Duet 3 Disconnects from SBC
Firmware installation
1.5k
    mrenz999
    During printing my SBC says randomly "Network error, not connected" Then shuts down the print I have running. Not sure what is causing this.
      Please provide the results of M122 after this occurs.
      And setup some debug monitoring to capture more information.
      https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Monitoring_optional
      undefined 1 Reply Last reply 4 Sept 2020, 03:55 Reply Quote 0
        mrenz999 @Phaedrux
        @Phaedrux Warning: Lost connection to Duet (Board is not available (no data response))
        Warning: Controller has been reset
        Just happened. Will do M112 as well.
          M122 is diagnostics
          M112 is reset
          undefined 1 Reply Last reply 4 Sept 2020, 04:17 Reply Quote 0
            mrenz999 @Phaedrux
            @Phaedrux Opps typo lol
            m122
            RepRapFirmware for Duet 3 MB6HC version 3.01-RC9 running on Duet 3 MB6HC v1.01 or later
            Board ID: 08DJM-956L2-G43S8-6J1FA-3SJ6P-1B06GUsed output buffers: 1 of 40 (10 max)
            Static ram: 154572
            Dynamic ram: 162084 of which 20 recycled
            Exception stack ram used: 216
            Never used ram: 76324
            Tasks: NETWORK(ready,2076) HEAT(blocked,1196) CanReceiv(suspended,3824) CanSender(suspended,1484) CanClock(blocked,1432) TMC(blocked,216) MAIN(running,4652) IDLE(ready,80)
            Owned mutexes:
            Last reset 00:17:17 ago, cause: software
            Last software reset at 2020-09-04 04:59, reason: User, spinning module LinuxInterface, available RAM 75604 bytes (slot 1)
            Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
            Error status: 0
            Free file entries: 10
            MCU temperature: min 42.0, current 42.3, max 43.7
            Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
            12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
            Driver 0: standstill, reads 28510, writes 14 timeouts 0, SG min/max 0/0
            Driver 1: standstill, reads 28510, writes 14 timeouts 0, SG min/max 0/0
            Driver 2: standstill, reads 28511, writes 14 timeouts 0, SG min/max 0/0
            Driver 3: standstill, reads 28511, writes 14 timeouts 0, SG min/max 0/0
            Driver 4: standstill, reads 28512, writes 14 timeouts 0, SG min/max 0/0
            Driver 5: standstill, reads 28512, writes 14 timeouts 0, SG min/max 0/0
            Date/time: 2020-09-04 05:16:59
            Slowest loop: 3.68ms; fastest: 0.14ms
            === MainDDARing ===
            Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
            === AuxDDARing ===
            Heater 1 is on, I-accum = 0.0
            Segments left: 0
            Movement lock held by null
            HTTP* is ready with "M122" in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is assembling a command in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon* is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 2.08ms; fastest: 0.01ms
            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
            HTTP sessions: 0 of 8
            • Ethernet -
              State: disabled
              Error counts: 0 0 0 0 0
              === CAN ===
              Messages sent 53, longest wait 0ms for type 0
              === Linux interface ===
              State: 0, failed transfers: 0
              Last transfer: 16ms ago
              RX/TX seq numbers: 436/438
              SPI underruns 0, overruns 0
              Number of disconnects: 1
              Buffer RX/TX: 0/0-0
              === Duet Control Server ===
              Duet Control Server v3.1.1
              Trigger:
              Finishing macro config.g, started by system
            Next stack level
            Code buffer space: 4096
            Full transfers per second: 30.67
            undefined 1 Reply Last reply 4 Sept 2020, 04:26 Reply Quote 0
              mrenz999 @mrenz999
              @Phaedrux
              Started the print again with same results. Then ran M122
              again
              9/3/2020, 9:23:58 PM Leadscrew adjustments made: 0.273 0.190 0.300, points used 3, (mean, deviation) before (0.254, 0.047) after (0.000, 0.000)
              9/3/2020, 9:23:46 PM m122
              Board ID: 08DJM-956L2-G43S8-6J1FA-3SJ6P-1B06GUsed output buffers: 1 of 40 (13 max)
              Static ram: 154572
              Dynamic ram: 162708 of which 20 recycled
              Exception stack ram used: 424
              Never used ram: 75492
              Tasks: NETWORK(ready,2076) HEAT(blocked,1184) CanReceiv(suspended,3824) CanSender(suspended,1432) CanClock(blocked,1432) TMC(blocked,80) MAIN(running,4436) IDLE(ready,80)
              Owned mutexes:
              Last reset 00:24:07 ago, cause: software
              Error status: 0
              MCU temperature: min 42.3, current 42.8, max 42.9
              Supply voltage: min 23.0, current 23.7, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: ok, reads 62668, writes 3 timeouts 0, SG min/max 0/215
              Driver 1: ok, reads 62668, writes 3 timeouts 0, SG min/max 0/142
              Driver 2: standstill, reads 62668, writes 3 timeouts 0, SG min/max 0/88
              Driver 3: standstill, reads 62669, writes 3 timeouts 0, SG min/max 0/90
              Driver 4: standstill, reads 62668, writes 3 timeouts 0, SG min/max 0/93
              Driver 5: standstill, reads 62672, writes 0 timeouts 0, SG min/max not available
              Date/time: 2020-09-04 05:23:50
              Slowest loop: 4.72ms; fastest: 0.14ms
              Hiccups: 0(0), FreeDm: 373, MinFreeDm: 373, MaxWait: 1426733ms
              === MainDDARing ===
              Scheduled moves: 15, completed moves: 14, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3
              === AuxDDARing ===
              Heater 0 is on, I-accum = 0.4
              Heater 1 is on, I-accum = 0.6
              Segments left: 0
              Movement lock held by File
              File* is idle in state(s) 40 0 0, running macro
              === Network ===
              Slowest loop: 1.92ms; fastest: 0.01ms
              • Ethernet -
                State: disabled
                === CAN ===
                Messages sent 1644, longest wait 0ms for type 0
                Last transfer: 18ms ago
                RX/TX seq numbers: 13844/13846
                Buffer RX/TX: 0/0-0
                File:
                Finishing macro deployprobe.g, started by G30 P1 X20 Y365 Z-99999 ; probe near an adjusting screw
              Next stack level
              Executing macro bed.g, started by G32 ; bed compensation
              Suspended code: G30 P2 X430 Y240 Z-99999 S3 ; probe near an adjusting screw and calibrate 3 motors
              Suspended code: ;G29
              Suspended code: ;M402 ; retract probe
              Next stack level
              Executing macro start.g, started by system
              Suspended code: G28 ; home XYZ
              Suspended code: ;G29 S1 ; load heightmap
              Suspended code: ;M400
              Suspended code: ;G10 P0 R80 S235 ; Set extruder to 180 and release
              Suspended code: ;M98 P"0:/sys/ZSpeedsPrint.g" ; Load Z speeds for printing
              Suspended code: ;M98 P"0:/sys/CurrentsPrint.g" ; Load print motor currents
              Suspended code: ; Slicer Start Gcode begins.
              Next stack level
              Suspended code: T0
              Suspended code: M190 S70
              Suspended code: M104 S245
              Suspended code: M109 S245
              Suspended code: M82 ;absolute extrusion mode
              Suspended code: M83 ;relative extrusion mode
              Suspended code: G1 F1500 E-6.5
              Suspended code: ;LAYER_COUNT:51
              Suspended code: ;LAYER:0
              Suspended code: M107
              Suspended code: G0 F3600 X86.205 Y144.27 Z0.3
              Suspended code: ;TYPE:SKIRT
              Suspended code: G1 F1500 E6.5
              Suspended code: G1 F1800 X86.965 Y143.845 E0.03139
              Suspended code: G1 X88.334 Y143.116 E0.05591
              Suspended code: G1 X88.714 Y142.922 E0.01538
              Suspended code: G1 X89.867 Y142.356 E0.0463
              Suspended code: G1 X90.079 Y142.272 E0.00822
              Suspended code: G1 X91.185 Y141.751 E0.04407
              Suspended code: G1 X91.433 Y141.647 E0.00969
              Suspended code: G1 X92.556 Y141.229 E0.04319
              Suspended code: G1 X93.411 Y140.916 E0.03282
              Suspended code: G1 X94.083 Y140.698 E0.02547
              Suspended code: G1 X94.905 Y140.451 E0.03094
              Suspended code: G1 X95.523 Y140.28 E0.02311
              Suspended code: G1 X96.059 Y140.127 E0.02009
              Suspended code: G1 X96.74 Y139.945 E0.02541
              Suspended code: G1 X97.539 Y139.75 E0.02965
              Suspended code: G1 X97.766 Y139.701 E0.00837
              Suspended code: G1 X98.593 Y139.536 E0.0304
              Suspended code: G1 X98.654 Y139.529 E0.00221
              Suspended code: G1 X99.964 Y139.278 E0.04808
              Trigger:
              Next stack level
              Full transfers per second: 32.69
              File /opt/dsf/sd/gcodes/petgtriple-moon.gcode is selected, processing
              9/3/2020, 9:23:36 PM Connection to Duet established
              9/3/2020, 9:23:36 PM Warning: Lost connection to Duet (Board is not available (no data response))
                mrenz999
                9/3/2020, 10:36:20 PM m122
                Static ram: 154572
                Dynamic ram: 162500 of which 20 recycled
                Exception stack ram used: 528
                Never used ram: 75596
                Tasks: NETWORK(ready,2076) HEAT(blocked,1184) CanReceiv(suspended,3824) CanSender(suspended,1432) CanClock(blocked,1432) TMC(blocked,80) MAIN(running,2808) IDLE(ready,80)
                Owned mutexes:
                Last reset 00:57:28 ago, cause: software
                Last software reset at 2020-09-04 05:38, reason: User, spinning module LinuxInterface, available RAM 75388 bytes (slot 2)
                Error status: 0
                MCU temperature: min 43.7, current 43.8, max 46.6
                Supply voltage: min 23.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 0: standstill, reads 55532, writes 19 timeouts 0, SG min/max 0/216
                Driver 1: standstill, reads 55533, writes 19 timeouts 0, SG min/max 0/182
                Driver 2: standstill, reads 55533, writes 19 timeouts 0, SG min/max 0/117
                Driver 3: standstill, reads 55533, writes 19 timeouts 0, SG min/max 0/867
                Driver 4: standstill, reads 55534, writes 19 timeouts 0, SG min/max 0/107
                Driver 5: standstill, reads 55534, writes 19 timeouts 0, SG min/max 0/202
                Date/time: 2020-09-04 06:36:24
                Slowest loop: 4.66ms; fastest: 0.14ms
                Hiccups: 0(0), FreeDm: 375, MinFreeDm: 330, MaxWait: 29338ms
                === MainDDARing ===
                Scheduled moves: 0, completed moves: 3, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                === AuxDDARing ===
                Segments left: 0
                File* is idle in state(s) 0
                Queue* is idle in state(s) 0
                === Network ===
                • Ethernet -
                  State: disabled
                  === CAN ===
                  Messages sent 13776, longest wait 0ms for type 0
                  State: 0, failed transfers: 96
                  Last transfer: 19ms ago
                  RX/TX seq numbers: 46307/46300
                  SPI underruns 40, overruns 40
                  Buffer RX/TX: 0/0-0
                  Full transfers per second: 32.49
                  jay_s_uk
                  I would first suggest updating your firmware. You're still running 3.01-RC9
                    You're still on an old release candidate firmware. Please update to 3.1.1 your issue may already be solved.
                    undefined 1 Reply Last reply 4 Sept 2020, 15:25 Reply Quote 0
                      mrenz999 @Phaedrux
                      @Phaedrux So it should just require a sudo apt-get update ?
                        A Former User
                        as of 3.0.0 apt should just-work(tm) for upgrades (but expansion- or tool-boards needs to be upgraded by M997 until the scripts from the reprapfirmware package takes care of that)
                        undefined 1 Reply Last reply 4 Sept 2020, 16:05 Reply Quote 0
                          mrenz999 @A Former User
                          @bearer Hmmm. Well it updated the Pi but not the Duet 3. Is there something else I should be doing ?
                          ? 1 Reply Last reply 4 Sept 2020, 19:47 Reply Quote 0
                            mrenz999
                            Is there something else to do other than that sudo apt-get update and upgrade that needs to be done?
                              Some of the older firmware didn't update properly with the normal apr-get update method. In these cases you'd need to update the board firmware separately. Once you're at 3.1.1 it should "just work" going forward.
                              You should be able to update the board firmware by uploading the firmware zip file to the /sys folder in DWC just as you would normally with any other Duet.
                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
                              If that doesn't work, then you have the option of using Bossa to flash the firmware to the board over USB with a PC.
                              https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_main_board_firmware
                                A Former User @mrenz999
                                @mrenz999 said in Duet 3 Disconnects from SBC:
                                not really, but it'd be helpfull to see the output from apt as it would allude to why the firmware failed.
                                should be as simple as doing echo S997 | sudo /opt/dsf/bin/CodeConsole from ssh if the duet is communicating with the pi (if its not then thats why the upgrade failed, but afaik not been an issue after 3.0)
                                undefined 1 Reply Last reply 5 Sept 2020, 01:51 Reply Quote 0
                                  @bearer pi@duet3:~ $ echo S997 | sudo /opt/dsf/bin/CodeConsole
                                  Unhandled exception. System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requested address /var/run/dsf/dcs.sock
                                  at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
                                  at System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
                                  at DuetAPIClient.BaseConnection.Connect(ClientInitMessage initMessage, String socketPath, CancellationToken cancellationToken) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPIClient/BaseConnection.cs:line 98
                                  at CodeConsole.Program.Main(String[] args) in /home/christian/Duet3D/DuetSoftwareFramework/src/CodeConsole/Program.cs:line 44
                                  at CodeConsole.Program.<Main>(String[] args)
                                  Aborted
                                  This is the result of it.
                                  ? 1 Reply Last reply 5 Sept 2020, 05:27 Reply Quote 0
                                    Did you try uploading the Zip in DWC?
                                    undefined 2 Replies Last reply 5 Sept 2020, 02:23 Reply Quote 0
                                      mrenz999 @Phaedrux
                                      @Phaedrux I did download it. However, I am unable to connect to DWC now for some reason. It says Failed to connect to Duet3.local DCS not started. I hard power reset both, unplugged and left off for a few mins and replugged them in. Is there a way to do it through the pi ?
                                        If the pi is connected to the duet via usb you can use bossa to flash the duet. That may be a better option if it's too much hassle getting everything disconnected to get it to a PC to flash. But if you have a laptop or PC nearby that might be easier if you're not comfortable with the pi environment.
                                        undefined 2 Replies Last reply 5 Sept 2020, 03:28 Reply Quote 0
                                          mrenz999 @Phaedrux
                                          @Phaedrux I have a laptop. Do I need to disconnect everything from the board or just plug in and do it ?
                                          9 out of 32
