    Direct drive extruder and Bowden extruder on one machine?
    bondtech tool e3d toolchanger extruder
    10
    26
    3.2k
    • engikeneerundefined
      engikeneer @theruttmeister
      @theruttmeister @1997alex I think there is one other (very specific) occasion where you might be combining bowden & direct drive - a single hotend Y-splitter multi-material printer where you need direct drive (e.g. to print flexibles, or because you hate bowden). I'm thinking multiple bowdens connecting through a Y-splitter (similar to the original Prusa MMU), then a single direct drive extruder actually pushing the filament through the hotend.
      In reality here, the bowdens are more like loading devices to swap the active filament, whilst the direct drive is doing the brunt of the extrusion. You'd probably want to have the bowdens at quite low currents in normal running in case they are out of sync with the main direct drive extruder.
      Of course, there are many other reasons why this might not be a great design (filament clogging, lots of extruders etc) hence I've not seen one in real life, though there was someone else on the forum that mentioned they were working on one a while ago...
      i3 clone with a bunch of mods
      theruttmeisterundefined 1 Reply Last reply Reply Quote 0
      • theruttmeisterundefined
        theruttmeister @engikeneer
        @engikeneer
        You could argue the Palette falls into this category.
        And in fact you can use the Palette to load filament into the head. But they have encoders and switches to make sure everything stays in sync.
        Palette splices though, because un-loading and loading filament is slow, wasteful and failure prone.
        Isolate, substitute, verify.
          Phaedrux Moderator @theruttmeister
          @theruttmeister said in Direct drive extruder and Bowden extruder on one machine?:
          Thanks for the laugh, I needed that.
            theruttmeister
            You've lost me?
              @theruttmeister Sorry, I thought everyone was aware how notorious the Palette is for getting out of sync with splices taking too long and the buffer running out and there being no sensor to detect this and then snapping the filament.
              That part is bang on though.
                theruttmeister @Phaedrux
                @Phaedrux
                Clearly we have had very different experiences of the Palette... I've build multi-input heads, and I've used multiple generations of the Palette.
                The development units had some issues. But I have found the production units to be reliable. I'd certainly pick one over any multi-input design I've ever seen.
                • aprzundefined
                  aprz
                  Very interesting points. I’ve heard of the mmu from Prusa it looks good and is less than the pallete but I’m not sure the mmu is worth buying at $299. The printer I have has a long Bowden tube and it takes while to push filament through and wanted to know if a single extruder at the other end of the bowden tube would be of any improvement besides loading quickly(already using a direct drive), considering that there’s articles on Bowden vs direct drive extrusion just came to mind.
                  • Marco_76undefined
                    Marco_76 @theruttmeister
                    @theruttmeister
                    I had a similar idea, taking the advantage of a nema 17 with high torque on the bowden side, and a small nema 8 (80-100g) as additional direct stepper? Maybe with a 3:1 or 5:1 gear ratio. The idea is to help the small nema 8, which alone would not work. Is it so creazy?
                    Marco
                      deckingman @aprz
                      @1997alex In answer to your original question but without getting into any debate about whether it's a good idea or not, yes you can do that and you would not be the first to use two extruders in a push-pull arrangement. Configuration wise, you simply define a tool to use two extruders and then set the mixing ratio to 1:1.
                      Marco_76undefined 1 Reply Last reply Reply Quote 0
                      • Marco_76undefined
                        Marco_76 @deckingman
                        @deckingman
                        Thanks Deckingman . I know I can configure two steppers to work in sync, but the question in fact is if it is a good idea or not and if there are specific issues with this configuration. As of now I'm using the flex3drive system but I found the worm gear very fragile (it's the second tyme I'm oredering replacements). The other option which I'm evaluating is to change the plastic worm gear with metal gears.
                          deckingman @Marco_76
                          @Marco_76 My comment was addressed to the OP, not to you. However, in answer to your question of whether its a good idea or not, it depends on the usage case. If you have an extruder that doesn't grip the filament well, and if the incoming filament runs through a long tube which may or may not have bends and thus induces friction in the filament path, or if you use large heavy reels of filament which do not rotate easily, then a push-pull extruder arrangement will help. Personally, I use Bondtech BMG extruders (6 of them) mounted on a second gantry which tracks the hot end, and my (6) filament reels rotate freely, and I don't use PTFE tubes on the inlet side of the extruders, so a push-pull arrangement is not necessary in my usage case.
                          • Marco_76undefined
                            @deckingman
                            interesting solution. Is there any picture or schema which show this?
                              @Marco_76 said in Direct drive extruder and Bowden extruder on one machine?:
                              @deckingman
                              Shows what? Do you mean the extruder gantry? If so then I guess you want to know more about my CoreXYUVAB printer. Plenty of information on my blog and YouTube channels which are linked in my description.
                                theruttmeister @Marco_76
                                @theruttmeister
                                Marco
                                Not crazy... but I don't think you get much from that. A NEMA8, even with a gearbox, puts out such a tiny amount of torque that I don't think there's much benefit over a plain Bowden drive. But I've not tried it, so I don't really know for certain.
                                Its also easy enough to use decently large X/Y motors and a direct drive NEMA17... unless you really really want to go really fast.
                                Oriental motors make a really nice NEMA11 (actually not true NEMA bolt spacing... but anyway) with a 10:1 spur gearbox, its insanely expensive, but makes for a nice light direct drive extruder. Puts out ~42oz-in of torque. Its a bit long with that gearbox, but it works nicely.
                                https://catalog.orientalmotor.com/item/stepper-motors-motor-only/legacy-pkp-series-2-phase-bipolar-stepper-motors/pkp223d15a-sg10-1
                                I expect that the issue with a push/pull setup is going to be the stretch/compression in the bowden... if you have too much, the small motor may run out of torque. With the tube stretching/compressing to effectively absorb the extra torque from the larger motor.
                                Because the motors are running in sync, you might not gain anything at all... in a perfect world you would want to 'pre-load' the bowden tube, so that 100% of the torque from the large motor is being used for extrusion.
                                It might be that the natural 'spring' that is micro-stepping will absorb that variation.
                                Its would be fun to design and try such a setup.
                                • oliofundefined
                                  oliof
                                  someone once linked a two-in-one setup with two bowden feeders and a direct feeder here on the forum, which is one application where I see this could be beneficial: decent control of the retracted filament that's not used, and nice short retracts on the print head.
                                  • Vetiundefined
                                    Veti
                                    on verrf there was a presentation from ldo about their motor for the orbiter extruder
                                    https://www.thingiverse.com/thing:4223085
                                    Gear ratio - 7.5 (new option 7.2)
                                    Filament pushing force 120Ncm - 12.4 Kg
                                    Filament acceleration up to 660mm/s^2
                                    Retraction speed: 60mm/s
                                    Overall weight is about 140g
                                    the stepper motor is 70g
                                      theruttmeister @Veti
                                      @Veti
                                      Nifty.
                                      I'd be worried about the long term durability of what looks like printed gears in that gearbox...
                                      But I've bought enough LDO motors over the years to trust them (even if I would plan for those gears wearing away...)
                                      3D printing really has made custom gears the easiest thing in the world!
                                      • Marco_76undefined
                                        @deckingman Impressive, I've seen your videos on your channel. I finally made my two flex3Drive working but I will take it as next generation, when I want to modify again my COREXYU 🙂
                                          @deckingman Impressive, ...........................
                                          Most people say "crazy" - (and they are probably right) 🙂
                                          • dragonnundefined
                                            dragonn
                                            It does make sense, I am using it right now.
                                            I have a light Nema 14 direct drive and a large nema 17 bowden.
                                            The whole point of that bowden is to feed the filament inside the printer enclose so the small direct drive doesn't have to work so hard to get the filament.
                                            They is one big problem with that, it is hard to get the ratio perfectly, a slight amount to low on the bowden extruder and after some hours of printing it will span the filament bowden the bowden and direct drive. A small amount to much and it will tangle inside the printer enclose.
