    How is warranty service provided?
    776
    • RyanPundefined
      RyanP @jens55
      @jens55
      Don't disagree with any of this. Just don't know IF there was a short. I was using this printer all weekend.
      Btw, Creality Ender 5 Plus, original bed.
      CR10S, August 2018
      Anycubic Photon S December 2019
      Ender 5 Feb 2020
      Ender 5 Plus May 2020
      Anycubic Photon Mono X Nov 2020
      https://3dimensiongames.com/
        How do the solder points on the bottom side of the board look?
        RyanPundefined 1 Reply Last reply Reply Quote 0
        • RyanPundefined
          RyanP @Phaedrux
          Clean and shiny.
          CR10S, August 2018
          Ender 5 Feb 2020
            How would you like to proceed? Do you want to try replacing the terminals yourself, or is Digitmakers able to do a warranty exchange?
            Either way, definitely check the resistance of the bed and double check for any potential shorts so that it doesn't happen again.
            • zaptaundefined
              zapta @RyanP
              @RyanP, a side note for the future, you may want to look into adding a solid state relay or an external power mosfet for the bed.
              This will offload the high currents from your duet.
              IIRC, there is an official duet web page that discusses this option but I can't find it at the moment.
              Phaedruxundefined RyanPundefined 2 Replies Last reply Reply Quote 0
                Phaedrux Moderator @zapta
                @zapta https://duet3d.dozuki.com/Wiki/Choosing_a_bed_heater
                • RyanPundefined
                  RyanP
                  Perfect guys.
                  @Phaedrux regarding unit. Digitmakers simply directed me to the online warranty submission. I have completed all of that but don't know how the approval process works.
                  Basically I simply want my largest printer back up and running, for the next week and a half so I can fill more orders.
                  CR10S, August 2018
                  Ender 5 Feb 2020
                  • RyanPundefined
                    RyanP @zapta
                    @zapta
                    I'm starting a Hevo build. As I go through that I will be doing small, more intermediate settings and mods to my printers. One major thing I am waiting until the Christmas rush is over is to do the 3.x firmware update. Figured I'd to all three current printers during the Hevo build.
                    CR10S, August 2018
                    Ender 5 Feb 2020
                      Phaedrux Moderator @RyanP
                      @RyanP In that case consider this your approval. Include a link to this thread when you submit your form.
                      • RyanPundefined
                        RyanP @Phaedrux
                        @Phaedrux said in How is warranty service provided?:
                        I supplied this link in the form from the get go, I just don't know what the next step is.
                        CR10S, August 2018
                        Ender 5 Feb 2020
                        • zaptaundefined
                          zapta @RyanP
                          @RyanP said in How is warranty service provided?:
                          My only printer is HEVO and it's reliable and served me very well. I like its simplicity. The main design change I made was switching from bowden to a direct extruder. Couldn't get decent print quality with that 600mm bowden tube despite many attempts and design variations.
                          If I would build another one, I would probably look for a linear rail based design, at least for the X axis, with the expectation that it will be stiffer than the current dual 8mm steel rods.
                          • RyanPundefined
                            RyanP @zapta
                            @zapta
                            I'm going to build mine in stages. First is a 400x400x500 frame kit.
                            Linear rails is my goal across the board. I'm looking consistency, and predictably. Something I am only partially getting with my current spread of creality based printers.
                            I converted all my current printers to DD this year and will never go back to Bowden.
                            CR10S, August 2018
                            Ender 5 Feb 2020
                              droftarts administrators @RyanP
                              Usually, you fill in the vendor's form, with a link to this thread to show warranty approval. Then the vendor emails you about returns and replacement.
                              • RyanPundefined
                                RyanP
                                My dealer, Digitmakers in Toronto, just emailed me and advised to bring in the board in for replacement. Thanks @Phaedrux . You guys and Duet3D are the best.
                                I can't imagine not using Duet boards in any of my printers.
                                CR10S, August 2018
                                Ender 5 Feb 2020
