    My 6 input (5+1) mixing hot end
    My Duet controlled machine
    18
    109
    7.4k
      deckingman
      Hmm. I wonder if there are any differences between Vegas and resolve in that respect. My PC is nothing too fancy. It has an i7 8700K - std frequency of 3.7 GHz - not overclocked or anything. 16GB RAM. NO GPU - just the stock intel UHD 630 graphics that's bundled with the ASRock 370 Extreme mobo. Mostly because earlier versions of Vegas didn't leverage GPUs all that well so it was generally best advice to spend the money on the processor instead. The latest Vegas does leverage GPUs a lot better so a graphics card is on my wish list - need to decide which one - any advice for a budget of (say) £200?
      Anyway, depending on what is going one - stuff like picture in picture and motion tracking slow it down a bit more - but a typical 1080p AVCHD renders in about the same time as playback. i.e. a 20 minute 1080p AVCHD at 50 fps with 5.1 surround will render in about the same 20 minutes. An MP4 for YouTube renders in about half that time - about 10 mins for a 20 min video. Dunno if that's good or bad........
      arhiundefined yellowedplasticundefined 2 Replies Last reply Reply Quote 0
      • arhiundefined
        arhi @deckingman
        @deckingman no clue, dv depends heavily on what you did with the futage, with object tracking, many nodes of corrections and stuff, it can take hours .. on the other hand, some light corrections and 60min video is exported in 5-6 minutes ... I assume vegas is the same, basically they all use cpu fully all cores of cpu and lot of power from the gpu... and I doubt their algo's are too different in efficiency
        • Chrissundefined
          Chriss @deckingman
          @deckingman said in My 6 input (5+1) mixing hot end:
          So the YouTube channel reaches a lot more people than the blog.
          That is normal nowadays, the people to not want to check and check a blog for changes. The people prefer the push notifications on youtube, as I do. 😉 (Nobody uses RSS any more, unfortunately.)
          I love to see more updates from your tremendous project.
          Thumps up for your channel! You do a very good job there!
          Cheers, Chriss
          • yellowedplasticundefined
            yellowedplastic @deckingman
            @deckingman an RX 580 or RX 5500XT should fit the budget, with 8GB VRAM, if barely. 4GB would probably be just fine for 1080P, but more would help for 4K. Vegas doesn't care too much about AMD vs Nvidia, just memory, memory bandwidth, and GPU throughput. Resolve can and will use the GPU a lot, but also all of your logical CPU cores, where most others don't.
            As an aside, it's the i7-8700 that houses your current GPU, not the motherboard itself.
              deckingman @yellowedplastic
              @yellowedplastic Thanks for the recomendations and the clarification about the graphics. I'll take a look at those boards (Xmas isn't far away 🙂 )
                deckingman @Chriss
                @Chriss Aww, thanks man!
                  deckingman
                  ...........and now Part 13............https://youtu.be/YDG6BTwp4AU
                  • MrDuiundefined
                    MrDui
                    Kudos on that great design, and bravvo for your amazing printer, the results are incredible.
                    If I may, I believe you are overthinking the water cooling for this project.
                    I've built many water cooled print heads (I think I'm at my 5th design now) and it's really not rocket science, especially compared to what you've done already.
                    My first and most basic design was this one I showed in the following instructable, and it worked perfectly fine for years, despite being super basic.
                    https://www.instructables.com/Water-Cool-Your-3D-Printer-Nozzle-the-Cheap-and-Ea/
                    Since then I made some other fully 3D printed watercooled nozzle, and never had any issue with these even though they are printed with PLA. You can see the last one I made here: https://forum.duet3d.com/topic/18741/box-large-format-diy-printer
                    So far it seems to work just fine, but I only have a few dozens of printing hours with it so it's relatively new.
                    I suggest you to give it another go, In my opinion your current design is quite suitable to do this. If you need any help in designing it just let me know, I'd be glad to contribute 🙂
                      deckingman @MrDui
                      @MrDui Thanks.
                      But I have 6 inputs and I really don't have space to use those E3D style heat breaks.
                      Currently the spacing between the heat breaks is 12mm and I'm looking at reducing this further. The plate they fix to is about 40mm x 28mm plus 6mm mounting bosses giving maximum outside dimensions of 40mm x 42mm.
                      An E3D style heat break with it's air cooling fins has a diameter of 22mm and if we assume the water jacket has a modest wall thickness of say 3mm, then the effective diameter would be about 28mm. If I installed 6 of those in such a way that were touching (as close as possible), then the plate would be 84mm x 56mm which is pretty huge for a hot end. In addition to that, there would still need to be mounting bosses and of course the coolant inlet and outlet connectors would be protruding out even further. By the time one has added elbows and pipework (because the coolant entry and exit are at the side), I would not be surprised if the resultant envelope was in the order of 100mm square .
                      Also, with 28mm spacing between the inlets, this would mean that the combining block which takes the 6 inputs to a single point, would need to increase in size from 40mm x 28mm to at least 62mm x 34mm. But this would mean that the compound angles would be too acute for the filament path unless the length was increased from about 31 mm to about 50mm.
                      All in all, those type heat breaks just make the entire assembly far too to big to be practical. (Which is why I started out using Slice Engineering Mosquito) heat breaks).
                      MrDuiundefined 1 Reply Last reply Reply Quote 0
                      • MrDuiundefined
                        MrDui @deckingman
                        @deckingman
                        Maybe my previous post wasn't clear, I wasn't suggesting to use the E3D, but to keep your exact current system and add a 3D printed sleeve around the copper heatsinks (not one per heatsink but all at once).
                        It's difficult to explain so hopefully you get the idea, if not then maybe you can send me the basic shapes of the parts and I can design it for you or at least try 🙂
                        (I know you want to keep part of your design confidential so just send whatever isn't critical, or even with different dimensions if you want).
                        I'm almost 100% sure it can be done within the same volume you currently have, or maybe very marginally larger.
                        • MrDuiundefined
                          MrDui @MrDui
                          Well actually I realized that I don't really need any dimensions, so I just done a quick little 3D to explain the idea:
                          The two white parts would be made of aluminum,
                          The orange ones are your copper heatsinks. It's possible that they would need to be slightly modified, but nothing really difficult if you have a lathe around
                          The blue one can just be 3D printed.
                          The idea is to sandwich the heatsinks between those two aluminum plates and have a 3D printed aluminum sleeve around to keep the water in. I made the sketch very basic but you'd need some grooves in the aluminum plate to ensure a good seal, as well as water inlets/outlets and screws to tighten everything.
                          The bottom plate would need to be slightly separated from your current heating block, I guess 6 washers should do the trick.
                          To seal everything, the easiest way is to use some automotive sealant, it is made for high temperatures, it's cheap and it's easy to do 🙂
                          Hope it helps !
                          deckingmanundefined 2 Replies Last reply Reply Quote 0
                            I think heat breaks without heatsinks would work too. This doesn't help Ian because E3D doesn't make a PTFE-lined heat break without heatsink.
                            • fmaundefined
                              fma
                              I plan to order this heatbreak, which is very well done, because of using copper where good thermal conductivity is needed, and stainless steel where bad thermal conductivity is needed.
                              It is then very easy to integrate it in a bloc of aluminium, drilled with a few holes to have water circulation:
                              (the hole on the bottom-left needs to be closed by a screw+gasket)
                              The only problem is the price 😕 Especially when you need 6 of them! But they may give you some...
                              Frédéric
                                deckingman @MrDui
                                @MrDui Funnily enough, my first cooling "tank" design use just that approach - but with simple tubes rather than the finned type. From other designs that I've looked at, the fins are not necessary when liquid cooling is used. But I had problems with leaks around the tubes. That was why I changed the lower part to one piece block with the tubes effectively milled out of a solid part.
                                For info, the liquid cooling system works just fine - I don't need to change it. The issue I have to resolve is filament leakage around the heat breaks where they are a press fit into a plate. The next design has screw threaded heat breaks which I hope will cure that problem.
                                  deckingman @fma
                                  @fma Yes, I've looked at the copper head and Slice engineering's liquid cooling designs too...(and every other "off the shelf" heat break that I can find).
                                  My problem is that I have 6 inputs but only one output. With that type of heat break, the normal method of getting everything to seal is that the nozzle is tightened against the heat break. But I can't do that. So I need the heat break to have flats or a hexagonal section, so that it can be tightened against a flat plate. And it needs to be 4mm ID so that I can use a PTFE insert. So I'm having to make them. But they will look very similar to the heat breaks in the design you posted - just with flats or a hexagonal section so that they can be tightened.
                                  Essentially, the cooling system and heat breaks worked well. It's just that I had filament leaks because press fitting the heat breaks into a flat plate didn't work well.
                                    deckingman @MrDui
                                    @MrDui For info, this was my first attempt at the simpler "tubular" design
                                    Despite copious amounts of sealant, I still had leaks.
                                    • fmaundefined
                                      fma
                                      I don't know if they exist in such small size, but you may search for copper gaskets used on cars oil tanks: https://www.ebay.com/p/202950637
                                      They are crushed during tightening, and handle high temperature.
                                      Frédéric
                                      • fmaundefined
                                        fma
                                        Did you see this one? It can be tighten with a spanner, but I don't know how torque it can handle...
                                        Frédéric
                                          deckingman @fma
                                          @fma said in My 6 input (5+1) mixing hot end:
                                          Yes I did. But it's "all metal" so only 2mm or so ID (internal diameter) and mixing hot ends need to have PTFE lined heat breaks.
                                          • fmaundefined
                                            fma
                                            Ah, sorry, I forgot that point...
                                            Frédéric
