    Duet 3 Mini 5+ : Initial announcement
    288
    31.0k
      T3P3Tony administrators @weed2all
      @weed2all we will be supplying them via resellers and directly through the website
      • Dan1990undefined
        Dan1990
        Is there any estimation in terms of releasing? or still before x-mas?
        jbarrosundefined 1 Reply Last reply Reply Quote 0
        • jbarrosundefined
          jbarros @Dan1990
          @Dan1990 this was yesterday:
          @dc42 said in Duet 3 Mini 5+ : Initial announcement:
          We will have a limited number of pre-production boards next month. Full production and general availability will be Q1 next year.
            Just to clarify, we expect to have almost 300 pre-production boards early in December, so there should be enough for those who want to try them. We are hopeful that these boards will pass the relevant CE approval tests, but we can't guarantee this because so far we have only run some of these tests (the ones most likely to fail) and on a previous PCB revision. That's why we are calling them pre-production boards. If the boards do pass CE testing then we will be able to do the first production run in January.
            Chrissundefined 1 Reply Last reply Reply Quote 2
            • poohzazaundefined
              poohzaza
              nice where can i sing up for preorder
                T3P3Tony administrators @poohzaza
                @poohzaza we won't be running a pre-order for those. They will be for sale our website and hopefully some resellers as well.
                • piperswundefined
                  pipersw
                  You sell on your website ? I see you don't sell anything, everything is out of stock with Covid
                    @pipersw right now yes, we will let people what the plan is when we get closer to the release of the mini 5+
                    weed2allundefined 1 Reply Last reply Reply Quote 1
                    • Richard Fundefined
                      Richard F
                      better start saving my pennies the perfect board for me , and people wanting to upgrade ender 3s type printers, they should sell well
                      • weed2allundefined
                        weed2all @T3P3Tony
                        @T3P3Tony awsome...tag my name here when the boards are ready to be sell!...as im constantly check the forum...
                        https://www.thingiverse.com/weed2all/designs
                          Richard F
                          ps i hope you add a 12v reg for the fans
                          Vetiundefined A Former User? 2 Replies Last reply Reply Quote 0
                          • Vetiundefined
                            Veti @Richard F
                            @Richard-F said in Duet 3 Mini 5+ : Initial announcement:
                            you can see the jumpers above the fan connectors
                            vin or 12v
                            Richard Fundefined 1 Reply Last reply Reply Quote 0
                              Richard F @Veti
                              @Veti great ;}
                                The 12V fan output is also listed here https://duet3d.dozuki.com/Wiki/The_Duet_family_of_motion_control_electronics
                                  A Former User @Richard F
                                  Someone evidently didn't look at the specs before posting....
                                  Richard Fundefined 1 Reply Last reply Reply Quote -3
                                    Richard F @A Former User
                                    @CaLviNx forgive me i did not know there was a data sheet with specs as the board is still in testing and things can change before the release
                                    • piperswundefined
                                      pipersw @dc42
                                      The PCB is not the same between wifi and ethernet like for Duet2 ?
                                      I love the possibility to swap from wifi to Ethernet by swap the wifi module to Ethernet module on Duet 2, it's cheaper than buy an another Duet.
                                        T3P3Tony administrators @pipersw
                                        @pipersw no its not the same
                                        • piperswundefined
                                          pipersw
                                          for 5 steppers motors at 1.4A, the TMC2209 need active cooling with the board mounted vertically ?
                                            dc42 administrators @pipersw
                                            @pipersw said in Duet 3 Mini 5+ : Initial announcement:
                                            Probably wise to use a fan, but my guess is that you wouldn't get any overheat warnings even without fan cooling.
                                            piperswundefined 1 Reply Last reply Reply Quote 0
