    Duet 2 Ethernet and SBC
    Beta Firmware
    29
    302
    34.0k
    • smoki3undefined
      smoki3 @A Former User
      @bearer then I already get a lot of errors while booting, because the drivers are missing
      • wilrikerundefined
        wilriker @smoki3
        @smoki3 Don't worry about your wiring. It most likely is a firmware issue. Unfortunately I did not have any time since the last time I wrote here to look into that.
        Manuel
        My Tool Collection
        Baenwortundefined 1 Reply Last reply Reply Quote 0
        • Baenwortundefined
          Baenwort @wilriker
          So when this works for the Ethernet model would it be possible to run spaghetti detective?
          Also, for the D2E, would this offloading to the SBC enable smoother segments on Delta's using mesh compensation?
            A Former User @Baenwort
            @Baenwort said in Duet 2 Ethernet and SBC:
            Presumably you'd need to pause the Duet either by triggering on a input pin or sending g-code to pause - as such how the SBC is connected doesn't really matter much except you can use echo M25 | sudo CodeConsole rather than say curl ..blah blah.. or echo M25 > /dev/ttyAMC0 which might require a little setup and flushing of the usb serial first?
            As for smoother I can't say I'm authority on it, but unless the bottleneck was reading g-code from the SD card moving to a SBC isn't going to improve the handling as the realtime motion planning from the g-code is still done on the Duet.
            • Baenwortundefined
              Baenwort @A Former User
              @bearer the spaghetti detective bit was because with a SBC to act as the plugin host it would be potentially easier to port the octoprint plugin.
              The comment about smoothness is because I was told once that because of the complexity of the Delta math that on Duet 2 if you enabled mesh bed compensation that it no longer calculated every point to move but fell back on arcs and segments like ordinary RAMPS. But if a SBC offloads some work from the duet I wondered if more could be calculated with the now freed up resources.
              It presumes that the DWC takes up some amount of resources to run on the Duet processor.
              • deadwood83undefined
                deadwood83
                OK, here's my thinking on an easy way to connect SBC regardless of ethernet or wifi version.
                The header on the side is a 2.54mm, could accept female or male, protrudes past the board edge and sits forward and next to the paneldue header. The adapter is soldered to the bottom in the same manner the ESP is attached to the top. It could also be mounted with pins through it.
                Hole for plastic push-fitting to reinforce.
                Relief is left for up to a 7mm diameter fastening post around the board mounting screw. Resistors are 470-Ohm.
                Anything I am missing?
                  A Former User @deadwood83
                  @deadwood83 said in Duet 2 Ethernet and SBC:
                  maybe some pull downs to the reset/enable lines to ensure no interference (unless rff 3.2 handles that in firmware) could be jumpered for flexibility i guess.
                    deadwood83
                    @bearer I think it would be much less intrusive to figure out a way to pull PE4 and PE5 low in firmware.
                    I poked around in the Duet3 designs and I see that someone (Tony?) had a great idea for v1.1.
                    Input buffers. With that in mind, I present version two! All parts available for SMT from JLC, incorporates the design guidelines laid out in the duet3, comes to $19.5USD per 10 (please note I am not selling these, this is the price from JLCPCB) (plus shipping). Sadly I did have to bump it to a dual layer PCB.
                    For V1.04 Duet Wifi, the CS/NPCS0 pin already has a 2k2 resistor. R2 can be bridged in that case.SBCAdapterv2.JPG
                    Fixed the dims.
                    arhiundefined 1 Reply Last reply Reply Quote 1
                    • arhiundefined
                      arhi @deadwood83
                      @deadwood83 why solder to board instead plugin in to the header?
                        A Former User @arhi
                        @arhi said in Duet 2 Ethernet and SBC:
                        presumably because wifi boards don't have headers?
                        • arhiundefined
                          arhi @A Former User
                          @bearer wifi boards you have to desolder the board right? so if you do that you can solder on the 2 headers thats easier than removing the esp module 😄 ...
                            A Former User @arhi
                            simply disabling it in either RRF or WiFi firmware seems to work, but can't say I've done a ton of testing (there is a thread with a pogo pin thing to slap on top of existing wifi module and worked for the limited testing i did)
                            • arhiundefined
                              arhi @A Former User
                              @bearer ah, that's cool then 🙂 ... I dislike wifi in general so never even tried the duet2wifi board 🙂 all my duet's are eth ... anyhow it's rather easy to solder a header on this board too so not a biggy even as is it is very useful
                                A Former User @arhi
                                true, but the headers holes are covered by the wifi module which is probably not for everyone to remove.
                                  deadwood83
                                  It is version agnostic. It is attached to the back of the board, so it works with both ethernet and wifi versions. No desoldering required, only attaching pins to the Pi header. I will publish the public EasyEDA links once I verify all my measurements in KiCad.duetFit.JPG
                                  EDIT:
                                  -Updated image to be proper scaling.
                                  -Created non-hollow version with plated through-holes for ethernet users who want to stick it on the headers
                                  -License is CERN open hardware, feel free to commercialize it if anybody feels so motivated.
                                  -Strengthened top section, re-scaled text, verified clearance against paneldue header, extended bottom of board to index against duet mainboard.
                                  -NO DESOLDERING NECESSARY
                                  -Updated grounding to star/bus ground pattern
                                  The schematics/PCB
                                  I will keep 5 for me. The others can go to homes in the US at the cost of a flat rate envelope.
                                  arhiundefined T3P3Tonyundefined tekstyleundefined 3 Replies Last reply Reply Quote 1
                                    deadwood83
                                    I think I may have messed up in my design.
                                    @T3P3Tony I have a question about the SBC conn on the duet 3 v1.01. On my little breakout I put a 470-Ohm in series with the input buffers on SCLK and only just realized (after ordering some) that your placement of the 470 was NOT on the clock line but rather on PC23/IO_7_OUT. Looking at TI's guidelines for matching a series damping resistor: https://www.ti.com/lit/an/scba012a/scba012a.pdf
                                    Assuming worst-case scenario, at max output current for the SN74LVG2G34 (12mA) we get Irms of ~8mA
                                    Using PCBWay's trace impedance tool shows a line impedance of roughly 105-Ohm for 2 layer FR4 1.6mm 1-Oz copper PCB using the trace width of .61mm
                                    My worry is that the 470-Ohm resistor will provide too much dampening and round off the waveform peaks too much since SCK on the daughterboard lives at the termination rather than origination (or could this be considered the origination due to the amount of PCB the signal must travel?). Do you think this is a valid worry, or should it be OK with the resistor there at the current speed of 8MHz?
                                    Considering other solutions to this point involved some wires with crimped/socketed resistors, and one instance of a breadboard, am I just overthinking it now?
                                    • arhiundefined
                                      arhi @deadwood83
                                      The schematics/PCB
                                      awesome 🙂 thanks
                                      Did you made this in kicad and exported to easyeda or you made it directly in easyeda. I can redraw it in kicad but if you already have it in kicad it would save me some time 😄
                                      deadwood83undefined 1 Reply Last reply Reply Quote 0
                                      • smoki3undefined
                                        smoki3
                                        @deadwood83 Cool design. I use a would use a similar one but with an integrated 5V DCDC converter to power the raspberry. Otherwise you need an external one which is not so pretty and easy to use.
                                        I also integrated the same pin layout as on the raspberry to use a simple ribbon cable.
                                        But actually the firmware is the first thing which need to be fixed 🙂
                                        • PCRundefined
                                          PCR
                                          @deadwood83 Wrote you a PM
                                            4 layer and 2 Oz for the Duets
