    How is warranty service provided?
    776
      droftarts administrators @RyanP
      @RyanP Are you sure the bed hasn't shorted out? With a blown fuse, as well as the melted terminal, it strikes me that something was pulling some serious current. What bed is it, or what machine is this on? What voltage is the machine running on? If possible, test the resistance of the bed.
      You can replace the screw terminal; see here for replacements https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Screw_Terminals
      You will need a big soldering iron to desolder/resolder these terminals. They go into some large tracks.
      • jens55undefined
        jens55
        I agree with droftarts, no reason for the fuse to blow if there was just a poor connection.
        I am a little suspicious of the semiconductor right next to the connector - TR2 marked 'bed heat'. Might just be detritus coming off the bubbling connector but might bear looking into.
        RyanPundefined 1 Reply Last reply Reply Quote 0
        • RyanPundefined
          RyanP @jens55
          @jens55
          Don't disagree with any of this. Just don't know IF there was a short. I was using this printer all weekend.
          Btw, Creality Ender 5 Plus, original bed.
          CR10S, August 2018
          Anycubic Photon S December 2019
          Ender 5 Feb 2020
          Ender 5 Plus May 2020
          Anycubic Photon Mono X Nov 2020
          https://3dimensiongames.com/
            How do the solder points on the bottom side of the board look?
            • RyanPundefined
              RyanP @Phaedrux
              Clean and shiny.
              CR10S, August 2018
              Ender 5 Feb 2020
                How would you like to proceed? Do you want to try replacing the terminals yourself, or is Digitmakers able to do a warranty exchange?
                Either way, definitely check the resistance of the bed and double check for any potential shorts so that it doesn't happen again.
                • zaptaundefined
                  zapta @RyanP
                  @RyanP, a side note for the future, you may want to look into adding a solid state relay or an external power mosfet for the bed.
                  This will offload the high currents from your duet.
                  IIRC, there is an official duet web page that discusses this option but I can't find it at the moment.
                  Phaedruxundefined RyanPundefined 2 Replies Last reply Reply Quote 0
                    Phaedrux Moderator @zapta
                    @zapta https://duet3d.dozuki.com/Wiki/Choosing_a_bed_heater
                    • RyanPundefined
                      RyanP
                      Perfect guys.
                      @Phaedrux regarding unit. Digitmakers simply directed me to the online warranty submission. I have completed all of that but don't know how the approval process works.
                      Basically I simply want my largest printer back up and running, for the next week and a half so I can fill more orders.
                      CR10S, August 2018
                      Ender 5 Feb 2020
                      • RyanPundefined
                        RyanP @zapta
                        @zapta
                        I'm starting a Hevo build. As I go through that I will be doing small, more intermediate settings and mods to my printers. One major thing I am waiting until the Christmas rush is over is to do the 3.x firmware update. Figured I'd to all three current printers during the Hevo build.
                        CR10S, August 2018
                        Ender 5 Feb 2020
                          Phaedrux Moderator @RyanP
                          @RyanP In that case consider this your approval. Include a link to this thread when you submit your form.
                          • RyanPundefined
                            RyanP @Phaedrux
                            @Phaedrux said in How is warranty service provided?:
                            I supplied this link in the form from the get go, I just don't know what the next step is.
                            CR10S, August 2018
                            Ender 5 Feb 2020
                            • zaptaundefined
                              zapta @RyanP
                              @RyanP said in How is warranty service provided?:
                              My only printer is HEVO and it's reliable and served me very well. I like its simplicity. The main design change I made was switching from bowden to a direct extruder. Couldn't get decent print quality with that 600mm bowden tube despite many attempts and design variations.
                              If I would build another one, I would probably look for a linear rail based design, at least for the X axis, with the expectation that it will be stiffer than the current dual 8mm steel rods.
                              • RyanPundefined
                                RyanP @zapta
                                @zapta
                                I'm going to build mine in stages. First is a 400x400x500 frame kit.
                                Linear rails is my goal across the board. I'm looking consistency, and predictably. Something I am only partially getting with my current spread of creality based printers.
                                I converted all my current printers to DD this year and will never go back to Bowden.
                                CR10S, August 2018
                                Ender 5 Feb 2020
                                  Usually, you fill in the vendor's form, with a link to this thread to show warranty approval. Then the vendor emails you about returns and replacement.
                                  • RyanPundefined
                                    RyanP
                                    My dealer, Digitmakers in Toronto, just emailed me and advised to bring in the board in for replacement. Thanks @Phaedrux . You guys and Duet3D are the best.
                                    I can't imagine not using Duet boards in any of my printers.
                                    CR10S, August 2018
                                    Ender 5 Feb 2020
