    Duet 2 Ethernet and SBC
    Beta Firmware
    29
    302
    33.3k
    • arhiundefined
      arhi @smoki3
      @smoki3 said in Duet 2 Ethernet and SBC:
      We try to debug it. As you read this thread completely... This was the reason for starting of this thread. It never was about the hardware/pcb design
      I seen now for the first time you mentioned "toolchanger" so I assume you are using DUEX. I have not noticed in the thread you are using DUEX, sorry. I understood it's a limitation of duet+sbc, that duex will not be supported. (as for the pcb part, that I apologize for, it should really be moved into some separate topic)
      • wilrikerundefined
        wilriker @arhi
        @arhi said in Duet 2 Ethernet and SBC:
        This is just an intermediate limitation we are currently trying to resolve. It works on my setup but it does not work for @smoki3 and we try to find out why.
        Manuel
        My Tool Collection
        • arhiundefined
          arhi @wilriker
          @wilriker said in Duet 2 Ethernet and SBC:
          awesome, I understood there's a problem making it permanent.
          • jlipavsky79undefined
            jlipavsky79 @wilriker
            @wilriker Have you gotten this to work in a machine yet?
            • wilrikerundefined
              wilriker @jlipavsky79
              @jlipavsky79 Unfortunately I did not get to it yet. Will test in the course of this week.
              Manuel
              My Tool Collection
              • MarMedundefined
                MarMed
                So after receiving the boards from JLCPCB($36.37) to avoid turning your hairs gray troubleshooting, check for lifted pads on the buffer ICs. I happened to have 1 board out of 10 where the TFR pin was not soldered.
                • arhiundefined
                  arhi @MarMed
                  @MarMed only one pad on 6pin ic ? can you share pic?
                  MarMedundefined 1 Reply Last reply Reply Quote 0
                  • MarMedundefined
                    MarMed @arhi
                    @arhi these photos were taken before I knew the issue, and I already soldered the pad, so I apologize for the poor photo quality.
                    20201102_203919 - Copy.jpg 20201102_193024 - Copy.jpg 20201102_203844 - Copy.jpg
                    • arhiundefined
                      arhi
                      weird, I would not expect pad lifting on something like this... anyhow, it's easy fix, good to know ppl need to check the pcb's
                      • smoki3undefined
                        smoki3
                        @wilriker
                        After a few releases today I tried 3.2beta4 on my tool changer again because I saw a lot of commits regarding the SBC. It seems to work now. I will now wire everything a do a test print.
                        UPDATE: Test print was fine
                        A Former User? wilrikerundefined 2 Replies Last reply Reply Quote 1
                          A Former User @smoki3
                          Test print was fine
                          with the duex? thats awesome!
                          • wilrikerundefined
                            wilriker @smoki3
                            That's great news!
                            @bearer said in Duet 2 Ethernet and SBC:
                            I had an (air) print running just fine with DueX5 a while back also but @smoki3 never got to finish the homing sequence with stallGuard. Glad that's working now.
                            Manuel
                            My Tool Collection
                            • resamundefined
                              resam
                              Since this post is getting rather long, let me summarize briefly and post a few bits that I haven't found here yet:
                              @deadwood83 has made a nice PCB nice PCB here with PCB and schematic sources in EasyEDA. It fits nicely on a Duet 2 WiFi and DuetEthernet without desoldering the existing WiFi module.
                              The pins on the PCB are mostly self-explanatory to hook them up to a Raspberry Pi:
                              • GND to GND / multiple physical pins
                              • SCK to GPIO11 / SPI0 SCLK / Physical Pin 23
                              • MOS to GPIO10 / SPI0 MOSI / Physical Pin 19
                              • MISO to GPIO9 / SPI0 MISO / Physical Pin 21
                              • 3V3 to 3V3/Physical Pin 1 or 17
                              • RDY to GPIO25 (TransferReadPin) / Physical Pin 22
                              • CS to GPIO8 / SPI0 CE0 / Physical Pin 24
                              (see this for a Raspberry Pi pin out table to double check)
                              GeneRisiundefined 1 Reply Last reply Reply Quote 3
                              • keyz182undefined
                                keyz182
                                Has anyone got tips on connecting optimally?
                                Currently I'm using a 4 core and a 2 core shielded cables, to connect up, with the shield as ground. Still have to drop the SPI speed to 2MHz though.
                                When I'm able, I'll rearrange things to reduce the cable length further (about 15cm currently). I've tried to route other wires (steppers etc) away from the Comms cable.
                                • resamundefined
                                  resam
                                  I successfully connected (default settings) with a piece of 25cm ethernet cable (without the shield mesh - just the twisted pairs + outer insulation) soldered to pin headers on both sides. I paid no attention to the twisted pairs and just chose a good color mapping that worked nicely with the physical world.
                                  I haven't run any prints yet, but DSF is working and M122 shows no SPI errors, and plenty of successful transfers after 30min idling. Jogging the axis works via PanelDue and DWC perfectly.
                                  A snippet of my M122:
                                  RepRapFirmware for Duet 2 SBC version 3.2.2 running on Duet 2 1.02 or later + SBC (SBC mode)
                                  Static ram: 17008
                                  Dynamic ram: 60600 of which 72 recycled
                                  Never used RAM 34400, free system stack 160 words
                                  Last reset 00:16:35 ago, cause: power up
                                  === SBC interface ===
                                  State: 4, failed transfers: 0
                                  Last transfer: 5ms ago
                                  RX/TX seq numbers: 34553/34553
                                  SPI underruns 0, overruns 0
                                  Number of disconnects: 0, IAP RAM available 0x0dad4
                                  Buffer RX/TX: 0/0-0
                                  === Duet Control Server ===
                                  Duet Control Server v3.2.2
                                  Code buffer space: 4096
                                  Full transfers per second: 35.44
                                  Maximum length of RX/TX data transfers: 2560/512
                                  • keyz182undefined
                                    keyz182
                                    I had run quite a lot of successful prints previously on 3.2.
                                    Switched to 3.3 beta today to do some testing and found prints stopping after a layer or two, and logs complaining about SPI. I think I read that 3.3 is more vocal about SPI errors, so just making sure hardware is good before looking at software, especially when it's beta.
                                    keyz182undefined 1 Reply Last reply Reply Quote 0
                                    • GeneRisiundefined
                                      GeneRisi @resam
                                      @resam Is anyone ordering a batch of these boards and doesn't need all 10 of them? Please PM me if you want to sell one. I'm in the US. Thanks!
                                      • keyz182undefined
                                        keyz182 @keyz182
                                        FYI - I found adding a simple ferrite core to the cabling from the Duet to the Pi has silenced the SPI errors.
                                        I have a ~10CM run with shielded cables, but I guess it's still noisy there, but that core appears to have reduced the noise enough to bump the frequency back to 4MHz. Haven't tried the full 8MHz yet as I want to get some prints finished before I do anymore testing.
                                        gloomyandyundefined 1 Reply Last reply Reply Quote 0
                                        • gloomyandyundefined
                                          gloomyandy @keyz182
                                          @keyz182 Could you post details of the type of core you used and perhaps a picture of how you have it installed?
                                          • keyz182undefined
                                            keyz182 @gloomyandy
                                            @gloomyandy can't get to the back of the printer right now. As for which ones, I litterally typed "ferrite core" into Amazon and bought the first ones that came up. Just clipped them straight onto the cable. I did have to trim the insulation a bit as it was a bit too fat ( I have a pair of 4core shielded cables, so trimmed the outer insulation). If you have loose cables, they should just fit, all of them through the one core.
                                            It came to mind as I had to do the same with my Paneldue. It's got maybe a meter of cable to it, and it was very intermittent without the core
