    DuetLapse3
    Third-party software
    20
    296
    30.8k
    • stuartofmtundefined
      stuartofmt @jay_s_uk
      @jay_s_uk
      OK - thx. It's not difficult but I will need some help testing.
        jay_s_uk @stuartofmt
        @stuartofmt
        i can provide a current 3.2 output from machine/status if needed.
        i'm sure @PCR would do some testing for you
        stuartofmtundefined 1 Reply Last reply Reply Quote 1
          @jay_s_uk
          That would be very helpful (much better than closing my eyes and imagining) - thanks!
            jay_s_uk
            {"boards":[{"bootloaderFileName":null,"canAddress":0,"directDisplay":null,"firmwareDate":"2021-01-05","firmwareFileName":"Duet3Firmware_Mini5plus.uf2","firmwareName":"RepRapFirmware for Duet 3 Mini 5\u002B","firmwareVersion":"3.2","iapFileNameSBC":"Duet3_SBCiap32_Mini5plus.bin","iapFileNameSD":"Duet3_SDiap32_Mini5plus.bin","maxHeaters":32,"maxMotors":7,"mcuTemp":{"current":-273.15,"min":-273.15,"max":-273.15},"name":"Duet 3 Mini 5\u002B","shortName":"Mini5plus","state":"unknown","supports12864":true,"supportsDirectDisplay":true,"uniqueId":"P2P4H-PA67A-G65J0-40TFU-L2D0Z-ZTS4L","v12":{"current":0,"min":0,"max":0},"vIn":{"current":12.3,"min":0,"max":12.3}}],"directories":{"filaments":"0:/filaments/","firmware":"0:/sys/","gCodes":"0:/gcodes/","macros":"0:/macros/","menu":"0:/menu/","scans":"0:/scans/","system":"0:/sys/","web":"0:/www/"},"fans":[{"actualValue":0,"blip":0.1,"frequency":0,"max":1,"min":0.1,"name":"","requestedValue":0,"rpm":-1,"thermostatic":{"heaters":[],"highTemperature":null,"lowTemperature":null}},{"actualValue":0,"blip":0.1,"frequency":0,"max":1,"min":0.1,"name":"","requestedValue":1,"rpm":-1,"thermostatic":{"heaters":[1],"highTemperature":45,"lowTemperature":45}}],"heat":{"bedHeaters":[0,-1],"chamberHeaters":[-1,-1],"coldExtrudeTemperature":160,"coldRetractTemperature":90,"heaters":[{"active":0,"current":15.4,"max":120,"min":-273.1,"model":{"deadTime":2.2,"enabled":true,"gain":114,"heatingRate":0.219,"inverted":false,"maxPwm":1,"pid":{"overridden":false,"p":1.5,"i":0.1,"d":2.2,"used":true},"standardVoltage":12.2,"timeConstant":520.5,"timeConstantFansOn":520.5},"monitors":[{"action":0,"condition":"tooHigh","limit":120},{"action":null,"condition":"disabled","limit":null},{"action":null,"condition":"disabled","limit":null}],"name":null,"sensor":0,"standby":0,"state":"off"},{"active":0,"current":15.9,"max":285,"min":-273.1,"model":{"deadTime":7,"enabled":true,"gain":407.9,"heatingRate":2.343,"inverted":false,"maxPwm":1,"pid":{"overridden":false,"p":0,"i":0,"d":0.2,"used":true},"standardVoltage":12.2,"timeConstant":174.1,"timeConstantFansOn":152.7},"monitors":[{"action":0,"condition":"tooHigh","limit":285},{"action":null,"condition":"disabled","limit":null},{"action":null,"condition":"disabled","limit":null}],"name":null,"sensor":1,"standby":0,"state":"active"}]},"httpEndpoints":[],"inputs":[{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"HTTP","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"Marlin","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Telnet","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"File","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"Marlin","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"USB","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Aux","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":true,"name":"Trigger","stackDepth":1,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Queue","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"LCD","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"SBC","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Daemon","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Aux2","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Autopause","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false}],"job":{"build":null,"duration":null,"file":{"filament":[],"fileName":null,"firstLayerHeight":0,"generatedBy":null,"height":0,"lastModified":null,"layerHeight":0,"numLayers":0,"printTime":null,"simulatedTime":null,"size":0,"thumbnails":[]},"filePosition":0,"firstLayerDuration":null,"lastDuration":0,"lastFileName":null,"lastFileAborted":false,"lastFileCancelled":false,"lastFileSimulated":false,"layer":null,"layerTime":null,"layers":[],"timesLeft":{"filament":null,"file":null,"layer":null},"warmUpDuration":null},"limits":{"axes":8,"axesPlusExtruders":8,"bedHeaters":2,"boards":5,"chamberHeaters":2,"drivers":14,"driversPerAxis":4,"extruders":5,"extrudersPerTool":5,"fans":16,"gpInPorts":16,"gpOutPorts":32,"heaters":32,"heatersPerTool":2,"monitorsPerHeater":3,"restorePoints":6,"sensors":56,"spindles":2,"tools":50,"trackedObjects":32,"triggers":16,"volumes":2,"workplaces":9,"zProbeProgramBytes":8,"zProbes":4},"messages":[],"move":{"axes":[{"acceleration":1000,"babystep":0,"current":1200,"drivers":["0.4"],"homed":false,"jerk":1000,"letter":"X","machinePosition":0,"max":270,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":0,"minProbed":false,"speed":6000,"stepsPerMm":100,"userPosition":0,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]},{"acceleration":1000,"babystep":0,"current":1200,"drivers":["0.3"],"homed":false,"jerk":1000,"letter":"Y","machinePosition":0,"max":260,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":0,"minProbed":false,"speed":6000,"stepsPerMm":100,"userPosition":0,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]},{"acceleration":200,"babystep":0,"current":1200,"drivers":["0.1","0.2"],"homed":false,"jerk":200,"letter":"Z","machinePosition":0,"max":350,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":0,"minProbed":false,"speed":300,"stepsPerMm":400,"userPosition":0,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]}],"calibration":{"final":{"deviation":0,"mean":0},"initial":{"deviation":0,"mean":0},"numFactors":0},"compensation":{"fadeHeight":null,"file":null,"meshDeviation":null,"probeGrid":{"xMin":15,"xMax":230,"xSpacing":20,"yMin":15,"yMax":230,"ySpacing":20,"radius":-1},"skew":{"compensateXY":true,"tanXY":0,"tanXZ":0,"tanYZ":0},"type":"none"},"currentMove":{"acceleration":0,"deceleration":0,"laserPwm":null,"requestedSpeed":0,"topSpeed":0},"daa":{"enabled":false,"minimumAcceleration":10,"period":0},"extruders":[{"acceleration":250,"current":1000,"driver":"0.0","filament":"","factor":1,"jerk":120,"microstepping":{"interpolated":true,"value":16},"nonlinear":{"a":0,"b":0,"upperLimit":0.2},"position":0,"pressureAdvance":0,"rawPosition":0,"speed":1200,"stepsPerMm":837}],"idle":{"timeout":30,"factor":0.3},"kinematics":{"forwardMatrix":[[1,0,0],[0,1,0],[0,0,1]],"inverseMatrix":[[1,0,0],[0,1,0],[0,0,1]],"tiltCorrection":{"correctionFactor":1,"lastCorrections":[0,0],"maxCorrection":10,"screwPitch":0.5,"screwX":[-130,400],"screwY":[150,150]},"name":"cartesian"},"printingAcceleration":10000,"speedFactor":1,"travelAcceleration":10000,"virtualEPos":0,"workplaceNumber":0,"workspaceNumber":1},"network":{"corsSite":null,"hostname":"duet3","interfaces":[{"activeProtocols":[],"actualIP":"192.168.1.31","configuredIP":"192.168.1.31","firmwareVersion":null,"gateway":"192.168.1.1","mac":"B8:27:EB:C9:9C:1A","numReconnects":null,"signal":null,"speed":null,"subnet":"255.255.255.0","type":"wifi"}],"name":"duet3"},"plugins":[{"dwcFiles":["GCodeViewer.10bd9549.js","GCodeViewer.88004336.css"],"sbcFiles":[],"rrfFiles":[],"pid":-1,"name":"GCodeViewer","author":"Juan Rosario","version":"0.11.1","license":"LGPL-3.0-or-later","sourceRepository":null,"dwcVersion":"3.2.0-beta4","dwcDependencies":[],"dwcWebpackChunk":"GCodeViewer","sbcRequired":false,"sbcDsfVersion":null,"sbcData":{},"sbcExecutable":null,"sbcExecutableArguments":null,"sbcOutputRedirected":true,"sbcPermissions":[],"sbcPackageDependencies":[],"sbcPluginDependencies":[],"rrfVersion":null}],"scanner":{"progress":0,"status":"D"},"sensors":{"analog":[{"lastReading":15.4,"name":"","type":"thermistor"},{"lastReading":15.9,"name":"","type":"thermistor"}],"endstops":[{"triggered":false,"type":"inputPin","probeNumber":null},{"triggered":false,"type":"inputPin","probeNumber":null},null],"filamentMonitors":[],"gpIn":[],"probes":[{"calibrationTemperature":25,"deployedByUser":false,"disablesHeaters":false,"diveHeight":2,"lastStopHeight":0,"maxProbeCount":5,"offsets":[-27.3,3.5],"recoveryTime":0,"speed":2,"temperatureCoefficient":0,"temperatureCoefficients":[0,0],"threshold":1000,"tolerance":0.02,"travelSpeed":333.3,"triggerHeight":3.553,"type":1,"value":[671]}]},"spindles":[{"active":0,"current":0,"frequency":0,"min":60,"max":10000,"tool":-1},{"active":0,"current":0,"frequency":0,"min":60,"max":10000,"tool":-1}],"state":{"atxPower":null,"beep":null,"currentTool":0,"displayMessage":"","dsfVersion":"3.2.0","gpOut":[{"pwm":0}],"laserPwm":null,"logFile":null,"logLevel":"off","messageBox":null,"machineMode":"FFF","msUpTime":503,"nextTool":0,"powerFailScript":"","previousTool":-1,"restorePoints":[{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1}],"status":"idle","time":"2021-01-14T17:44:25","upTime":363424},"tools":[{"active":[0],"axes":[[0],[1]],"extruders":[0],"fans":[0],"filamentExtruder":0,"heaters":[1],"mix":[1],"name":"","number":0,"offsets":[0,0,0],"offsetsProbed":0,"retraction":{"extraRestart":0,"length":5,"speed":40,"unretractSpeed":40,"zHop":0.5},"standby":[0],"state":"active"}],"userSessions":[],"userVariables":[],"volumes":[{"capacity":29077254144,"freeSpace":20587024384,"mounted":true,"name":null,"openFiles":null,"path":"/","speed":null},{"capacity":2143281152,"freeSpace":2028986368,"mounted":true,"name":null,"openFiles":null,"path":"/boot","speed":null}]}
              stuartofmt
              Could someone please try this? It's a test script for the SBC calls. It's read only with the exception of a M117 'Test of SBC' which should show up in DWC.
              Once its placed in a directory permissions will need to be changed.
              chmod +x ./SBCTEST.py
              it can then be run with the following command
              python3 ./SBCTEST.py -duet <ipaddress of your SBC printer>
              with a bit of luck it will report success, in any case - if the resultant SBCTEST.log file can be posted back, that would be a great help.
              I've tested it on my non SBC duet - there may be some syntax errors in the unexercised code - but I hope not 🙂
              If there are then a screen shot would be helpful.
              [SBCTEST.py]
              • PCRundefined
                PCR
                Can do it tomorrow! Thank you
                  @stuartofmt said in DuetLapse3:
                  localhost Determine API Version
                  localhost Testing: rr_model at address localhost
                  localhost http://localhost/rr_model?key=boards
                  localhost
                  localhost Testing: /machine/system at address localhost
                  localhost http://localhost/machine/status
                  localhost
                  localhost API model is: machine   Version is: 3
                  localhost Status is :idle
                  localhost Layer is :0
                  Traceback (most recent call last):
                    File "./SBCTEST.py", line 147, in <module>
                      logger.info('Send Gcode result: '+sendDuetGcode(apiModel, 'M117 Test of SBC'))
                    File "./SBCTEST.py", line 122, in sendDuetGcode
                      r = requests.get.post(URL, data=command)
                  AttributeError: 'function' object has no attribute 'post'
                  Nothing is displayed on DWC
                  stuartofmtundefined 1 Reply Last reply Reply Quote 0
                    @jay_s_uk
                    Aghhhh - A definite typo ... Try this please.
                    The rest looks good.
                    [SBCTEST.py]
                    PCRundefined 1 Reply Last reply Reply Quote 0
                    • PCRundefined
                      PCR @stuartofmt
                      @stuartofmt
                      192.168.140.126 Determine API Version
                      192.168.140.126 Testing: rr_model at address 192.168.140.126
                      192.168.140.126 http://192.168.140.126/rr_model?key=boards
                      192.168.140.126
                      192.168.140.126 Testing: /machine/system at address 192.168.140.126
                      192.168.140.126 http://192.168.140.126/machine/status
                      192.168.140.126
                      192.168.140.126 API model is: machine   Version is: 3
                      192.168.140.126 Status is :processing
                      192.168.140.126 Layer is :0
                      --- Logging error ---
                        File "/usr/lib/python3.7/logging/__init__.py", line 1034, in emit
                          msg = self.format(record)
                        File "/usr/lib/python3.7/logging/__init__.py", line 880, in format
                          return fmt.format(record)
                        File "/usr/lib/python3.7/logging/__init__.py", line 619, in format
                          record.message = record.getMessage()
                        File "/usr/lib/python3.7/logging/__init__.py", line 380, in getMessage
                          msg = msg % self.args
                      TypeError: not all arguments converted during string formatting
                      Call stack:
                        File "./sbctest.py", line 147, in <module>
                        File "./sbctest.py", line 127, in sendDuetGcode
                          logger.info("gCode command return code = ",r.status_code)
                      Message: 'gCode command return code = '
                      Arguments: (405,)
                      Call stack:
                      Arguments: (405,)
                      192.168.140.126 Method Not Allowed
                      TypeError: can only concatenate str (not "int") to str
                        stuartofmt
                        @PCR @jay_s_uk
                        Thanks - there was a silly formatting error (now fixed) but underlying that it looks like there was an http 405 error returned.
                        I've added a two more version of the send gcode function to try - hopefully one of them works. Unfortunately the documentation and other examples (which purport to work) are somewhat vague on this aspect ....
                        ALSO - if you are running RRF3.2 the default behavior for CORS seems to have changed. With another program I am using (DueUI) - I had to add the following to config.sys (up front in the network section) - after the upgrade. BUT DuetLapse was unaffected. It MAY be different on SBC.
                        I'd suggest first trying "as is" but if this script still does not work with one of the methods (depending on what the errors are) - the CORS thing may need to be looked into.
                        M586 C"*"                                     ;enable CORS
                        New Test Script is here
                        [SBCTEST.py]
                        • fractalengineerundefined
                          fractalengineer
                          Awesome Stuart, thanks for carrying on Danal's work
                          Looks well documented too, I'll give it a shot over the weekend.
                          Very neat of you to handle issues outside of your own setup too
                          Do you think in it's current state this could realistically be implemented as a plugin in DWC for a possible GUI?
                          Railcore II ZL
                          stuartofmtundefined 1 Reply Last reply Reply Quote 2
                            stuartofmt @fractalengineer
                            @fractalengineer
                            Thanks. As a plugin ? hmmm . I'll have to see what that means / entails. Let me put that as a priority 2 for right now.
                            Priority 1 is getting SSB working and tidying up some of the logic / behavior surrounding pauses. I did not test that aspect much and its somewhat ambiguous - so stay tuned ...
                              @stuartofmt
                              192.168.1.31 Determine API Version
                              192.168.1.31 Testing: rr_model at address 192.168.1.31
                              192.168.1.31 http://192.168.1.31/rr_model?key=boards
                              192.168.1.31
                              192.168.1.31 Testing: /machine/system at address 192.168.1.31
                              192.168.1.31 http://192.168.1.31/machine/status
                              192.168.1.31
                              192.168.1.31 API model is: SBC   Version is: 3
                              192.168.1.31 Status is :idle
                              192.168.1.31 Layer is :0
                              192.168.1.31 ***Testing V0***
                              405
                              Method Not Allowed
                              192.168.1.31 gCode command return code = 405
                              192.168.1.31 Method Not Allowed
                              192.168.1.31 Send Gcode result: 405
                              192.168.1.31 ***Testing V1***
                              200
                              OK
                              192.168.1.31 Send Gcode result: 0
                              192.168.1.31 ***Testing V2***
                              404
                              Not Found
                              192.168.1.31 gCode command return code = 404
                              192.168.1.31 Not Found
                              192.168.1.31 Send Gcode result: 404
                                @jay_s_uk
                                OK! Looks like V1 worked!! So you should have got a message on DWC saying "Test of SBC"
                                Did you see that ?
                                  jay_s_uk
                                  @stuartofmt
                                  No, nothing displayed on DWC
                                    @jay_s_uk
                                    Ok - I'm going to have to get some help. The code I have seen elsewhere (including Danal's) does not work (or I've done something stupid). The one that reports success - does not seem to send the gcode .... go figure .....
                                    So - this should work for SBC -- but not for using the pause capability (that's the only thing that sends gcodes). Appreciate it if you could test before I update github
                                    Hmm - wont let me upload the file to here. I'll update on github - if you would not mind downloading from there.
                                      stuartofmt
                                      Ok it looks like we are getting close ( thanks to an "anonymous" tip in another thread 🙂 )
                                      Can you try this please. V3 is the latest (and hopefully correct) form.
                                      [SBCTEST.py]
                                        stuartofmt
                                        In order to better handle pause situations - I need to access Duet to get a previously unused set of parameters. I'll post a new test script tomorrow. If successful - then SBC should be fully supported. Stay tuned and thanks for the help.
                                        • PCRundefined
                                          PCR
                                          @stuartofmt i will have acces to my SBC printer tomorrow
                                            stuartofmt
                                            If all y'all could try this on SBC please
                                            [SBCTEST.py]
                                            In particular verify that a message appears in DWC "Test of SBC"
