    Cant find Endstop status on DWC
    Duet Web Control wishlist
    10
    21
    1.6k
    • 3DPrintingWorldundefined
      3DPrintingWorld
      I just updated to RRF 3.2 and now I can not find the endstop status screen on DWC. Previously the status was shown under the settings menu in the "Machines-specific" screen but it is not longer shown since I updated firmware. Did it get moved somewhere?
      jay_s_ukundefined 1 Reply Last reply Reply Quote 2
        jay_s_uk @3DPrintingWorld
        @3DPrintingWorld it's been removed in 3.2
        Use M119 or the object model
          3DPrintingWorld
          Ok, I cant say I understand why it would be removed. M119 is very weak, hardly a replacement for visual status on the screen. I am not familiar with what the object model is but I hope it will fill the void.
          • fcwiltundefined
            fcwilt @3DPrintingWorld
            @3DPrintingWorld said in Cant find Endstop status on DWC:
            With version 3.2 you can view the object model in the Settings section of DWC.
            3DPrintingWorldundefined 1 Reply Last reply Reply Quote 0
              3DPrintingWorld @fcwilt
              @fcwilt Can you explain "object model" as I am unable to find any reference information or find it on DWC.
                Phaedrux Moderator @3DPrintingWorld
                @3DPrintingWorld https://duet3d.dozuki.com/Wiki/Object_Model_of_RepRapFirmware
                Does this help? Imagine it as a record of the current state of the machine.
                • OwenDundefined
                  OwenD
                  The object model browser probably isn't much use in this instance as it doesn't live update.
                  It will show the state when you open the browser.
                  To check you can use M119 or send
                  echo sensors.endstops[0].triggered
                  Where 0=X, 1=Y etc
                    A Former User
                    You might check out the macro from OwenD here https://forum.duet3d.com/topic/15420/object-model-endstop-switches/3
                    For me that works nicely! Thanks everybody
                      3DPrintingWorld
                      Glad you can check status with the M119 but I'm confused as to why the visual status has been removed as it was a nice feature.
                      fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 1
                      • fcwiltundefined
                        Here is where the Object Model state can be viewed BUT it is only in firmware 3.2 - as I recall.
                        There is a "refresh" button you can use to update to the current state of the system.
                          Indeed. And it should be making a comeback.
                            deckingman @Phaedrux
                            @Phaedrux said in Cant find Endstop status on DWC:
                            If you have the ear of the relevant person responsible, tell them that it would be even better if one could see the status of the ends stop as they are assigned to axes, rather than by their index number. When they were displayed, it was by index number and it can be a real pain to find out which index number corresponds to which axis. It is almost impossible to work out the logic.
                            3DPrintingWorldundefined 1 Reply Last reply Reply Quote 2
                              3DPrintingWorld @deckingman
                              @deckingman I agree with you, that would be a nice addition!
                              • Adamfilipundefined
                                Adamfilip
                                I feel just having a Small Dot Next to the XYZ and Probe areas would be very helpful
                                to have a quick visualization of endstop status
                                endstops.jpg image url)
                                deckingmanundefined 1 Reply Last reply Reply Quote 12
                                • Chrissundefined
                                  Chriss
                                  My voice on this feature request! This is a very handsome solution. 😉
                                    deckingman @Adamfilip
                                    @Adamfilip That gets my vote too - a very elegant solution. Hope it can be implemented.........
                                    warpsterundefined Adamfilipundefined 2 Replies Last reply Reply Quote 0
                                    • warpsterundefined
                                      warpster @deckingman
                                      That would be helpful. There are many docs around that say to reference the endstop status in the DWC but all of that documentation is wrong and confusing to a new user at this point. I think the proposed solution would be a great addition!
                                      By the way I do not have the Object Model choice under Settings on 3.2 so is that an addon?
                                      • fcwiltundefined
                                        fcwilt @warpster
                                        @warpster said in Cant find Endstop status on DWC:
                                        It's a plug-in that needs to be started.
                                        Navigate in DWC to here and you should see the start buttons on the right side.
                                        warpsterundefined 1 Reply Last reply Reply Quote 1
                                        • warpsterundefined
                                          warpster @fcwilt
                                          @fcwilt got it, thanks
                                            Adamfilip @deckingman
                                            +1 bumping
                                            Wish this feature can be implemented. Feeling like DWC never seems to get any love or improvements, just my impression. (hope im wrong)
                                            Adamfilipundefined 1 Reply Last reply Reply Quote 0
