    3D GCode Viewer integrated with DWC
    Duet Web Control wishlist
    42
    284
    30.5k
    • Sindariusundefined
      Sindarius @Exerqtor
      @Exerqtor I'd have to play with it because the hit testing may ignore the transparent area and honestly I tend to think people wouldn't leave it on after cancelling objects because it is so easy to misclick and potentially cancel something you didn't mean to (even with the dialog).
      Exerqtorundefined 1 Reply Last reply Reply Quote 0
      • Exerqtorundefined
        Exerqtor @Sindarius
        @Sindarius said in 3D GCode Viewer integrated with DWC:
        Yeah that's a valid point πŸ˜…
        Sindariusundefined 1 Reply Last reply Reply Quote 0
          Sindarius @Exerqtor
          @Exerqtor I do like the solid edges idea tho so I’ll probably do that
            Sindarius
            Starting to put some work into CNC gcode files.
            Tried my solid rendering to see how a 3d carve would look.
            Edit : A couple extra pics
              Sindarius
              Just pushed out a new release with support for G2/G3.
              https://github.com/Sindarius/DWC_GCodeViewer_Plugin/releases/tag/0.11.0
              • bastienundefined
                bastien
                sorry for my stupid question, how install your viewer, besose i send your dwc in my duet and a not viewer menu
                  jay_s_uk
                  @Sindarius
                  You may want to edit your first post and remove the link the original DWC builds, replacing it with a link to the new github repo releases page
                    Sindarius @jay_s_uk
                    @jay_s_uk that’s probably a good idea since that dates to Sept 2019 😱
                    Edit : Updated. It may be time time to start a new thread...
                      Sindarius @bastien
                      @bastien which version of dwc are you running?? The latest version of my viewer is now a plugin that runs on dwc 3.2-beta 4.
                      • bastienundefined
                        bastien
                        i just install 3.2, i viewer in sub menu in files but no in main menu
                        bastienundefined 1 Reply Last reply Reply Quote 0
                        • bastienundefined
                          bastien @bastien
                          @bastien said in 3D GCode Viewer integrated with DWC:
                          it's ok, i re install plug in and start in new plug in menu 😊 😊
                          • DIY-O-Sphereundefined
                            DIY-O-Sphere
                            @Sindarius
                            Are there known issues with the latest version on a maestro?
                            Cant't get it working anymore. (RRF 3.2_b4 +0.11.1)
                            The previous versions of fw and plugin worked. (guess RRF 3.2_b2 +0.6.5)
                            (UTC+1)
                              Sindarius @DIY-O-Sphere
                              @DIY-O-Sphere I pulled down and installed the 3.2-beta4 that is on GitHub, I normally run my own build, and was able to install my plugin without any problems. Make sure you are pulling the latest version of my plugin from the github releases page https://github.com/Sindarius/DWC_GCodeViewer_Plugin/releases. I don't believe the firmware version itself should have any play since the plugin is a javascript solution that runs in DWC itself.
                              Just double check the following to make sure you are on the latest
                              DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                                DIY-O-Sphere @Sindarius
                                @Sindarius
                                After de-energising and powering up everything is working now....
                                A simple sw-reset after the update was not enough.....
                                (UTC+1)
                                • PCRundefined
                                  PCR
                                  @Sindarius
                                  File processed with arcwelder
                                  01_SP2_Unterschale_DQ2_PET_0.3mm_1h39m.gcode.txt
                                  • PCRundefined
                                    PCR
                                      Sindarius @PCR
                                      @PCR I’ll take a look at the file. Those are some impressive arcs πŸ˜„
                                      • PCRundefined
                                        PCR
                                        no rush πŸ˜‰ was more like a little note
                                          Sindarius @PCR
                                          @PCR This probably looks better.
                                            Sindarius
                                            G3 fix is in RC2
                                            https://github.com/Duet3D/DuetWebControl/releases/tag/3.2.0-rc2
