    DuetLapse3
    Third-party software
    20
    296
    30.7k
    • JohnOCFIIundefined
      JohnOCFII @stuartofmt
      @stuartofmt Excellent way to carry on Danal's work!
      • PCRundefined
        PCR
        @stuartofmt
        wget https://github.com/stuartofmt/DuetLapse3/blob/main/DuetLapse3.py
        should be changed to
        wget https://github.com/stuartofmt/DuetLapse3/raw/main/DuetLapse3.py
        stuartofmtundefined 1 Reply Last reply Reply Quote 0
        • PCRundefined
          PCR
          This post is deleted!
          • PCRundefined
            PCR
            @stuartofmt I am running the LPC SBC Port of RRF. But i can not connect to my Pi.
            here is my Object Model
            192.168.140.126 The printer at 192.168.140.126 did not respond
            192.168.140.126 Check the ip address or logical printer name is correct
            192.168.140.126 Duet software version must be at RRF3 or above and suppotr rr_model
            Best
              jay_s_uk
              @stuartofmt
              The duet+SBC doesn't support the object model and uses machine/status instead.
              The DuetWebAPI handled both methods of obtaining information.
              • stuartofmtundefined
                stuartofmt @PCR
                @PCR
                Instructions on wget for download fixed. Thanks!
                  stuartofmt @jay_s_uk
                  @jay_s_uk
                  Let me take a look at the SBC situation (which I do not own). I was under the impression that /machine/status was replaced (to be?) by rr_model as the preferred method.
                  It may take me a few of days to figure out.
                    jay_s_uk @stuartofmt
                    @stuartofmt its the other way round.
                    rr_model is replaced by machine/status in SBC situations
                      @jay_s_uk
                      OK - thx. It's not difficult but I will need some help testing.
                        @stuartofmt
                        i can provide a current 3.2 output from machine/status if needed.
                        i'm sure @PCR would do some testing for you
                        stuartofmtundefined 1 Reply Last reply Reply Quote 1
                          @jay_s_uk
                          That would be very helpful (much better than closing my eyes and imagining) - thanks!
                            jay_s_uk
                            {"boards":[{"bootloaderFileName":null,"canAddress":0,"directDisplay":null,"firmwareDate":"2021-01-05","firmwareFileName":"Duet3Firmware_Mini5plus.uf2","firmwareName":"RepRapFirmware for Duet 3 Mini 5\u002B","firmwareVersion":"3.2","iapFileNameSBC":"Duet3_SBCiap32_Mini5plus.bin","iapFileNameSD":"Duet3_SDiap32_Mini5plus.bin","maxHeaters":32,"maxMotors":7,"mcuTemp":{"current":-273.15,"min":-273.15,"max":-273.15},"name":"Duet 3 Mini 5\u002B","shortName":"Mini5plus","state":"unknown","supports12864":true,"supportsDirectDisplay":true,"uniqueId":"P2P4H-PA67A-G65J0-40TFU-L2D0Z-ZTS4L","v12":{"current":0,"min":0,"max":0},"vIn":{"current":12.3,"min":0,"max":12.3}}],"directories":{"filaments":"0:/filaments/","firmware":"0:/sys/","gCodes":"0:/gcodes/","macros":"0:/macros/","menu":"0:/menu/","scans":"0:/scans/","system":"0:/sys/","web":"0:/www/"},"fans":[{"actualValue":0,"blip":0.1,"frequency":0,"max":1,"min":0.1,"name":"","requestedValue":0,"rpm":-1,"thermostatic":{"heaters":[],"highTemperature":null,"lowTemperature":null}},{"actualValue":0,"blip":0.1,"frequency":0,"max":1,"min":0.1,"name":"","requestedValue":1,"rpm":-1,"thermostatic":{"heaters":[1],"highTemperature":45,"lowTemperature":45}}],"heat":{"bedHeaters":[0,-1],"chamberHeaters":[-1,-1],"coldExtrudeTemperature":160,"coldRetractTemperature":90,"heaters":[{"active":0,"current":15.4,"max":120,"min":-273.1,"model":{"deadTime":2.2,"enabled":true,"gain":114,"heatingRate":0.219,"inverted":false,"maxPwm":1,"pid":{"overridden":false,"p":1.5,"i":0.1,"d":2.2,"used":true},"standardVoltage":12.2,"timeConstant":520.5,"timeConstantFansOn":520.5},"monitors":[{"action":0,"condition":"tooHigh","limit":120},{"action":null,"condition":"disabled","limit":null},{"action":null,"condition":"disabled","limit":null}],"name":null,"sensor":0,"standby":0,"state":"off"},{"active":0,"current":15.9,"max":285,"min":-273.1,"model":{"deadTime":7,"enabled":true,"gain":407.9,"heatingRate":2.343,"inverted":false,"maxPwm":1,"pid":{"overridden":false,"p":0,"i":0,"d":0.2,"used":true},"standardVoltage":12.2,"timeConstant":174.1,"timeConstantFansOn":152.7},"monitors":[{"action":0,"condition":"tooHigh","limit":285},{"action":null,"condition":"disabled","limit":null},{"action":null,"condition":"disabled","limit":null}],"name":null,"sensor":1,"standby":0,"state":"active"}]},"httpEndpoints":[],"inputs":[{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"HTTP","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"Marlin","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Telnet","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"File","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"Marlin","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"USB","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Aux","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":true,"name":"Trigger","stackDepth":1,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Queue","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"LCD","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"SBC","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Daemon","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Aux2","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Autopause","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false}],"job":{"build":null,"duration":null,"file":{"filament":[],"fileName":null,"firstLayerHeight":0,"generatedBy":null,"height":0,"lastModified":null,"layerHeight":0,"numLayers":0,"printTime":null,"simulatedTime":null,"size":0,"thumbnails":[]},"filePosition":0,"firstLayerDuration":null,"lastDuration":0,"lastFileName":null,"lastFileAborted":false,"lastFileCancelled":false,"lastFileSimulated":false,"layer":null,"layerTime":null,"layers":[],"timesLeft":{"filament":null,"file":null,"layer":null},"warmUpDuration":null},"limits":{"axes":8,"axesPlusExtruders":8,"bedHeaters":2,"boards":5,"chamberHeaters":2,"drivers":14,"driversPerAxis":4,"extruders":5,"extrudersPerTool":5,"fans":16,"gpInPorts":16,"gpOutPorts":32,"heaters":32,"heatersPerTool":2,"monitorsPerHeater":3,"restorePoints":6,"sensors":56,"spindles":2,"tools":50,"trackedObjects":32,"triggers":16,"volumes":2,"workplaces":9,"zProbeProgramBytes":8,"zProbes":4},"messages":[],"move":{"axes":[{"acceleration":1000,"babystep":0,"current":1200,"drivers":["0.4"],"homed":false,"jerk":1000,"letter":"X","machinePosition":0,"max":270,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":0,"minProbed":false,"speed":6000,"stepsPerMm":100,"userPosition":0,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]},{"acceleration":1000,"babystep":0,"current":1200,"drivers":["0.3"],"homed":false,"jerk":1000,"letter":"Y","machinePosition":0,"max":260,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":0,"minProbed":false,"speed":6000,"stepsPerMm":100,"userPosition":0,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]},{"acceleration":200,"babystep":0,"current":1200,"drivers":["0.1","0.2"],"homed":false,"jerk":200,"letter":"Z","machinePosition":0,"max":350,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":0,"minProbed":false,"speed":300,"stepsPerMm":400,"userPosition":0,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]}],"calibration":{"final":{"deviation":0,"mean":0},"initial":{"deviation":0,"mean":0},"numFactors":0},"compensation":{"fadeHeight":null,"file":null,"meshDeviation":null,"probeGrid":{"xMin":15,"xMax":230,"xSpacing":20,"yMin":15,"yMax":230,"ySpacing":20,"radius":-1},"skew":{"compensateXY":true,"tanXY":0,"tanXZ":0,"tanYZ":0},"type":"none"},"currentMove":{"acceleration":0,"deceleration":0,"laserPwm":null,"requestedSpeed":0,"topSpeed":0},"daa":{"enabled":false,"minimumAcceleration":10,"period":0},"extruders":[{"acceleration":250,"current":1000,"driver":"0.0","filament":"","factor":1,"jerk":120,"microstepping":{"interpolated":true,"value":16},"nonlinear":{"a":0,"b":0,"upperLimit":0.2},"position":0,"pressureAdvance":0,"rawPosition":0,"speed":1200,"stepsPerMm":837}],"idle":{"timeout":30,"factor":0.3},"kinematics":{"forwardMatrix":[[1,0,0],[0,1,0],[0,0,1]],"inverseMatrix":[[1,0,0],[0,1,0],[0,0,1]],"tiltCorrection":{"correctionFactor":1,"lastCorrections":[0,0],"maxCorrection":10,"screwPitch":0.5,"screwX":[-130,400],"screwY":[150,150]},"name":"cartesian"},"printingAcceleration":10000,"speedFactor":1,"travelAcceleration":10000,"virtualEPos":0,"workplaceNumber":0,"workspaceNumber":1},"network":{"corsSite":null,"hostname":"duet3","interfaces":[{"activeProtocols":[],"actualIP":"192.168.1.31","configuredIP":"192.168.1.31","firmwareVersion":null,"gateway":"192.168.1.1","mac":"B8:27:EB:C9:9C:1A","numReconnects":null,"signal":null,"speed":null,"subnet":"255.255.255.0","type":"wifi"}],"name":"duet3"},"plugins":[{"dwcFiles":["GCodeViewer.10bd9549.js","GCodeViewer.88004336.css"],"sbcFiles":[],"rrfFiles":[],"pid":-1,"name":"GCodeViewer","author":"Juan Rosario","version":"0.11.1","license":"LGPL-3.0-or-later","sourceRepository":null,"dwcVersion":"3.2.0-beta4","dwcDependencies":[],"dwcWebpackChunk":"GCodeViewer","sbcRequired":false,"sbcDsfVersion":null,"sbcData":{},"sbcExecutable":null,"sbcExecutableArguments":null,"sbcOutputRedirected":true,"sbcPermissions":[],"sbcPackageDependencies":[],"sbcPluginDependencies":[],"rrfVersion":null}],"scanner":{"progress":0,"status":"D"},"sensors":{"analog":[{"lastReading":15.4,"name":"","type":"thermistor"},{"lastReading":15.9,"name":"","type":"thermistor"}],"endstops":[{"triggered":false,"type":"inputPin","probeNumber":null},{"triggered":false,"type":"inputPin","probeNumber":null},null],"filamentMonitors":[],"gpIn":[],"probes":[{"calibrationTemperature":25,"deployedByUser":false,"disablesHeaters":false,"diveHeight":2,"lastStopHeight":0,"maxProbeCount":5,"offsets":[-27.3,3.5],"recoveryTime":0,"speed":2,"temperatureCoefficient":0,"temperatureCoefficients":[0,0],"threshold":1000,"tolerance":0.02,"travelSpeed":333.3,"triggerHeight":3.553,"type":1,"value":[671]}]},"spindles":[{"active":0,"current":0,"frequency":0,"min":60,"max":10000,"tool":-1},{"active":0,"current":0,"frequency":0,"min":60,"max":10000,"tool":-1}],"state":{"atxPower":null,"beep":null,"currentTool":0,"displayMessage":"","dsfVersion":"3.2.0","gpOut":[{"pwm":0}],"laserPwm":null,"logFile":null,"logLevel":"off","messageBox":null,"machineMode":"FFF","msUpTime":503,"nextTool":0,"powerFailScript":"","previousTool":-1,"restorePoints":[{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1}],"status":"idle","time":"2021-01-14T17:44:25","upTime":363424},"tools":[{"active":[0],"axes":[[0],[1]],"extruders":[0],"fans":[0],"filamentExtruder":0,"heaters":[1],"mix":[1],"name":"","number":0,"offsets":[0,0,0],"offsetsProbed":0,"retraction":{"extraRestart":0,"length":5,"speed":40,"unretractSpeed":40,"zHop":0.5},"standby":[0],"state":"active"}],"userSessions":[],"userVariables":[],"volumes":[{"capacity":29077254144,"freeSpace":20587024384,"mounted":true,"name":null,"openFiles":null,"path":"/","speed":null},{"capacity":2143281152,"freeSpace":2028986368,"mounted":true,"name":null,"openFiles":null,"path":"/boot","speed":null}]}
                              stuartofmt
                              Could someone please try this? It's a test script for the SBC calls. It's read only with the exception of a M117 'Test of SBC' which should show up in DWC.
                              Once its placed in a directory permissions will need to be changed.
                              chmod +x ./SBCTEST.py
                              it can then be run with the following command
                              python3 ./SBCTEST.py -duet <ipaddress of your SBC printer>
                              with a bit of luck it will report success, in any case - if the resultant SBCTEST.log file can be posted back, that would be a great help.
                              I've tested it on my non SBC duet - there may be some syntax errors in the unexercised code - but I hope not 🙂
                              If there are then a screen shot would be helpful.
                              [SBCTEST.py]
                              • PCRundefined
                                PCR
                                Can do it tomorrow! Thank you
                                  @stuartofmt said in DuetLapse3:
                                  localhost Determine API Version
                                  localhost Testing: rr_model at address localhost
                                  localhost http://localhost/rr_model?key=boards
                                  localhost
                                  localhost Testing: /machine/system at address localhost
                                  localhost http://localhost/machine/status
                                  localhost
                                  localhost API model is: machine   Version is: 3
                                  localhost Status is :idle
                                  localhost Layer is :0
                                  Traceback (most recent call last):
                                    File "./SBCTEST.py", line 147, in <module>
                                      logger.info('Send Gcode result: '+sendDuetGcode(apiModel, 'M117 Test of SBC'))
                                    File "./SBCTEST.py", line 122, in sendDuetGcode
                                      r = requests.get.post(URL, data=command)
                                  AttributeError: 'function' object has no attribute 'post'
                                  Nothing is displayed on DWC
                                    @jay_s_uk
                                    Aghhhh - A definite typo ... Try this please.
                                    The rest looks good.
                                    [SBCTEST.py]
                                    PCRundefined 1 Reply Last reply Reply Quote 0
                                    • PCRundefined
                                      PCR @stuartofmt
                                      @stuartofmt
                                      192.168.140.126 Determine API Version
                                      192.168.140.126 Testing: rr_model at address 192.168.140.126
                                      192.168.140.126 http://192.168.140.126/rr_model?key=boards
                                      192.168.140.126
                                      192.168.140.126 Testing: /machine/system at address 192.168.140.126
                                      192.168.140.126 http://192.168.140.126/machine/status
                                      192.168.140.126
                                      192.168.140.126 API model is: machine   Version is: 3
                                      192.168.140.126 Status is :processing
                                      192.168.140.126 Layer is :0
                                      --- Logging error ---
                                        File "/usr/lib/python3.7/logging/__init__.py", line 1034, in emit
                                          msg = self.format(record)
                                        File "/usr/lib/python3.7/logging/__init__.py", line 880, in format
                                          return fmt.format(record)
                                        File "/usr/lib/python3.7/logging/__init__.py", line 619, in format
                                          record.message = record.getMessage()
                                        File "/usr/lib/python3.7/logging/__init__.py", line 380, in getMessage
                                          msg = msg % self.args
                                      TypeError: not all arguments converted during string formatting
                                      Call stack:
                                        File "./sbctest.py", line 147, in <module>
                                        File "./sbctest.py", line 127, in sendDuetGcode
                                          logger.info("gCode command return code = ",r.status_code)
                                      Message: 'gCode command return code = '
                                      Arguments: (405,)
                                      Call stack:
                                      Arguments: (405,)
                                      192.168.140.126 Method Not Allowed
                                      TypeError: can only concatenate str (not "int") to str
                                        stuartofmt
                                        @PCR @jay_s_uk
                                        Thanks - there was a silly formatting error (now fixed) but underlying that it looks like there was an http 405 error returned.
                                        I've added a two more version of the send gcode function to try - hopefully one of them works. Unfortunately the documentation and other examples (which purport to work) are somewhat vague on this aspect ....
                                        ALSO - if you are running RRF3.2 the default behavior for CORS seems to have changed. With another program I am using (DueUI) - I had to add the following to config.sys (up front in the network section) - after the upgrade. BUT DuetLapse was unaffected. It MAY be different on SBC.
                                        I'd suggest first trying "as is" but if this script still does not work with one of the methods (depending on what the errors are) - the CORS thing may need to be looked into.
                                        M586 C"*"                                     ;enable CORS
                                        New Test Script is here
                                        [SBCTEST.py]
                                        • fractalengineerundefined
                                          fractalengineer
                                          Awesome Stuart, thanks for carrying on Danal's work
                                          Looks well documented too, I'll give it a shot over the weekend.
                                          Very neat of you to handle issues outside of your own setup too
                                          Do you think in it's current state this could realistically be implemented as a plugin in DWC for a possible GUI?
                                          Railcore II ZL
                                          stuartofmtundefined 1 Reply Last reply Reply Quote 2
                                            stuartofmt @fractalengineer
                                            @fractalengineer
                                            Thanks. As a plugin ? hmmm . I'll have to see what that means / entails. Let me put that as a priority 2 for right now.
                                            Priority 1 is getting SSB working and tidying up some of the logic / behavior surrounding pauses. I did not test that aspect much and its somewhat ambiguous - so stay tuned ...
