    DuetLapse3
    Third-party software
    20
    296
    30.8k
    • PCRundefined
      PCR
      @stuartofmt I am running the LPC SBC Port of RRF. But i can not connect to my Pi.
      here is my Object Model
      192.168.140.126 The printer at 192.168.140.126 did not respond
      192.168.140.126 Check the ip address or logical printer name is correct
      192.168.140.126 Duet software version must be at RRF3 or above and suppotr rr_model
      Best
        jay_s_uk
        @stuartofmt
        The duet+SBC doesn't support the object model and uses machine/status instead.
        The DuetWebAPI handled both methods of obtaining information.
        stuartofmtundefined 1 Reply Last reply Reply Quote 0
        • stuartofmtundefined
          stuartofmt @PCR
          @PCR
          Instructions on wget for download fixed. Thanks!
            stuartofmt @jay_s_uk
            @jay_s_uk
            Let me take a look at the SBC situation (which I do not own). I was under the impression that /machine/status was replaced (to be?) by rr_model as the preferred method.
            It may take me a few of days to figure out.
              jay_s_uk @stuartofmt
              @stuartofmt its the other way round.
              rr_model is replaced by machine/status in SBC situations
                @jay_s_uk
                OK - thx. It's not difficult but I will need some help testing.
                  @stuartofmt
                  i can provide a current 3.2 output from machine/status if needed.
                  i'm sure @PCR would do some testing for you
                  stuartofmtundefined 1 Reply Last reply Reply Quote 1
                    @jay_s_uk
                    That would be very helpful (much better than closing my eyes and imagining) - thanks!
                      jay_s_uk
                      {"boards":[{"bootloaderFileName":null,"canAddress":0,"directDisplay":null,"firmwareDate":"2021-01-05","firmwareFileName":"Duet3Firmware_Mini5plus.uf2","firmwareName":"RepRapFirmware for Duet 3 Mini 5\u002B","firmwareVersion":"3.2","iapFileNameSBC":"Duet3_SBCiap32_Mini5plus.bin","iapFileNameSD":"Duet3_SDiap32_Mini5plus.bin","maxHeaters":32,"maxMotors":7,"mcuTemp":{"current":-273.15,"min":-273.15,"max":-273.15},"name":"Duet 3 Mini 5\u002B","shortName":"Mini5plus","state":"unknown","supports12864":true,"supportsDirectDisplay":true,"uniqueId":"P2P4H-PA67A-G65J0-40TFU-L2D0Z-ZTS4L","v12":{"current":0,"min":0,"max":0},"vIn":{"current":12.3,"min":0,"max":12.3}}],"directories":{"filaments":"0:/filaments/","firmware":"0:/sys/","gCodes":"0:/gcodes/","macros":"0:/macros/","menu":"0:/menu/","scans":"0:/scans/","system":"0:/sys/","web":"0:/www/"},"fans":[{"actualValue":0,"blip":0.1,"frequency":0,"max":1,"min":0.1,"name":"","requestedValue":0,"rpm":-1,"thermostatic":{"heaters":[],"highTemperature":null,"lowTemperature":null}},{"actualValue":0,"blip":0.1,"frequency":0,"max":1,"min":0.1,"name":"","requestedValue":1,"rpm":-1,"thermostatic":{"heaters":[1],"highTemperature":45,"lowTemperature":45}}],"heat":{"bedHeaters":[0,-1],"chamberHeaters":[-1,-1],"coldExtrudeTemperature":160,"coldRetractTemperature":90,"heaters":[{"active":0,"current":15.4,"max":120,"min":-273.1,"model":{"deadTime":2.2,"enabled":true,"gain":114,"heatingRate":0.219,"inverted":false,"maxPwm":1,"pid":{"overridden":false,"p":1.5,"i":0.1,"d":2.2,"used":true},"standardVoltage":12.2,"timeConstant":520.5,"timeConstantFansOn":520.5},"monitors":[{"action":0,"condition":"tooHigh","limit":120},{"action":null,"condition":"disabled","limit":null},{"action":null,"condition":"disabled","limit":null}],"name":null,"sensor":0,"standby":0,"state":"off"},{"active":0,"current":15.9,"max":285,"min":-273.1,"model":{"deadTime":7,"enabled":true,"gain":407.9,"heatingRate":2.343,"inverted":false,"maxPwm":1,"pid":{"overridden":false,"p":0,"i":0,"d":0.2,"used":true},"standardVoltage":12.2,"timeConstant":174.1,"timeConstantFansOn":152.7},"monitors":[{"action":0,"condition":"tooHigh","limit":285},{"action":null,"condition":"disabled","limit":null},{"action":null,"condition":"disabled","limit":null}],"name":null,"sensor":1,"standby":0,"state":"active"}]},"httpEndpoints":[],"inputs":[{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"HTTP","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"Marlin","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Telnet","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"File","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"Marlin","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"USB","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Aux","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":true,"name":"Trigger","stackDepth":1,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Queue","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"LCD","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"SBC","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Daemon","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Aux2","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Autopause","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false}],"job":{"build":null,"duration":null,"file":{"filament":[],"fileName":null,"firstLayerHeight":0,"generatedBy":null,"height":0,"lastModified":null,"layerHeight":0,"numLayers":0,"printTime":null,"simulatedTime":null,"size":0,"thumbnails":[]},"filePosition":0,"firstLayerDuration":null,"lastDuration":0,"lastFileName":null,"lastFileAborted":false,"lastFileCancelled":false,"lastFileSimulated":false,"layer":null,"layerTime":null,"layers":[],"timesLeft":{"filament":null,"file":null,"layer":null},"warmUpDuration":null},"limits":{"axes":8,"axesPlusExtruders":8,"bedHeaters":2,"boards":5,"chamberHeaters":2,"drivers":14,"driversPerAxis":4,"extruders":5,"extrudersPerTool":5,"fans":16,"gpInPorts":16,"gpOutPorts":32,"heaters":32,"heatersPerTool":2,"monitorsPerHeater":3,"restorePoints":6,"sensors":56,"spindles":2,"tools":50,"trackedObjects":32,"triggers":16,"volumes":2,"workplaces":9,"zProbeProgramBytes":8,"zProbes":4},"messages":[],"move":{"axes":[{"acceleration":1000,"babystep":0,"current":1200,"drivers":["0.4"],"homed":false,"jerk":1000,"letter":"X","machinePosition":0,"max":270,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":0,"minProbed":false,"speed":6000,"stepsPerMm":100,"userPosition":0,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]},{"acceleration":1000,"babystep":0,"current":1200,"drivers":["0.3"],"homed":false,"jerk":1000,"letter":"Y","machinePosition":0,"max":260,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":0,"minProbed":false,"speed":6000,"stepsPerMm":100,"userPosition":0,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]},{"acceleration":200,"babystep":0,"current":1200,"drivers":["0.1","0.2"],"homed":false,"jerk":200,"letter":"Z","machinePosition":0,"max":350,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":0,"minProbed":false,"speed":300,"stepsPerMm":400,"userPosition":0,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]}],"calibration":{"final":{"deviation":0,"mean":0},"initial":{"deviation":0,"mean":0},"numFactors":0},"compensation":{"fadeHeight":null,"file":null,"meshDeviation":null,"probeGrid":{"xMin":15,"xMax":230,"xSpacing":20,"yMin":15,"yMax":230,"ySpacing":20,"radius":-1},"skew":{"compensateXY":true,"tanXY":0,"tanXZ":0,"tanYZ":0},"type":"none"},"currentMove":{"acceleration":0,"deceleration":0,"laserPwm":null,"requestedSpeed":0,"topSpeed":0},"daa":{"enabled":false,"minimumAcceleration":10,"period":0},"extruders":[{"acceleration":250,"current":1000,"driver":"0.0","filament":"","factor":1,"jerk":120,"microstepping":{"interpolated":true,"value":16},"nonlinear":{"a":0,"b":0,"upperLimit":0.2},"position":0,"pressureAdvance":0,"rawPosition":0,"speed":1200,"stepsPerMm":837}],"idle":{"timeout":30,"factor":0.3},"kinematics":{"forwardMatrix":[[1,0,0],[0,1,0],[0,0,1]],"inverseMatrix":[[1,0,0],[0,1,0],[0,0,1]],"tiltCorrection":{"correctionFactor":1,"lastCorrections":[0,0],"maxCorrection":10,"screwPitch":0.5,"screwX":[-130,400],"screwY":[150,150]},"name":"cartesian"},"printingAcceleration":10000,"speedFactor":1,"travelAcceleration":10000,"virtualEPos":0,"workplaceNumber":0,"workspaceNumber":1},"network":{"corsSite":null,"hostname":"duet3","interfaces":[{"activeProtocols":[],"actualIP":"192.168.1.31","configuredIP":"192.168.1.31","firmwareVersion":null,"gateway":"192.168.1.1","mac":"B8:27:EB:C9:9C:1A","numReconnects":null,"signal":null,"speed":null,"subnet":"255.255.255.0","type":"wifi"}],"name":"duet3"},"plugins":[{"dwcFiles":["GCodeViewer.10bd9549.js","GCodeViewer.88004336.css"],"sbcFiles":[],"rrfFiles":[],"pid":-1,"name":"GCodeViewer","author":"Juan Rosario","version":"0.11.1","license":"LGPL-3.0-or-later","sourceRepository":null,"dwcVersion":"3.2.0-beta4","dwcDependencies":[],"dwcWebpackChunk":"GCodeViewer","sbcRequired":false,"sbcDsfVersion":null,"sbcData":{},"sbcExecutable":null,"sbcExecutableArguments":null,"sbcOutputRedirected":true,"sbcPermissions":[],"sbcPackageDependencies":[],"sbcPluginDependencies":[],"rrfVersion":null}],"scanner":{"progress":0,"status":"D"},"sensors":{"analog":[{"lastReading":15.4,"name":"","type":"thermistor"},{"lastReading":15.9,"name":"","type":"thermistor"}],"endstops":[{"triggered":false,"type":"inputPin","probeNumber":null},{"triggered":false,"type":"inputPin","probeNumber":null},null],"filamentMonitors":[],"gpIn":[],"probes":[{"calibrationTemperature":25,"deployedByUser":false,"disablesHeaters":false,"diveHeight":2,"lastStopHeight":0,"maxProbeCount":5,"offsets":[-27.3,3.5],"recoveryTime":0,"speed":2,"temperatureCoefficient":0,"temperatureCoefficients":[0,0],"threshold":1000,"tolerance":0.02,"travelSpeed":333.3,"triggerHeight":3.553,"type":1,"value":[671]}]},"spindles":[{"active":0,"current":0,"frequency":0,"min":60,"max":10000,"tool":-1},{"active":0,"current":0,"frequency":0,"min":60,"max":10000,"tool":-1}],"state":{"atxPower":null,"beep":null,"currentTool":0,"displayMessage":"","dsfVersion":"3.2.0","gpOut":[{"pwm":0}],"laserPwm":null,"logFile":null,"logLevel":"off","messageBox":null,"machineMode":"FFF","msUpTime":503,"nextTool":0,"powerFailScript":"","previousTool":-1,"restorePoints":[{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1}],"status":"idle","time":"2021-01-14T17:44:25","upTime":363424},"tools":[{"active":[0],"axes":[[0],[1]],"extruders":[0],"fans":[0],"filamentExtruder":0,"heaters":[1],"mix":[1],"name":"","number":0,"offsets":[0,0,0],"offsetsProbed":0,"retraction":{"extraRestart":0,"length":5,"speed":40,"unretractSpeed":40,"zHop":0.5},"standby":[0],"state":"active"}],"userSessions":[],"userVariables":[],"volumes":[{"capacity":29077254144,"freeSpace":20587024384,"mounted":true,"name":null,"openFiles":null,"path":"/","speed":null},{"capacity":2143281152,"freeSpace":2028986368,"mounted":true,"name":null,"openFiles":null,"path":"/boot","speed":null}]}
                        stuartofmt
                        Could someone please try this? It's a test script for the SBC calls. It's read only with the exception of a M117 'Test of SBC' which should show up in DWC.
                        Once its placed in a directory permissions will need to be changed.
                        chmod +x ./SBCTEST.py
                        it can then be run with the following command
                        python3 ./SBCTEST.py -duet <ipaddress of your SBC printer>
                        with a bit of luck it will report success, in any case - if the resultant SBCTEST.log file can be posted back, that would be a great help.
                        I've tested it on my non SBC duet - there may be some syntax errors in the unexercised code - but I hope not 🙂
                        If there are then a screen shot would be helpful.
                        [SBCTEST.py]
                        • PCRundefined
                          PCR
                          Can do it tomorrow! Thank you
                            @stuartofmt said in DuetLapse3:
                            localhost Determine API Version
                            localhost Testing: rr_model at address localhost
                            localhost http://localhost/rr_model?key=boards
                            localhost
                            localhost Testing: /machine/system at address localhost
                            localhost http://localhost/machine/status
                            localhost
                            localhost API model is: machine   Version is: 3
                            localhost Status is :idle
                            localhost Layer is :0
                            Traceback (most recent call last):
                              File "./SBCTEST.py", line 147, in <module>
                                logger.info('Send Gcode result: '+sendDuetGcode(apiModel, 'M117 Test of SBC'))
                              File "./SBCTEST.py", line 122, in sendDuetGcode
                                r = requests.get.post(URL, data=command)
                            AttributeError: 'function' object has no attribute 'post'
                            Nothing is displayed on DWC
                              @jay_s_uk
                              Aghhhh - A definite typo ... Try this please.
                              The rest looks good.
                              [SBCTEST.py]
                              PCRundefined 1 Reply Last reply Reply Quote 0
                              • PCRundefined
                                PCR @stuartofmt
                                @stuartofmt
                                192.168.140.126 Determine API Version
                                192.168.140.126 Testing: rr_model at address 192.168.140.126
                                192.168.140.126 http://192.168.140.126/rr_model?key=boards
                                192.168.140.126
                                192.168.140.126 Testing: /machine/system at address 192.168.140.126
                                192.168.140.126 http://192.168.140.126/machine/status
                                192.168.140.126
                                192.168.140.126 API model is: machine   Version is: 3
                                192.168.140.126 Status is :processing
                                192.168.140.126 Layer is :0
                                --- Logging error ---
                                  File "/usr/lib/python3.7/logging/__init__.py", line 1034, in emit
                                    msg = self.format(record)
                                  File "/usr/lib/python3.7/logging/__init__.py", line 880, in format
                                    return fmt.format(record)
                                  File "/usr/lib/python3.7/logging/__init__.py", line 619, in format
                                    record.message = record.getMessage()
                                  File "/usr/lib/python3.7/logging/__init__.py", line 380, in getMessage
                                    msg = msg % self.args
                                TypeError: not all arguments converted during string formatting
                                Call stack:
                                  File "./sbctest.py", line 147, in <module>
                                  File "./sbctest.py", line 127, in sendDuetGcode
                                    logger.info("gCode command return code = ",r.status_code)
                                Message: 'gCode command return code = '
                                Arguments: (405,)
                                Call stack:
                                Arguments: (405,)
                                192.168.140.126 Method Not Allowed
                                TypeError: can only concatenate str (not "int") to str
                                  stuartofmt
                                  @PCR @jay_s_uk
                                  Thanks - there was a silly formatting error (now fixed) but underlying that it looks like there was an http 405 error returned.
                                  I've added a two more version of the send gcode function to try - hopefully one of them works. Unfortunately the documentation and other examples (which purport to work) are somewhat vague on this aspect ....
                                  ALSO - if you are running RRF3.2 the default behavior for CORS seems to have changed. With another program I am using (DueUI) - I had to add the following to config.sys (up front in the network section) - after the upgrade. BUT DuetLapse was unaffected. It MAY be different on SBC.
                                  I'd suggest first trying "as is" but if this script still does not work with one of the methods (depending on what the errors are) - the CORS thing may need to be looked into.
                                  M586 C"*"                                     ;enable CORS
                                  New Test Script is here
                                  [SBCTEST.py]
                                  • fractalengineerundefined
                                    fractalengineer
                                    Awesome Stuart, thanks for carrying on Danal's work
                                    Looks well documented too, I'll give it a shot over the weekend.
                                    Very neat of you to handle issues outside of your own setup too
                                    Do you think in it's current state this could realistically be implemented as a plugin in DWC for a possible GUI?
                                    Railcore II ZL
                                    stuartofmtundefined 1 Reply Last reply Reply Quote 2
                                      stuartofmt @fractalengineer
                                      @fractalengineer
                                      Thanks. As a plugin ? hmmm . I'll have to see what that means / entails. Let me put that as a priority 2 for right now.
                                      Priority 1 is getting SSB working and tidying up some of the logic / behavior surrounding pauses. I did not test that aspect much and its somewhat ambiguous - so stay tuned ...
                                        @stuartofmt
                                        192.168.1.31 Determine API Version
                                        192.168.1.31 Testing: rr_model at address 192.168.1.31
                                        192.168.1.31 http://192.168.1.31/rr_model?key=boards
                                        192.168.1.31
                                        192.168.1.31 Testing: /machine/system at address 192.168.1.31
                                        192.168.1.31 http://192.168.1.31/machine/status
                                        192.168.1.31
                                        192.168.1.31 API model is: SBC   Version is: 3
                                        192.168.1.31 Status is :idle
                                        192.168.1.31 Layer is :0
                                        192.168.1.31 ***Testing V0***
                                        405
                                        Method Not Allowed
                                        192.168.1.31 gCode command return code = 405
                                        192.168.1.31 Method Not Allowed
                                        192.168.1.31 Send Gcode result: 405
                                        192.168.1.31 ***Testing V1***
                                        200
                                        OK
                                        192.168.1.31 Send Gcode result: 0
                                        192.168.1.31 ***Testing V2***
                                        404
                                        Not Found
                                        192.168.1.31 gCode command return code = 404
                                        192.168.1.31 Not Found
                                        192.168.1.31 Send Gcode result: 404
                                          @jay_s_uk
                                          OK! Looks like V1 worked!! So you should have got a message on DWC saying "Test of SBC"
                                          Did you see that ?
                                            jay_s_uk
                                            @stuartofmt
                                            No, nothing displayed on DWC
