7" ; create servo pin 0 for BLTouch
                          tracarundefined 3 Replies Last reply Reply Quote 0
                          • tracarundefined
                            tracar
                            will test 7 hours from now when i get back from work.
                            • tracarundefined
                              tracar @droftarts
                              @droftarts
                              M98 PCONFIG.G
                              HTTP is enabled on port 80
                              FTP is disabled
                              TELNET is disabled
                              Warning: M950 command is not supported
                              M558
                              Z Probe type 9, input 0, invert no, dive height 5.0mm, probe speed 120mm/min, travel speed 6000mm/min, recovery time 0.00 sec, heaters normal, max taps 1, max diff 0.03
                              M122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                              Board ID: 08DLM-996RU-N8PS4-7J9D4-3S86R-KAA3N
                              Used output buffers: 1 of 24 (9 max)
                              currently on the sd card:
                              i would have to update to 3xx to test anything else
                              • tracarundefined
                                tracar @droftarts
                                @droftarts said in hbot homes correctly but prints mirrored ,:
                                current:
                                M280 P7 S10 :deploy bltouch
                                M280 P7 S90 I1 ;retract pin
                                also works the same as :
                                M280 P7 S90 ;retract pin without I1
                                and with : instead of ; normal?
                                • tracarundefined
                                  tracar
                                  i have printing working as it should, on 2XX
                                  still can not get dual independant z working with bltouch.
                                  • tracarundefined
                                    tracar @droftarts
                                    @droftarts
                                    with it on 3.11
                                    and the servo inverted - M950 S0 C"!exp.heater7" ; create servo pin 0 for BLTouch
                                    i get the pin to extend with m401. it will retract with m402
                                    ;Alarm Release + Pin UP
                                    M280 P7 S160
                                    changed to?
                                    ; Proberetract.g
                                    M280 P7 S90
                                    change to M402
                                    ; probedeploy.g
                                    M280 P7 S10
                                    change to M401
                                    • tracarundefined
                                      tracar
                                      figgerd it out must all be P0
                                        Phaedrux Moderator @tracar
                                        @tracar said in hbot homes correctly but prints mirrored ,:
                                        The M950 creates a servo number defined by S. So S0 in your case. The M280 P value must correspond to the same servo index number you want to control. So in your case P0.
                                        • tracarundefined
                                          tracar @Phaedrux
                                          @Phaedrux
                                          im happy,, only 1 item left
                                          how to configure this as i use external stepper drivers
                                          mine: M584 X6 Y5 Z7:8 U8 E3
                                          M574 X1 S1 P"!xstop" ; configure active-low endstop for high end on X via pin xstop
                                          M574 Y2 S1 P"!ystop" ; configure active-low endstop for high end on Y via pin ystop
                                          M574 Z1 S1 P"!zstop" ; configure active-low endstop for low end on Z via pin zstop
                                          need to change:
                                          M574 Z1 S1 P"zstop+????" ; configure active-high endstops for low end on Z via pins zstop and Ustop
                                          im on 3.11 want to make independant z and u homeing with each theit own endstop
                                          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Aug 30 2020 09:00:14 GMT-0600 (Mountain Daylight Time)
                                          M550 P"Duet2" ; set printer name
                                          M669 K1 ; select CoreXY mode
                                          M552 S1 ; enable network
                                          M586 P0 S1 ; enable HTTP
                                          M586 P1 S0 ; disable FTP
                                          M586 P2 S0 ; disable Telnet
                                          M569 P5 S1 T5 R1 ; physical drive x goes forwards
                                          M569 P6 S1 T5 R1 ; physical drive y goes forwards
                                          M569 P7 S1 T5 R1 ; physical drive z goes forwards
                                          M569 P8 S1 T5 R1 ; physical drive U goes forwards
                                          M569 P3 S1 ; physical drive extruder goes forwards
                                          M584 X6 Y5 Z7:8 U8 E3 ; set drive mapping
                                          M671 X-50:490 Y330:330 S5 ; x leadscrew position left to right from o,o on y axis , S5 means can adjust up to 5 mm
                                          M350 X16 Y16 Z16 U16 E16 I1 ; configure micro stepping with interpolation
                                          M92 X200.00 Y200.00 Z800.00 U800.00 E138.23 ; set steps per mm
                                          M566 X200.00 Y200.00 Z12.00 U12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                                          M203 X25000.00 Y25000.00 Z1000.00 U1000.00 E2400.00 ; set maximum speeds (mm/min)
                                          M201 X400.00 Y400.00 Z20.00 U20.00 E400.00 ; set accelerations (mm/s^2)
                                          M906 X300 Y300 Z300 U300 E800 I30 ; set motor currents (mA)
                                          M84 S30 ; Set idle timeout
                                          M208 X0 Y0 Z0 U0 S1 ; set axis minima
                                          M208 X440 Y535 Z900 U900 S0 ; set axis maxima
                                          ;M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
                                          M558 P9 C"^zprobe.in" H5 F120 T24000 ; set Z probe type to bltouch and the dive height + speeds
                                          G31 P500 X0 Y0 Z0.445 ; set Z probe trigger value, offset and trigger height
                                          M557 X70:400 Y180:500 S100 ; define mesh grid
                                          M563 P0 S"swiss" D0 H1 F0 ; define tool 0
                                            Well what endstop are you using for U? e0stop? e1stop? Those are really your only options unless using a duex.
