    RRF 2.03 pressure advance causes 20% overextrusion
    Firmware installation
    15
    116
    6.5k
    • jschallundefined
      jschall
      Probably going to focus my efforts mostly on scrapping bowden and going to direct...
      It is just too painful to deal with.
      • Edgars Batnaundefined
        Edgars Batna @jschall
        @jschall said in RRF 2.03 pressure advance causes 20% overextrusion:
        @Edgars-Batna That's why I went to the logic analyzer, because I knew it would just be constantly dismissed as a mechanical issue if I didn't remove everything mechanical from the equation.
        Forgot to mention that my observations also indicated that there's not enough CPU to keep up with tiny moves + PA on the Duet 2. This was also why I stopped debugging.
        As for using Bowden, yeah, sort of "forget it". BUT, this issue is not limited to Bowden. As far as I could tell there is no way to completely avoid the issue, but resolution (and in turn the CPU usage) makes it worse.
        It is possible that some trivial printers out there sort of work, but, the same way as my prints were dismissed as "not real", I'll just pretend those people don't exist either.
          DC42 has added this to the list to investigate.
            dc42 administrators @Phaedrux
            @Phaedrux said in RRF 2.03 pressure advance causes 20% overextrusion:
            I am waiting for the results from @jschall on RRF 3.1.1.
            • jschallundefined
              jschall
              Oh man, this update process is not working...
              There just aren't clear instructions anywhere...
              So, I've uploaded Duet2and3Firmware-3.0.zip, and clicked yes when it asked if I want to update. It complained about missing iap4e.bin, but it updated the web control to be very pretty. I searched around for any clear documentation, didn't find any, and assumed that I needed to rename Duet2CombinedIAP.bin to iap4e.bin and upload it. I did that.
              Now I still have a very pretty web control, but it just won't update the firmware to 3.0. No error messages whatsoever. What is the actual process to do this?
              • jschallundefined
                jschall
                Duet Web Control 2.0.4
                RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later + DueX5
                WiFi firmware version 1.23
                • jschallundefined
                  jschall
                  Got it. Had to find iap4e.bin from a really old firmware release. Had to find out about this by googling a forum post. I'm sorry, but what the heck? Why not document this in the release notes, or just put the file in the release bundle? Jeez, that's really bad.
                    dc42 administrators @jschall
                    It is in the release bundle. iap4e.bin is included in the .zip file updates for RRF 2.05.1, 2.05, 2.04, and some earlier releases.
                    jschallundefined 1 Reply Last reply Reply Quote 0
                    • jschallundefined
                      jschall @dc42
                      @dc42 said in RRF 2.03 pressure advance causes 20% overextrusion:
                      It is not in Duet2and3Firmware-3.0.zip
                        Phaedrux Moderator @Phaedrux
                        Update to 2.05.1 to get on recent code.
                        Post your config.g.
                        I did suggest you update to 2.05.1 first.
                        The issue of missing IAP files does come up and should be better addressed in the documentation. I'll see what I can do about that.
                        • jschallundefined
                          jschall
                          Currently running the test on RRF3.1.1. It is with x16 microstepping+interpolation, but I'll do a new control test with no PA as well.
                          • jschallundefined
                            jschall
                            Where the heck in the code are the reverse pins written?
                            Also my logic analyzer keeps failing.
                            • jschallundefined
                              jschall @jschall
                              Found it.
                              • jschallundefined
                                jschall
                                Got the logic analyzer to work... It is very picky about USB ports.
                                fwd_count 10734771
                                rev_count 8650049
                                net_count 2084722
                                mm 2638.888608
                                3 changes on this one:
                                • RRF 3.1.1, prior tests were at 2.03
                                • x16 microstepping, prior tests were at x8
                                • 100% speed, prior tests were at 200% speed
                                • Unplugged the extruder stepper and plugged in an identical stepper so I wouldn't have to listen to the gears make noise.
                                File is supposed to be 2545.00 mm + 15mm of priming, so this print was within 3% - pretty decent, but there's still a bug.
                                I am reverting the speed change and testing, and then I'll revert the microstepping change if it doesn't go back up to nasty overextrusion.
                                • jschallundefined
                                  jschall
                                  Just a thought, for a next generation path following algorithm, what I would do is:
                                  1. Segment the toolpath into linestrings in which the angles between the lines are less than some threshold (such as 30 degrees)
                                  2. Smooth those segments, using maybe a series of cubic splines (long lines may need to be split up into shorter lines first).
                                  3. Compute the speed curve along the segment such that tangential and radial acceleration is limited and such that the extruder can keep up with pressure advance. Each segment starts at zero speed and pressure and ends at zero speed and pressure.
                                  "Jerk" (bad choice of term) becomes unnecessary. Corners below the angle threshold are rounded smoothly, without ringing or asymmetry. The printer will come to a brief stop at sharp corners above the angle threshold, thus making them as sharp as possible.
                                  A lot of this could be done (and may have to be done) in a preprocessing step.
                                  dc42undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 1
                                  • jschallundefined
                                    jschall
                                    RRF 3.1.1, 200% speed, x16 microstepping, 1.0 PA:
                                    fwd_count 12180087
                                    rev_count 10084959
                                    net_count 2095128
                                    mm 2652.060759
                                    • jschallundefined
                                      jschall
                                      Starting test: RRF 3.1.1, 200% speed, x8 microstepping, 1.0 PA
                                      This one should be apples-to-apples to the tests on RRF 2.03.
                                      • jschallundefined
                                        jschall
                                        fwd_count 6073637
                                        rev_count 5024835
                                        net_count 1048802
                                        mm 2655.194937
                                        So this is not terribly huge overextrusion, I could try printing with this. There's still a bug.
                                          That's similar to what I have planned. A disadvantage is that the existing effect whereby the perimeters of holes are always under-sized would be made a little worse.
                                            T3P3Tony administrators @jschall
                                            it will be interesting to see if PA can compensate for the large blob seen when stopping briefly at corners. Currently sharp corners are slightly rounded because the printer does not come to a complete stop - but they are smooth, where as when the print hed has to be raised (e.g. to the next z level, there is a visible Z "seam".
                                            Maybe this is better off combined with jerk for angles > than the smoothing process works on.
