    Duet 2 Ethernet and SBC
    Beta Firmware
    29
    302
    33.5k
    • arhiundefined
      arhi
      weird, I would not expect pad lifting on something like this... anyhow, it's easy fix, good to know ppl need to check the pcb's
      • smoki3undefined
        smoki3
        @wilriker
        After a few releases today I tried 3.2beta4 on my tool changer again because I saw a lot of commits regarding the SBC. It seems to work now. I will now wire everything a do a test print.
        UPDATE: Test print was fine
        A Former User? wilrikerundefined 2 Replies Last reply Reply Quote 1
          A Former User @smoki3
          @smoki3 said in Duet 2 Ethernet and SBC:
          Test print was fine
          with the duex? thats awesome!
          • wilrikerundefined
            wilriker @smoki3
            That's great news!
            @bearer said in Duet 2 Ethernet and SBC:
            I had an (air) print running just fine with DueX5 a while back also but @smoki3 never got to finish the homing sequence with stallGuard. Glad that's working now.
            Manuel
            My Tool Collection
            • resamundefined
              resam
              Since this post is getting rather long, let me summarize briefly and post a few bits that I haven't found here yet:
              @deadwood83 has made a nice PCB nice PCB here with PCB and schematic sources in EasyEDA. It fits nicely on a Duet 2 WiFi and DuetEthernet without desoldering the existing WiFi module.
              The pins on the PCB are mostly self-explanatory to hook them up to a Raspberry Pi:
              • GND to GND / multiple physical pins
              • SCK to GPIO11 / SPI0 SCLK / Physical Pin 23
              • MOS to GPIO10 / SPI0 MOSI / Physical Pin 19
              • MISO to GPIO9 / SPI0 MISO / Physical Pin 21
              • 3V3 to 3V3/Physical Pin 1 or 17
              • RDY to GPIO25 (TransferReadPin) / Physical Pin 22
              • CS to GPIO8 / SPI0 CE0 / Physical Pin 24
              (see this for a Raspberry Pi pin out table to double check)
              GeneRisiundefined 1 Reply Last reply Reply Quote 3
              • keyz182undefined
                keyz182
                Has anyone got tips on connecting optimally?
                Currently I'm using a 4 core and a 2 core shielded cables, to connect up, with the shield as ground. Still have to drop the SPI speed to 2MHz though.
                When I'm able, I'll rearrange things to reduce the cable length further (about 15cm currently). I've tried to route other wires (steppers etc) away from the Comms cable.
                • resamundefined
                  resam
                  I successfully connected (default settings) with a piece of 25cm ethernet cable (without the shield mesh - just the twisted pairs + outer insulation) soldered to pin headers on both sides. I paid no attention to the twisted pairs and just chose a good color mapping that worked nicely with the physical world.
                  I haven't run any prints yet, but DSF is working and M122 shows no SPI errors, and plenty of successful transfers after 30min idling. Jogging the axis works via PanelDue and DWC perfectly.
                  A snippet of my M122:
                  RepRapFirmware for Duet 2 SBC version 3.2.2 running on Duet 2 1.02 or later + SBC (SBC mode)
                  Static ram: 17008
                  Dynamic ram: 60600 of which 72 recycled
                  Never used RAM 34400, free system stack 160 words
                  Last reset 00:16:35 ago, cause: power up
                  === SBC interface ===
                  State: 4, failed transfers: 0
                  Last transfer: 5ms ago
                  RX/TX seq numbers: 34553/34553
                  SPI underruns 0, overruns 0
                  Number of disconnects: 0, IAP RAM available 0x0dad4
                  Buffer RX/TX: 0/0-0
                  === Duet Control Server ===
                  Duet Control Server v3.2.2
                  Code buffer space: 4096
                  Full transfers per second: 35.44
                  Maximum length of RX/TX data transfers: 2560/512
                  • keyz182undefined
                    keyz182
                    I had run quite a lot of successful prints previously on 3.2.
                    Switched to 3.3 beta today to do some testing and found prints stopping after a layer or two, and logs complaining about SPI. I think I read that 3.3 is more vocal about SPI errors, so just making sure hardware is good before looking at software, especially when it's beta.
                    keyz182undefined 1 Reply Last reply Reply Quote 0
                    • GeneRisiundefined
                      GeneRisi @resam
                      @resam Is anyone ordering a batch of these boards and doesn't need all 10 of them? Please PM me if you want to sell one. I'm in the US. Thanks!
                      • keyz182undefined
                        keyz182 @keyz182
                        FYI - I found adding a simple ferrite core to the cabling from the Duet to the Pi has silenced the SPI errors.
                        I have a ~10CM run with shielded cables, but I guess it's still noisy there, but that core appears to have reduced the noise enough to bump the frequency back to 4MHz. Haven't tried the full 8MHz yet as I want to get some prints finished before I do anymore testing.
                        gloomyandyundefined 1 Reply Last reply Reply Quote 0
                        • gloomyandyundefined
                          gloomyandy @keyz182
                          @keyz182 Could you post details of the type of core you used and perhaps a picture of how you have it installed?
                          • keyz182undefined
                            keyz182 @gloomyandy
                            @gloomyandy can't get to the back of the printer right now. As for which ones, I litterally typed "ferrite core" into Amazon and bought the first ones that came up. Just clipped them straight onto the cable. I did have to trim the insulation a bit as it was a bit too fat ( I have a pair of 4core shielded cables, so trimmed the outer insulation). If you have loose cables, they should just fit, all of them through the one core.
                            It came to mind as I had to do the same with my Paneldue. It's got maybe a meter of cable to it, and it was very intermittent without the core
                              gloomyandy @keyz182
                              @keyz182 Thanks! So I guess it was one of those clip on versions rather than a ferrite ring? Assume you just passed the wires through once?
                              • keyz182undefined
                                keyz182 @gloomyandy
                                @gloomyandy yup, the clip ons, and just the once.
                                • TopperHarleyundefined
                                  TopperHarley
                                  I have ordered some boards from @deadwood83 at JLCPCB.
                                  If you are from Germany and need one, feel free to contact me: https://forum.duet3d.com/topic/22545/3x-duet-2-ethernet-sbc-adapter-to-sell-germany-only
                                  CNCModellerundefined 1 Reply Last reply Reply Quote 0
                                  • CNCModellerundefined
                                    CNCModeller @TopperHarley
                                    Hi @topperharley, I'd like to order some for my Duet ethernet from JLC for myself.
                                    I'm in the UK, but I have no idea how to go about it. Is there a brief summary (for a total JLC noob) of what I need to do? I've created an account but am not sure where to go from there.
                                    Polar Duet3 Mini + 1HCL
                                    https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                                    Wanhao D4S: Duet2
                                    https://forum.duet3d.com/post/296755
                                    K40 Laser, Duet2
                                    https://forum.duet3d.com/post/312082
                                    Wanhao D5S
                                    https://www.youtube.com/CNCModellerUK
                                    GeneRisiundefined 1 Reply Last reply Reply Quote 0
                                      TopperHarley
                                      Hello guys!
                                      I have installed the SBC daughterboard from @deadwood83, because i want to switch to SBC mode later with the next release of RRF. It seem like my printer can't access to my network anymore with the installed daughter board (running standard image Duet2CombinedFirmware.bin 3.2.2).
                                      I was expecting there should be no issues running the standard image with installed SBC daughterboard.
                                      • GeneRisiundefined
                                        GeneRisi @CNCModeller
                                        @cncmodeller I am also a noob to JLC and wonder the same thing!
                                        • arhiundefined
                                          arhi @GeneRisi
                                          @generisi maybe open a topic in "Off Topic" category ... that would make much more sense.
                                          JLC service works just like any other pcb manufacturing service, you send them gerbers for layers and drill files for holes and they make you pcb's... if you want assembly you generate BOM files and position files (what and where) and they get you the parts and solder them on boards ... everything is properly documented on their site
                                          • GeneRisiundefined
                                            GeneRisi @arhi
                                            @arhi Thank you very much! I just ordered 5 boards
