    FreeCAD
    Off Topic
    13
    101
    8.4k
      droftarts administrators
      Off topic, but relevant and not sure where else to post it: AutoDesk announces that STEP export will remain in Fusion 360 personal licence: https://www.autodesk.com/products/fusion-360/blog/changes-to-fusion-360-for-personal-use/
      However, now Iโ€™ve started using FreeCAD Iโ€™m going to persist; I like having my documents on my machine, and I realise the cloud part of F360 always bothered me. And AutoDesk could always change their mind again!
      • zaptaundefined
        zapta @droftarts
        @droftarts, thanks for the update.
        Yesterday I spent a hour or two downloading STEP and STL files of my Fusion 360, as I saw it the main problem with the new license model.
        However, it clicked with me that I need to move to something more stable than a free Autodesk and FreeCad seems to be a good choice, especially now that it's gaining momentum.
        They also have a donation page https://liberapay.com/FreeCAD/income/
        • jens55undefined
          jens55
          I decided to give FreeCad another shot as well but was stopped in my tracks when I tried to work on an object from thingiverse and edit it.
          I used this method:
          You can convert a mesh to a solid model that FreeCAD can work with with a few easy steps:
          Note: an object needs to be selected before starting the command. Starting from step 2 you need to select the last object in the tree.
          menu Part --> Create shape from mesh
          menu Part --> Convert to solid
          Optional: menu Part --> Refine shape
          The STL from your link has many, many facets and the created solid is massive. Step 3 takes a long time to complete and does not work fully. You may be able to work with it, but things might be slow.
          Step one worked ok but step two threw an error saying the shape is not a shell.
          I have not been able to get past that error.
          Has anyone managed to do that conversion - a fairly important feature!
          JoergS5undefined arhiundefined 2 Replies Last reply Reply Quote 0
          • JoergS5undefined
            JoergS5 @jens55
            @jens55 said in FreeCAD:
            there are some wikis handling this error:
            https://forum.freecadweb.org/viewtopic.php?t=6643
            https://wiki.freecadweb.org/FreeCAD_and_Mesh_Import
            Seems to be a problem with the object itself (holes, self intersecting surfaces).
            • matt3oundefined
              matt3o
              gosh I'd love to use freecad on a regular basis, I find it to be usable and at the end you can design basically anything, the only problem is that it takes three times the time than with onshape (my weapon of choice). As a maker I don't care if my designs end up to the public domain, actually I like that, but I understand that onshape might close or limit functionalities at any time, so it's good to keep an eye on really open alternatives.
              Still as a hobbyist I have very limited time and knowing I have to spend half a hour on something it may take 5 minutes it's really painful.
              I'll see if I can help freecad development (being with code, docs or money) in the hope it will get a better workflow with time.
              Anything thanks @arhi for the shout out
              • arhiundefined
                arhi @jens55
                FreeCAD is not very useful for editing mesh files (I never managed to do useful edit of a mesh in f360 neither) but in a pinch, you can do it (slow and painful but ..) ... For me, it is faster to redo the whole part from scratch as a solid based on stl than to edit stl. For small STL edits I suggest using a mesh editing tool (I use Art of Illusion .. there are, other, better ones like blender..)
                • PCRundefined
                  PCR
                  https://w3-mediapool.hm.edu/mediapool/media/fk03/fk03_lokal/verbundlabore/kca/rpmlab/fk03_rp_stl_to_solid_r1.pdf
                  its a good guide ๐Ÿ˜‰ But in german
                  • arhiundefined
                    arhi @matt3o
                    @matt3o said in FreeCAD:
                    I'll see if I can freecad development (being with code, docs or money) in the hope it will get a better workflow with time.
                    Interesting. I used onShape for a long while (for me the best "free" tool out there, especially as I come from solidworks background) and stopped when they changed policy, not 'cause I have issue with publicity - I give source to all my 3d work anyhow so that's not a problem (like the f360 changes attm are not too big of a deal for me) but 'cause this is a move in wrong direction for me and they can change that at any time locking me out of my stuff and I don't want that.
                    Now wrt freeCAD being slower to work with, when was the last time you tried? What release you tried. Release they have out there is imho unusable, it is too slow and too unstable, but the pre-release .19 is very very usable. Takes a bit time to figure out how to do stuff but then it becomes fast and productive. The sketching is a bit sketchy ๐Ÿ˜ž and finiky but one gets around that after few days of using it
                    matt3oundefined 1 Reply Last reply Reply Quote 0
                    • arhiundefined
                      arhi @PCR
                      @PCR that url does not work for me ?
                      • JoergS5undefined
                        JoergS5 @arhi
                        @arhi for me the link works. It's a guide to convert stl to step with Catia or FreeCAD.
                        • arhiundefined
                          arhi @JoergS5
                          @JoergS5 interesting, it works now, was 404 when I tested first time
                          • arhiundefined
                            arhi
                            I was trying to make installer for freecad .19 for days now and finally decided to see what they are doing for .19 prerelease and I see they are shooting .z for a portable "install" ... looks like they have the same issue .. the NSIS tool they used originally has a 2G limit and when the size of the app goes over 2G the darn thing won't work. Anyhow unpacking the archive anywhere works and looks like it's using home dir to store all the running data, config, workbenches etc etc .. so no install required
                            • matt3oundefined
                              matt3o @arhi
                              @arhi said in FreeCAD:
                              I'm on .19-pre, I update the appimage every now and then. Very usable overall, but still way slower to design anything especially if you have complex composites.
                              When I have simple things to do I try to use it so to lower my dependency to onshape and to slowly get used to it. Also being able to work completely off-line is a huge plus. If onshape starts to do shitty things like fusion is doing I'll very quickly switch though ๐Ÿ™‚
                              • arhiundefined
                                arhi @matt3o
                                @matt3o dunno, for me it's similar speed as onshape to make stuff ... I'm probbly doing simpler stuff than you. I do some stuff faster on onshape when I don't know (yet) how to do it in freecad, but the operations I know how to do in freecad I think speed is same. So yes, I am designing bit slower in freecad (for now) but that's fault of mine not of freecads ๐Ÿ˜„
                                onshape made only one change that I know off that made me move, not 'cause the change affected me (didn't really I had everything open before that change anyhow) but 'cause the whole "we can change the rules any time and you can't do anything about it" is not the way I wanna play that game ๐Ÿ˜„
                                • matt3oundefined
                                  matt3o @arhi
                                  I see that you are implying my inadequacy at parametric cad which is... totally true ๐Ÿ˜„ but time to learn the software is still time. But I switched to inkscape (that now I actually prefer to illustrator... in certain aspects), to librecad (which is totally fine for what I need) and gimp (well, that still hurts)... freecad and blender are the last missing pieces...
                                  • arhiundefined
                                    arhi @matt3o
                                    @matt3o not yours, actually mine.... and yes, time to learn tool is important that's why I think learning freecad is better use of my time then learning more of onshape of f360 ๐Ÿ™‚
                                    • arhiundefined
                                      arhi
                                      anyone tried inventor import workbench
                                      https://github.com/jmplonka/InventorLoader
                                      supposedly loads inventor files and f360 can export inventor (not any more probably but..) and the objects, names, featues, history should be preserved? might be idea for migration f360>freecad
                                      • PCRundefined
                                        PCR
                                        360 can still export inventor and step! They changed it yesterday
                                          droftarts administrators @PCR
                                          @PCR ... and may still change their mind about that (and other) functionality at any point in the future.
                                          Maybe it was my internet connection, or the aged 2013 MacBook Pro I run, but Onshape became unbearably slow, and Fusion also had plenty of โ€˜brownoutโ€™ moments. FreeCAD may be clunky, but I notice that itโ€™s snappier.
                                          • PCRundefined
                                            PCR
                                            ๐Ÿ˜‰ yes they may and will!
                                            BTW SolidEdge has a maker edition too!
                                            And for all who want to simulate test out Z88!
