Unsolved Duet 3 Disconnects from SBC
Please provide the results of M122 after this occurs.
And setup some debug monitoring to capture more information.
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Monitoring_optional
@Phaedrux Warning: Lost connection to Duet (Board is not available (no data response))
Warning: Controller has been resetJust happened. Will do M112 as well.
M122 is diagnostics
M112 is reset
@Phaedrux Opps typo lol
m122
RepRapFirmware for Duet 3 MB6HC version 3.01-RC9 running on Duet 3 MB6HC v1.01 or later
Board ID: 08DJM-956L2-G43S8-6J1FA-3SJ6P-1B06GUsed output buffers: 1 of 40 (10 max)
Static ram: 154572
Dynamic ram: 162084 of which 20 recycled
Exception stack ram used: 216
Never used ram: 76324
Tasks: NETWORK(ready,2076) HEAT(blocked,1196) CanReceiv(suspended,3824) CanSender(suspended,1484) CanClock(blocked,1432) TMC(blocked,216) MAIN(running,4652) IDLE(ready,80)
Owned mutexes:
Last reset 00:17:17 ago, cause: software
Last software reset at 2020-09-04 04:59, reason: User, spinning module LinuxInterface, available RAM 75604 bytes (slot 1)
Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
Error status: 0
Free file entries: 10
MCU temperature: min 42.0, current 42.3, max 43.7
Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
Driver 0: standstill, reads 28510, writes 14 timeouts 0, SG min/max 0/0
Driver 1: standstill, reads 28510, writes 14 timeouts 0, SG min/max 0/0
Driver 2: standstill, reads 28511, writes 14 timeouts 0, SG min/max 0/0
Driver 3: standstill, reads 28511, writes 14 timeouts 0, SG min/max 0/0
Driver 4: standstill, reads 28512, writes 14 timeouts 0, SG min/max 0/0
Driver 5: standstill, reads 28512, writes 14 timeouts 0, SG min/max 0/0
Date/time: 2020-09-04 05:16:59
Slowest loop: 3.68ms; fastest: 0.14ms
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP* is ready with "M122" in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is assembling a command in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon* is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 2.08ms; fastest: 0.01ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
HTTP sessions: 0 of 8- Ethernet -
State: disabled
Error counts: 0 0 0 0 0
=== CAN ===
Messages sent 53, longest wait 0ms for type 0
=== Linux interface ===
State: 0, failed transfers: 0
Last transfer: 16ms ago
RX/TX seq numbers: 436/438
SPI underruns 0, overruns 0
Number of disconnects: 1
Buffer RX/TX: 0/0-0
=== Duet Control Server ===
Duet Control Server v3.1.1
Trigger:
Finishing macro config.g, started by system
Next stack level
Code buffer space: 4096
Full transfers per second: 30.67 - Ethernet -
@Phaedrux
Started the print again with same results. Then ran M122
again
9/3/2020, 9:23:58 PM Leadscrew adjustments made: 0.273 0.190 0.300, points used 3, (mean, deviation) before (0.254, 0.047) after (0.000, 0.000)
9/3/2020, 9:23:46 PM m122
Board ID: 08DJM-956L2-G43S8-6J1FA-3SJ6P-1B06GUsed output buffers: 1 of 40 (13 max)
Static ram: 154572
Dynamic ram: 162708 of which 20 recycled
Exception stack ram used: 424
Never used ram: 75492
Tasks: NETWORK(ready,2076) HEAT(blocked,1184) CanReceiv(suspended,3824) CanSender(suspended,1432) CanClock(blocked,1432) TMC(blocked,80) MAIN(running,4436) IDLE(ready,80)
Owned mutexes:
Last reset 00:24:07 ago, cause: software
Error status: 0
MCU temperature: min 42.3, current 42.8, max 42.9
Supply voltage: min 23.0, current 23.7, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: ok, reads 62668, writes 3 timeouts 0, SG min/max 0/215
Driver 1: ok, reads 62668, writes 3 timeouts 0, SG min/max 0/142
Driver 2: standstill, reads 62668, writes 3 timeouts 0, SG min/max 0/88
Driver 3: standstill, reads 62669, writes 3 timeouts 0, SG min/max 0/90
Driver 4: standstill, reads 62668, writes 3 timeouts 0, SG min/max 0/93
Driver 5: standstill, reads 62672, writes 0 timeouts 0, SG min/max not available
Date/time: 2020-09-04 05:23:50
Slowest loop: 4.72ms; fastest: 0.14ms
Hiccups: 0(0), FreeDm: 373, MinFreeDm: 373, MaxWait: 1426733ms
=== MainDDARing ===
Scheduled moves: 15, completed moves: 14, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3
=== AuxDDARing ===
Heater 0 is on, I-accum = 0.4
Heater 1 is on, I-accum = 0.6
Segments left: 0
Movement lock held by File
File* is idle in state(s) 40 0 0, running macro
=== Network ===
Slowest loop: 1.92ms; fastest: 0.01ms
State: disabled
=== CAN ===
Messages sent 1644, longest wait 0ms for type 0
Last transfer: 18ms ago
RX/TX seq numbers: 13844/13846
Buffer RX/TX: 0/0-0
File:
Finishing macro deployprobe.g, started by G30 P1 X20 Y365 Z-99999 ; probe near an adjusting screw
Next stack level
Executing macro bed.g, started by G32 ; bed compensation
Suspended code: G30 P2 X430 Y240 Z-99999 S3 ; probe near an adjusting screw and calibrate 3 motors
Suspended code: ;G29
Suspended code: ;M402 ; retract probe
Next stack level
Executing macro start.g, started by system
Suspended code: G28 ; home XYZ
Suspended code: ;G29 S1 ; load heightmap
Suspended code: ;M400
Suspended code: ;G10 P0 R80 S235 ; Set extruder to 180 and release
Suspended code: ;M98 P"0:/sys/ZSpeedsPrint.g" ; Load Z speeds for printing
Suspended code: ;M98 P"0:/sys/CurrentsPrint.g" ; Load print motor currents
Suspended code: ; Slicer Start Gcode begins.
Next stack level
Suspended code: T0
Suspended code: M190 S70
Suspended code: M104 S245
Suspended code: M109 S245
Suspended code: M82 ;absolute extrusion mode
Suspended code: M83 ;relative extrusion mode
Suspended code: G1 F1500 E-6.5
Suspended code: ;LAYER_COUNT:51
Suspended code: ;LAYER:0
Suspended code: M107
Suspended code: G0 F3600 X86.205 Y144.27 Z0.3
Suspended code: ;TYPE:SKIRT
Suspended code: G1 F1500 E6.5
Suspended code: G1 F1800 X86.965 Y143.845 E0.03139
Suspended code: G1 X88.334 Y143.116 E0.05591
Suspended code: G1 X88.714 Y142.922 E0.01538
Suspended code: G1 X89.867 Y142.356 E0.0463
Suspended code: G1 X90.079 Y142.272 E0.00822
Suspended code: G1 X91.185 Y141.751 E0.04407
Suspended code: G1 X91.433 Y141.647 E0.00969
Suspended code: G1 X92.556 Y141.229 E0.04319
Suspended code: G1 X93.411 Y140.916 E0.03282
Suspended code: G1 X94.083 Y140.698 E0.02547
Suspended code: G1 X94.905 Y140.451 E0.03094
Suspended code: G1 X95.523 Y140.28 E0.02311
Suspended code: G1 X96.059 Y140.127 E0.02009
Suspended code: G1 X96.74 Y139.945 E0.02541
Suspended code: G1 X97.539 Y139.75 E0.02965
Suspended code: G1 X97.766 Y139.701 E0.00837
Suspended code: G1 X98.593 Y139.536 E0.0304
Suspended code: G1 X98.654 Y139.529 E0.00221
Suspended code: G1 X99.964 Y139.278 E0.04808
Trigger:
Next stack level
Full transfers per second: 32.69
File /opt/dsf/sd/gcodes/petgtriple-moon.gcode is selected, processing
9/3/2020, 9:23:36 PM Connection to Duet established
9/3/2020, 9:23:36 PM Warning: Lost connection to Duet (Board is not available (no data response)) - Ethernet -
9/3/2020, 10:36:20 PM m122
Static ram: 154572
Dynamic ram: 162500 of which 20 recycled
Exception stack ram used: 528
Never used ram: 75596
Tasks: NETWORK(ready,2076) HEAT(blocked,1184) CanReceiv(suspended,3824) CanSender(suspended,1432) CanClock(blocked,1432) TMC(blocked,80) MAIN(running,2808) IDLE(ready,80)
Owned mutexes:
Last reset 00:57:28 ago, cause: software
Last software reset at 2020-09-04 05:38, reason: User, spinning module LinuxInterface, available RAM 75388 bytes (slot 2)
Error status: 0
MCU temperature: min 43.7, current 43.8, max 46.6
Supply voltage: min 23.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: standstill, reads 55532, writes 19 timeouts 0, SG min/max 0/216
Driver 1: standstill, reads 55533, writes 19 timeouts 0, SG min/max 0/182
Driver 2: standstill, reads 55533, writes 19 timeouts 0, SG min/max 0/117
Driver 3: standstill, reads 55533, writes 19 timeouts 0, SG min/max 0/867
Driver 4: standstill, reads 55534, writes 19 timeouts 0, SG min/max 0/107
Driver 5: standstill, reads 55534, writes 19 timeouts 0, SG min/max 0/202
Date/time: 2020-09-04 06:36:24
Slowest loop: 4.66ms; fastest: 0.14ms
Hiccups: 0(0), FreeDm: 375, MinFreeDm: 330, MaxWait: 29338ms
=== MainDDARing ===
Scheduled moves: 0, completed moves: 3, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Segments left: 0
File* is idle in state(s) 0
Queue* is idle in state(s) 0
=== Network ===
State: disabled
=== CAN ===
Messages sent 13776, longest wait 0ms for type 0
State: 0, failed transfers: 96
Last transfer: 19ms ago
RX/TX seq numbers: 46307/46300
SPI underruns 40, overruns 40
Buffer RX/TX: 0/0-0
Full transfers per second: 32.49
- Ethernet -
I would first suggest updating your firmware. You're still running 3.01-RC9
You're still on an old release candidate firmware. Please update to 3.1.1 your issue may already be solved.
@Phaedrux So it should just require a sudo apt-get update ?
as of 3.0.0 apt should just-work(tm) for upgrades (but expansion- or tool-boards needs to be upgraded by M997 until the scripts from the reprapfirmware package takes care of that)
@bearer Hmmm. Well it updated the Pi but not the Duet 3. Is there something else I should be doing ?
Is there something else to do other than that sudo apt-get update and upgrade that needs to be done?
Some of the older firmware didn't update properly with the normal apr-get update method. In these cases you'd need to update the board firmware separately. Once you're at 3.1.1 it should "just work" going forward.
You should be able to update the board firmware by uploading the firmware zip file to the /sys folder in DWC just as you would normally with any other Duet.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
If that doesn't work, then you have the option of using Bossa to flash the firmware to the board over USB with a PC.
@mrenz999 said in Duet 3 Disconnects from SBC:
not really, but it'd be helpfull to see the output from apt as it would allude to why the firmware failed.
should be as simple as doing
echo S997 | sudo /opt/dsf/bin/CodeConsole
from ssh if the duet is communicating with the pi (if its not then thats why the upgrade failed, but afaik not been an issue after 3.0) -
@bearer pi@duet3:~ $ echo S997 | sudo /opt/dsf/bin/CodeConsole
Unhandled exception. System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requested address /var/run/dsf/dcs.sock
at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
at DuetAPIClient.BaseConnection.Connect(ClientInitMessage initMessage, String socketPath, CancellationToken cancellationToken) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPIClient/BaseConnection.cs:line 98
at CodeConsole.Program.Main(String[] args) in /home/christian/Duet3D/DuetSoftwareFramework/src/CodeConsole/Program.cs:line 44
at CodeConsole.Program.<Main>(String[] args)
Aborted
This is the result of it. -
Did you try uploading the Zip in DWC?
@Phaedrux I did download it. However, I am unable to connect to DWC now for some reason. It says Failed to connect to Duet3.local DCS not started. I hard power reset both, unplugged and left off for a few mins and replugged them in. Is there a way to do it through the pi ?
If the pi is connected to the duet via usb you can use bossa to flash the duet. That may be a better option if it's too much hassle getting everything disconnected to get it to a PC to flash. But if you have a laptop or PC nearby that might be easier if you're not comfortable with the pi environment.
@Phaedrux I have a laptop. Do I need to disconnect everything from the board or just plug in and do it ?
@Phaedrux Verify failed
Page errors: 1115
Byte errors: 564485
This was the response when I used BOSSA through the pi
