    Duet-Wifi + Duex2 - short-to-ground reported by driver(s) 7 8 9
    389
    • CR3Dundefined
      CR3D
      Hi Community,
      i have a strange problem. With a standard setting of mine with a duet wifi and DUEX 2, I get the error message:
      Error: short-to-ground reported by driver (s) 7 8 9
      Error: over temperature shutdown reported by driver (s) 7 8 9
      but since it is a DUEX 2, these drivers are not available.
      How can this error message come about?
      The firmware is also stable at 2.05.1
      here the wiring:
      The Duex is also supplied with 24V.
      The Setup works normally, everything works! There ist just the error-message...
      Thank you in advance
      Christian (CR-3D)
      Christian from CR-3D
      Homepage:
      www.cr-3d.de
      Facebook:
      https://www.facebook.com/cr3d.official
      Our Discord Server
      https://discord.gg/SxRaPNuRdA
      Thingiverse Profile:
      https://www.thingiverse.com/cr-3d_official/about
      • Vetiundefined
        Veti
        post your config
        also does your wire conform with ?
        https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
        • CR3Dundefined
          CR3D
          Yes you can see the double wire clamp at the duet wifi...
          here the config:
          Notice, this config works identically at other printers too ...
          G90                                                ; Send absolute coordinates...
          M82                                                ; ...and absolute extruder moves
          M550 P"I655-C00010"                                  ; Set machine name
          M552   S0                                          ; Disable network
          M586 P0 S1                                         ; Enable HTTP
          M586 P1 S0                                         ; Disable FTP
          M586 P2 S0                                         ; Disable Telnet
          M569 P0 S0                                          ; Z-VR (von vorne betrachtet)
          M569 P1 S0                                          ; Z-Mitte
          M569 P2 S0                                          ; Z-VL -> nahe Ursprung
          M569 P3 S1                                          ; Extruder -> Physical drive 3 goes forwards
          M569 P4 S0                                          ; X-Achse -> Physical drive 4 goes forwards
          M569 P5 S0                                          ; Y0 -> Physical drive 5 goes backwards
          M569 P6 S1                                          ; Y1 -> Physical drive 6 goes forwards
          M584 X4 Y5:6 Z0:1:2 E3
          M671 X711:315:-88 Y15:585:15 S10 ; leadscrews at each corner
          M350 X16 Y16:16 Z16:16:16 E16 I1                          ; Configure microstepping with interpolation
          M92 X80 Y80:80 Z1600:1600:1600 E409         ; Set steps per mm
          M566 X400 Y400:400 Z50:50:50 E500         ; Set maximum instantaneous speed changes (mm/min)
          M203 X50000 Y50000:50000 Z800:800:800 E12000; Set maximum speeds (mm/min)
          M201 X900 Y900:900 Z1000:1000:1000 E1200; Set accelerations (mm/s^2)
          M906 X1300 Y1030:1030 Z1300:1300:1300 E1300 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30                                             ; Set idle timeout
          ; Set axis maxima
          M208 X590 Y485 Z500
          ; Set axis minima
          M208 S1 X-10 Y0 Z0
          M574 X2 Y2 S1                                       ; Set active high endstops
          ; Filament Runout
          M581 T2 E0 S1 C0
          M574 Z1 S2                                          ; Set endstops controlled by probe
          M558 P1 i1 H10 F500 T10000                             ; Set Z probe type to unmodulated and the dive height + speeds
          G31 P500 X0 Y51 Z3:50                                 ; Set Z probe trigger value, offset and trigger height
          M557 X40:590 Y51:475 P05:04                            ; Define mesh grid
          M307 H0 B0 S1.00                         ; Disable bang-bang mode for the bed heater and set PWM limit
          M305 P0 T100000 B4725 C7.060000e-8 	 ; Set thermistor + ADC parameters for heater 0
          M143 H0 S120                             ; Set temperature limit limit for heater 0 to 120C
          M305 P1 T100000 B4725 C7.060000e-8       ; Set thermistor + ADC parameters for heater 1
          M143 H1 S320  		                 ; Set temperature limit for heater 1 to 320C
          M106 P1 S1 F500 H1 T45                ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M106 P0 S0 F500 H-1                   ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M563 P0 S"HotEnd" D0 H1                              ; Define tool 0
          G10 P0 X0 Y0 Z0                                     ; Set tool 0 axis offsets
          G10 P0 R0 S0                                        ; Set initial tool 0 active and standby temperatures to 0C
          ; Open Door Switch
          M581 T2 E2 S0 C0			    ; trigger #2, connected on E2-endstop, trigger on  rising edge, only trigger while printing
          M581 T2 E3 S0 C0			    ; trigger #2, connected on E2-endstop, trigger on  rising edge, only trigger while printing
          ; Emergency Stop
          M581 T0 E4 S1 C0
          ; LED
          M106 P2 I0 F500 H-1 S255		     ; signal line for LED at fan2
          M106 P3 I0 F500 H-1 S0		             ; signal line for Bauraumluefter at fan3
          M572 D0 S0.03
          T0 P0;
          M400;
          M501
          Homepage:
          www.cr-3d.de
          Facebook:
          Our Discord Server
          • Vetiundefined
            Veti
            try adding
            M569 P7 R-1
            M569 P8 R-1
            M569 P9 R-1
            however i would suggest that you update to 3.1.1
            you can only define multiple values for E not Y and Z
            these should be removed
            CR3Dundefined 1 Reply Last reply Reply Quote 0
            • sebkritikelundefined
              sebkritikel
              Looks like it is showing as a Duex5 instead of a Duex2?
              The opposite problems in these threads, unsure if its the same issue(s)
              https://forum.duet3d.com/topic/6505/duex5-shown-as-duex2/7
              https://forum.duet3d.com/topic/16542/duex5-showing-up-as-duex2/15
              Large(ish?) IDEX - 6HC, 1HCL
              Stratasys Dimension 1200es to 6HC Conversion
              • CR3Dundefined
                CR3D @Veti
                @Veti said in Duet-Wifi + Duex2 - short-to-ground reported by driver(s) 7 8 9:
                M569 P7 R-1
                M569 P8 R-1
                M569 P9 R-1
                I tested this and it works! Thank you! πŸ™‚
                I also changed the multiple settings for the Y and Z axis, this was no problem till yet -> but it is better to make it clean πŸ™‚
                @sebkritikel
                You are right too! There is a DueX5 listet... I donΒ΄t know why ...
                Homepage:
                www.cr-3d.de
                Facebook:
                Our Discord Server
                  Is this a new Duex2? When and where did you purchase it? It showing up as a duex5 is odd.
                  Can you try reflashing your firmware? Staying with 2.05.1 is fine.
                    Phaedrux Moderator @CR3D
                    @CR3D I've been told this is likely caused by a bad connection underneath the SX1509b chip, which would certainly qualify for a warranty replacement.
                    • CR3Dundefined
                      CR3D @Phaedrux
                      @Phaedrux ok thank you for this Information! πŸ™‚ i will contact Roland πŸ™‚
                      Homepage:
                      www.cr-3d.de
                      Facebook:
                      Our Discord Server
