    PanelDueFirmware 3.2.4 released
    PanelDue
    14
    64
    4.2k
    • wilrikerundefined
      wilriker @BoA
      @BoA Thanks. I'll fix that in the next release. And if it were CSS... believe me it would look much worse if I am the developer. πŸ˜‚
      Manuel
      My Tool Collection
      • wilrikerundefined
        wilriker @worekarolis
        @worekarolis @cgcafer Thanks for confirming compatibility with V2 boards! And thanks to @dc42 for spotting the config error.
        Manuel
        My Tool Collection
        • Exerqtorundefined
          Exerqtor
          I've been getting some strange errors popping up on the PanelDue after updating to 3.2.4, none of the errors show up in the console on DWC and i can't find them if i scrub thru my print-gcode or any of my filament, toolchange, firmware retraction or current macro-files either.
          Heres ha pic of them:
          I don't know if this is a PanelDue issue, but since i didn't get them before the update and i can't find them any other place i'm giving it a shot.
            Looks like character loss between PanelDue and the Duet. It could be caused by a bad connection, or the baud rate being too high for the cable length.
            • Vetiundefined
              Veti
              or interference from other cables. i.e motor cables.
              Exerqtorundefined 1 Reply Last reply Reply Quote 0
              • Exerqtorundefined
                Exerqtor @Veti
                @dc42 said in PanelDueFirmware 3.2.4 released:
                I'll re-check the connections again, but the cable length is "only" 60cm, should that be enough to cause issues by itself? It's been the same length since i built the machine so just curious if that's stretching the limit to some extent, and resulting in only a minor bad connection on one of the sides is enough to cause problems?
                @Veti said in PanelDueFirmware 3.2.4 released:
                No other cables running along that side of the printer, so i can rule that out luckily πŸ™‚
                • Vetiundefined
                  Veti
                  @Exerqtor said in PanelDueFirmware 3.2.4 released:
                  you could also try twisting or braiding the cables .
                  • BoAundefined
                    BoA
                    Today, for the first time, I tried "print again" button. And... it does not work. Perhaps file name is too long, or something, but I got the message that my file (with name cut in the middle) has not beed found. 😞
                    File name: voron_80t_hubbed_gear_x4_rev2_10mm_0.2mm_NYLON_MK3S_2h3m.gcode
                    • wilrikerundefined
                      wilriker @BoA
                      @BoA thanks for reporting. I'll fix that in the next release.
                      Manuel
                      My Tool Collection
                      • Karaboxundefined
                        Karabox
                        on the last sale bought fystec paneldue 5i (clone), updated it to 3.2.4. Installed and turned on the power. I was very surprised to change the color palette from RGB to BGR. Is this a display issue or a firmware feature?
                        Exerqtorundefined wilrikerundefined 2 Replies Last reply Reply Quote 0
                        • Exerqtorundefined
                          Exerqtor @Karabox
                          @Karabox strongly doubt your harware shit the bed "just" with a fw update. Have you tried rolling back to 1.23.2 and then upgrade to 3.2.4 again to see if that remedy it?
                          • Karaboxundefined
                            Karabox
                            the first thing I did was update the firmware to 3.2.4, then I noticed that the red and blue colors were changed
                            I don’t know how it was before the firmware update πŸ˜ƒ
                            I tried now to update 4.3 (v3.0) display to version 3.2.4 - red color in place πŸ˜ƒ
                            • wilrikerundefined
                              wilriker @Karabox
                              @Karabox said in PanelDueFirmware 3.2.4 released:
                              It seems that fsytec is not using the exact same display as the Duet PanelDue 5i and thus the display driver will not match.
                              You could try to use the PanelDue-v3-5.0.bin instead. It might work since it uses a slightly different display driver.
                              But note that for clones there is no support.
                              Manuel
                              My Tool Collection
                              Karaboxundefined 1 Reply Last reply Reply Quote 0
                              • zaptaundefined
                                zapta @wilriker
                                @wilriker, the web interface shows slicer based time estimation. Are these estimations also visible in the latest version of paneldue?
                                In general they are the most accurate and most linear among the estimations provided by the web interface.
                                Extra points: allows the user to disable all but the slicer based information. All we need is just one good estimation. πŸ˜‰
                                • Karaboxundefined
                                  Karabox @wilriker
                                  @wilriker said in PanelDueFirmware 3.2.4 released:
                                  You were right, the firmware came up, the red color is in place. Thank you very much!
                                  SputnikOC3dundefined 2 Replies Last reply Reply Quote 0
                                  • wilrikerundefined
                                    wilriker @zapta
                                    @zapta The slicer based estimate is a feature of DWC and thus not accessible by PanelDue that is connected to RepRapFirmware.
                                    Manuel
                                    My Tool Collection
                                      A Former User
                                      will future firmwares have a command to switch baud rate to 115200 for users still running 57600 or will the new default be 115200 with appropriate change to the reprap config tool?
                                      • zaptaundefined
                                        zapta @wilriker
                                        @wilriker, do you know how the web interface does it? Do they read the gcode file independently? Do they track the execution of the progress gcode markers embedded in the gcode file?
                                        Would be great this slicer estimation and progress marker be tracked by the Duet natively. This estimation is more accurate and makes all the other time estimations obsolete.
                                        (I have a post processing script that among other things, propagate the slicer time markers to paneldue, displaying hours and minutes left in the standby temp fields of nozzle and bed respectively. It's very accurate but hackish).
                                          @bearer said in PanelDueFirmware 3.2.4 released:
                                          No. When you send M997 S4 to flash the PanelDue, the baud rate is automatically changed temporarily to 115200.
                                          • wilrikerundefined
                                            wilriker @zapta
                                            @zapta I don't know off hand how DWC get's the slicer estimate but it will simply start a countdown based on this number when the print is started. Nothing more fancy. This will be off in the first couple of minutes because it will count along the heat-up time but this will even out eventually the longer the print runs.
                                            Manuel
                                            My Tool Collection
