    RRF 2.03 pressure advance causes 20% overextrusion
    Firmware installation
    15
    116
    6.0k
    • jschallundefined
      jschall @bot
      @bot tried reducing the resolution of the STL to about 0.5mm and it still totally overextrudes, but turning it down in the slicer seemed to work better... weird.
      I am out for the weekend now, so no more experiments for a while.
      Need to grok the code. Sounds like it needs some low level improvements on top of any improvements to pressure advance, based on what @Edgars-Batna is saying.
      Funny, I just quit my software job, was hoping it was forever. Didn't even last a day.
      • Vetiundefined
        Veti
        @jschall said in RRF 2.03 pressure advance causes 20% overextrusion:
        this isnt a job, this is fun.
        • jmjcokeundefined
          jmjcoke
          This is a good resource for the resolution setting.
          https://youtu.be/Hvw3DrVAeTA
          Joshua Coke
          Trick Laser Metal Max with Smart Effector
          Duet Wifi
          Zesty Nimble
          Mosaic Pallette+
          At work
          Renishaw AM250/400/ RenAM500M/500Q Powder Bed Fusion (Metal 3D Printers)
          • CCS86undefined
            CCS86 @jschall
            With no pressure advance: https://drive.google.com/file/d/1oFvrJnxZc6fvLlGZqTdCqO7GB4Zfzdy_/view?usp=sharing
            Python script output:
            fwd_count 1942964
            rev_count 961423
            net_count 981541
            mm 2484.913924
            2.48m, dead on what the slicer expected.
            Proof positive that PA causes overextrusion and that this is a firmware bug, NOT a mechanical or configuration issue.
            Very nice find!
            I started a thread recently to brainstorm further PA improvement ideas. Over-extrusion was one of my issues. I am running RRF 3.1.1.
            https://forum.duet3d.com/topic/17752/pressure-advance-discussion-for-improvement-in-bowden-printers?_=1598756015603
            • jschallundefined
              jschall
              Probably going to focus my efforts mostly on scrapping bowden and going to direct...
              It is just too painful to deal with.
              • Edgars Batnaundefined
                Edgars Batna @jschall
                @Edgars-Batna That's why I went to the logic analyzer, because I knew it would just be constantly dismissed as a mechanical issue if I didn't remove everything mechanical from the equation.
                Forgot to mention that my observations also indicated that there's not enough CPU to keep up with tiny moves + PA on the Duet 2. This was also why I stopped debugging.
                As for using Bowden, yeah, sort of "forget it". BUT, this issue is not limited to Bowden. As far as I could tell there is no way to completely avoid the issue, but resolution (and in turn the CPU usage) makes it worse.
                It is possible that some trivial printers out there sort of work, but, the same way as my prints were dismissed as "not real", I'll just pretend those people don't exist either.
                  DC42 has added this to the list to investigate.
                    dc42 administrators @Phaedrux
                    @Phaedrux said in RRF 2.03 pressure advance causes 20% overextrusion:
                    I am waiting for the results from @jschall on RRF 3.1.1.
                    • jschallundefined
                      jschall
                      Oh man, this update process is not working...
                      There just aren't clear instructions anywhere...
                      So, I've uploaded Duet2and3Firmware-3.0.zip, and clicked yes when it asked if I want to update. It complained about missing iap4e.bin, but it updated the web control to be very pretty. I searched around for any clear documentation, didn't find any, and assumed that I needed to rename Duet2CombinedIAP.bin to iap4e.bin and upload it. I did that.
                      Now I still have a very pretty web control, but it just won't update the firmware to 3.0. No error messages whatsoever. What is the actual process to do this?
                      • jschallundefined
                        jschall
                        Duet Web Control 2.0.4
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later + DueX5
                        WiFi firmware version 1.23
                        • jschallundefined
                          jschall
                          Got it. Had to find iap4e.bin from a really old firmware release. Had to find out about this by googling a forum post. I'm sorry, but what the heck? Why not document this in the release notes, or just put the file in the release bundle? Jeez, that's really bad.
                            dc42 administrators @jschall
                            It is in the release bundle. iap4e.bin is included in the .zip file updates for RRF 2.05.1, 2.05, 2.04, and some earlier releases.
                            jschallundefined 1 Reply Last reply Reply Quote 0
                            • jschallundefined
                              jschall @dc42
                              @dc42 said in RRF 2.03 pressure advance causes 20% overextrusion:
                              It is not in Duet2and3Firmware-3.0.zip
                                Phaedrux Moderator @Phaedrux
                                Update to 2.05.1 to get on recent code.
                                Post your config.g.
                                I did suggest you update to 2.05.1 first.
                                The issue of missing IAP files does come up and should be better addressed in the documentation. I'll see what I can do about that.
                                • jschallundefined
                                  jschall
                                  Currently running the test on RRF3.1.1. It is with x16 microstepping+interpolation, but I'll do a new control test with no PA as well.
                                  • jschallundefined
                                    jschall
                                    Where the heck in the code are the reverse pins written?
                                    Also my logic analyzer keeps failing.
                                    • jschallundefined
                                      jschall @jschall
                                      Found it.
                                      • jschallundefined
                                        jschall
                                        Got the logic analyzer to work... It is very picky about USB ports.
                                        fwd_count 10734771
                                        rev_count 8650049
                                        net_count 2084722
                                        mm 2638.888608
                                        3 changes on this one:
                                        • RRF 3.1.1, prior tests were at 2.03
                                        • x16 microstepping, prior tests were at x8
                                        • 100% speed, prior tests were at 200% speed
                                        • Unplugged the extruder stepper and plugged in an identical stepper so I wouldn't have to listen to the gears make noise.
                                        File is supposed to be 2545.00 mm + 15mm of priming, so this print was within 3% - pretty decent, but there's still a bug.
                                        I am reverting the speed change and testing, and then I'll revert the microstepping change if it doesn't go back up to nasty overextrusion.
                                        • jschallundefined
                                          jschall
                                          Just a thought, for a next generation path following algorithm, what I would do is:
                                          1. Segment the toolpath into linestrings in which the angles between the lines are less than some threshold (such as 30 degrees)
                                          2. Smooth those segments, using maybe a series of cubic splines (long lines may need to be split up into shorter lines first).
                                          3. Compute the speed curve along the segment such that tangential and radial acceleration is limited and such that the extruder can keep up with pressure advance. Each segment starts at zero speed and pressure and ends at zero speed and pressure.
                                          "Jerk" (bad choice of term) becomes unnecessary. Corners below the angle threshold are rounded smoothly, without ringing or asymmetry. The printer will come to a brief stop at sharp corners above the angle threshold, thus making them as sharp as possible.
                                          A lot of this could be done (and may have to be done) in a preprocessing step.
                                          dc42undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 1
                                          • jschallundefined
                                            jschall
                                            RRF 3.1.1, 200% speed, x16 microstepping, 1.0 PA:
                                            fwd_count 12180087
                                            rev_count 10084959
                                            net_count 2095128
                                            mm 2652.060759
