    PanelDueFirmware 3.2.4 released
    PanelDue
    14
    64
    4.2k
    • BoAundefined
      BoA
      Today, for the first time, I tried "print again" button. And... it does not work. Perhaps file name is too long, or something, but I got the message that my file (with name cut in the middle) has not beed found. 😞
      File name: voron_80t_hubbed_gear_x4_rev2_10mm_0.2mm_NYLON_MK3S_2h3m.gcode
      • wilrikerundefined
        wilriker @BoA
        @BoA thanks for reporting. I'll fix that in the next release.
        Manuel
        My Tool Collection
        • Karaboxundefined
          Karabox
          on the last sale bought fystec paneldue 5i (clone), updated it to 3.2.4. Installed and turned on the power. I was very surprised to change the color palette from RGB to BGR. Is this a display issue or a firmware feature?
          Exerqtorundefined wilrikerundefined 2 Replies Last reply Reply Quote 0
          • Exerqtorundefined
            Exerqtor @Karabox
            @Karabox strongly doubt your harware shit the bed "just" with a fw update. Have you tried rolling back to 1.23.2 and then upgrade to 3.2.4 again to see if that remedy it?
            • Karaboxundefined
              Karabox
              the first thing I did was update the firmware to 3.2.4, then I noticed that the red and blue colors were changed
              I don’t know how it was before the firmware update 😃
              I tried now to update 4.3 (v3.0) display to version 3.2.4 - red color in place 😃
              • wilrikerundefined
                wilriker @Karabox
                @Karabox said in PanelDueFirmware 3.2.4 released:
                It seems that fsytec is not using the exact same display as the Duet PanelDue 5i and thus the display driver will not match.
                You could try to use the PanelDue-v3-5.0.bin instead. It might work since it uses a slightly different display driver.
                But note that for clones there is no support.
                Manuel
                My Tool Collection
                Karaboxundefined 1 Reply Last reply Reply Quote 0
                • zaptaundefined
                  zapta @wilriker
                  @wilriker, the web interface shows slicer based time estimation. Are these estimations also visible in the latest version of paneldue?
                  In general they are the most accurate and most linear among the estimations provided by the web interface.
                  Extra points: allows the user to disable all but the slicer based information. All we need is just one good estimation. 😉
                  • Karaboxundefined
                    Karabox @wilriker
                    @wilriker said in PanelDueFirmware 3.2.4 released:
                    You were right, the firmware came up, the red color is in place. Thank you very much!
                    SputnikOC3dundefined 2 Replies Last reply Reply Quote 0
                    • wilrikerundefined
                      wilriker @zapta
                      @zapta The slicer based estimate is a feature of DWC and thus not accessible by PanelDue that is connected to RepRapFirmware.
                      Manuel
                      My Tool Collection
                        A Former User
                        will future firmwares have a command to switch baud rate to 115200 for users still running 57600 or will the new default be 115200 with appropriate change to the reprap config tool?
                        • zaptaundefined
                          zapta @wilriker
                          @wilriker, do you know how the web interface does it? Do they read the gcode file independently? Do they track the execution of the progress gcode markers embedded in the gcode file?
                          Would be great this slicer estimation and progress marker be tracked by the Duet natively. This estimation is more accurate and makes all the other time estimations obsolete.
                          (I have a post processing script that among other things, propagate the slicer time markers to paneldue, displaying hours and minutes left in the standby temp fields of nozzle and bed respectively. It's very accurate but hackish).
                            @bearer said in PanelDueFirmware 3.2.4 released:
                            No. When you send M997 S4 to flash the PanelDue, the baud rate is automatically changed temporarily to 115200.
                            • wilrikerundefined
                              wilriker @zapta
                              @zapta I don't know off hand how DWC get's the slicer estimate but it will simply start a countdown based on this number when the print is started. Nothing more fancy. This will be off in the first couple of minutes because it will count along the heat-up time but this will even out eventually the longer the print runs.
                              Manuel
                              My Tool Collection
                                A Former User @dc42
                                @dc42 said in PanelDueFirmware 3.2.4 released:
                                so when using the default 57600 M997 S4 should switch both the Duet and the PanelDue to 115200, and erase/reset as needed? (it didn't, but when set to 115200 it did (erase and reset automagically))
                                • zaptaundefined
                                  zapta @wilriker
                                  @wilriker, yes, it seems to fetch and use various print metadata such as estimated total print time.
                                  https://github.com/Duet3D/DuetWebControl/blob/master/src/components/lists/JobFileList.vue#L202
                                  https://github.com/Duet3D/DuetWebControl/blob/master/src/components/panels/JobEstimationsPanel.vue#L41
                                  Would be cleaner and more accurate for duet to track the M73 progress markers and provide the estimation time and percentage to all UIs. That's what most printers do.
                                  • oozeBotundefined
                                    oozeBot
                                    Has it been reported that the PanelDue appears to be refreshing (blinking) much more often with this release? I’ve not been able to put my finger on what’s triggering it, but it’s new to 3.2.4 or maybe 3.2.3..
                                    A Former User? Exerqtorundefined wilrikerundefined 3 Replies Last reply Reply Quote 1
                                      A Former User @oozeBot
                                      @oozeBot said in PanelDueFirmware 3.2.4 released:
                                      yes, i think i share that sentiment
                                      • Exerqtorundefined
                                        Exerqtor @oozeBot
                                        I secound that, started happening with 3.2.3 at least.
                                        • wilrikerundefined
                                          wilriker @A Former User
                                          The flashing procedure will
                                          • send the command to erase-and-reset with the currently configured baud rate (this only has effect if PanelDueFirmware is already 3.2.2 or newer)
                                          • It waits one second for the PanelDue to comply - this will then start the Bootloader which is hard-coded to 115200 baud
                                          • If Duet board is currently set to something other than 115200 it will change that
                                          • bossa code is executed on Duet to flash the PanelDue
                                          • After the reset at the end PanelDue will boot and restore the previously configured baud rate
                                          • If the Duet baud rate was changed above this will be undone at the end before handing control back to the user
                                          Manuel
                                          My Tool Collection
                                          • wilrikerundefined
                                            wilriker @oozeBot
                                            Yes, that was a change introduced in 3.2.3. It will update twice as often than before. If it encounters too many errors related to too frequent status requests it will dynamically slow down request rate until it sees stable responses again.
                                            Also changed in that version was a significant speed up of the initialization phase.
                                            Also @bearer and @Exerqtor
                                            Manuel
                                            My Tool Collection
                                            BoAundefined oozeBotundefined 2 Replies Last reply Reply Quote 0
