    Duet 3 : No tool nor bed shown
    1.1k
    • Donpiundefined
      Donpi @droftarts
      @droftarts
      I use a Raspberry 4 2Go as SBC.
      M98 P"config.g" Show me the welcome message again.
      But no error
      Here is the return of
      M308 S0
      M308 S1
      M950 S0
      M950 S1
      M122 returns this :
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.01-RC9 running on Duet 3 MB6HC v1.01 or later
      Board ID: 08DJM-956BA-NA3TN-6JTDG-3SD6J-TABLTUsed output buffers: 1 of 40 (11 max)
      Static ram: 154572
      Dynamic ram: 160680 of which 20 recycled
      Exception stack ram used: 264
      Never used ram: 77680
      Tasks: NETWORK(ready,2076) HEAT(blocked,1412) CanReceiv(suspended,3824) CanSender(suspended,1484) CanClock(blocked,1432) TMC(blocked,216) MAIN(running,5036) IDLE(ready,80)
      Owned mutexes:
      Last reset 00:03:46 ago, cause: power up
      Last software reset details not available
      Error status: 0
      Free file entries: 10
      MCU temperature: min 20.8, current 26.6, max 26.8
      Supply voltage: min 24.9, current 24.9, max 25.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
      Driver 0: standstill, reads 6924, writes 11 timeouts 0, SG min/max 0/0
      Driver 1: standstill, reads 6925, writes 11 timeouts 0, SG min/max 0/0
      Driver 2: standstill, reads 6925, writes 11 timeouts 0, SG min/max 0/0
      Driver 3: standstill, reads 6926, writes 11 timeouts 0, SG min/max 0/0
      Driver 4: standstill, reads 6926, writes 11 timeouts 0, SG min/max 0/0
      Driver 5: standstill, reads 6927, writes 11 timeouts 0, SG min/max 0/0
      Date/time: 2020-11-18 12:04:16
      Slowest loop: 3.26ms; fastest: 0.14ms
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
      Segments left: 0
      Movement lock held by null
      HTTP* is ready with "M122" in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon* is idle in state(s) 0 0, running macro
      Code queue is empty.
      === Network ===
      Slowest loop: 1.90ms; fastest: 0.01ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 0 of 8
      - Ethernet -
      State: disabled
      Error counts: 0 0 0 0 0
      === CAN ===
      Messages sent 0, longest wait 0ms for type 0
      === Linux interface ===
      State: 0, failed transfers: 0
      Last transfer: 17ms ago
      RX/TX seq numbers: 6649/6650
      SPI underruns 0, overruns 0
      Number of disconnects: 0
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.1.1
      Daemon:
      Finishing macro daemon.g, started by system
      > Next stack level
      Code buffer space: 4096
      Full transfers per second: 0.82
      • Donpiundefined
        Donpi @jay_s_uk
        @jay_s_uk
        you meen with with
        sudo apt update
        sudo apt upgrade
        I'll allready done it but noting install.
          A Former User @Donpi
          @Donpi said in Duet 3 : No tool nor bed shown:
          try running M997 the previous post shows the software on the pi is 3.1.1. M997 should try to flash the board to match.
          Donpiundefined 1 Reply Last reply Reply Quote 0
          • Donpiundefined
            Donpi @A Former User
            @bearer @jay_s_uk @engikeneer
            The M997 worked... I guess
            now M115 reutrns :
            But still nothing...
            • Vetiundefined
              Veti
              M950 S0
              M950 S1
              you wrote T instead of S
              • Donpiundefined
                Donpi @Veti
                @Veti Yeah, in this case, even S was wrong 😛
                M950 H0 and H1 give the same response :
                Heater 0 does not exist
                • Vetiundefined
                  Veti
                  M350 X16 Y16 Z16:16 E16 I1 ; Configure microstepping with interpolation
                  you are not allowed to specify 2 z values.
                  what i would suggest is. save all your config files and generate an new one from the configurator.
                  then slowly start adding your additional configs one by one until it breaks.
                    droftarts administrators @Donpi
                    @Donpi My mistake, send M950 H0 and M950 H1 (not T0/1) to check heater definition. Also send M563 P0 to check tool definition.
                    M563 P0
                    Tool 0 - name: T0; drives: 0; heaters (active/standby temps): 1 (0.0/0.0); xmap: X; ymap: Y; fans: 0; status: selected
                    But M308 S0 and S1 reporting "Sensor does not exist" does seem to imply there is a problem with your M308 definition in config.g. What happens if you send M308 S0 P"temp0" Y"thermistor" A"Bed Temp" T100000 B4700 C0.0000000706?
                    • Donpiundefined
                      Donpi @droftarts
                      @droftarts strange this work well.
                      and if I call M308 S0, it says :
                      Sensor 0 (bed Temp) type bla bla bla...
                      It's like my config.g is not readed or somthing reset everything
                      • Donpiundefined
                        Donpi @Veti
                        @Veti With a complettely new copnfiguration strait from the generator I have the same behaviour
                        • Vetiundefined
                          Veti
                          what version of the duet web control are you running?
                          Donpiundefined 2 Replies Last reply Reply Quote 0
                          • Donpiundefined
                            Donpi @Veti
                            @Veti
                            I'am a bit puzzled ...
                            I have created a macro with my config.g.
                            And running the macro I get the tootls and heaters...
                            It' just give me this errors
                            I don't know why my config.g is ignored...
                            • Donpiundefined
                              Donpi @Veti
                              @Veti My duet web control is 3.1.1
                              • Donpiundefined
                                Donpi
                                Hum the macro is not saved in the micro SD ... I think the problem is from here ...
                                  @Donpi If you're using SBC, you shouldn't have an SD card in the Duet! The O: directory is a virtual SD drive on the Raspberry Pi. See https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Virtual_SD_card
                                  Where is your config.g? On the SD card in the Duet, or on the Raspberry Pi?
                                  • Donpiundefined
                                    Donpi @droftarts
                                    @droftarts
                                    Of cours in the raspberry
                                    There is no card on de Duet
                                    • Donpiundefined
                                      Donpi
                                      Hooo... could it be that the partition I see on windows is the one for the Duet in standalone mode.
                                      And that the partition use by the Raspberry Bi is not visible on windows ?
                                        Very likely!
                                        • Donpiundefined
                                          Donpi
                                          All that for this ...
                                          Sorry for the time lost 😕
                                          • Vetiundefined
                                            Veti @Donpi
                                            @Donpi
                                            you are making the changes on the sd card in windows?
