    DuetLapse3
    Third-party software
    20
    296
    30.9k
    • PCRundefined
      PCR
      @stuartofmt
      wget https://github.com/stuartofmt/DuetLapse3/blob/main/DuetLapse3.py
      should be changed to
      wget https://github.com/stuartofmt/DuetLapse3/raw/main/DuetLapse3.py
      stuartofmtundefined 1 Reply Last reply Reply Quote 0
      • PCRundefined
        PCR
        This post is deleted!
        • PCRundefined
          PCR
          @stuartofmt I am running the LPC SBC Port of RRF. But i can not connect to my Pi.
          here is my Object Model
          192.168.140.126 The printer at 192.168.140.126 did not respond
          192.168.140.126 Check the ip address or logical printer name is correct
          192.168.140.126 Duet software version must be at RRF3 or above and suppotr rr_model
          Best
            jay_s_uk
            @stuartofmt
            The duet+SBC doesn't support the object model and uses machine/status instead.
            The DuetWebAPI handled both methods of obtaining information.
            • stuartofmtundefined
              stuartofmt @PCR
              @PCR
              Instructions on wget for download fixed. Thanks!
                stuartofmt @jay_s_uk
                @jay_s_uk
                Let me take a look at the SBC situation (which I do not own). I was under the impression that /machine/status was replaced (to be?) by rr_model as the preferred method.
                It may take me a few of days to figure out.
                  jay_s_uk @stuartofmt
                  @stuartofmt its the other way round.
                  rr_model is replaced by machine/status in SBC situations
                    @jay_s_uk
                    OK - thx. It's not difficult but I will need some help testing.
                      @stuartofmt
                      i can provide a current 3.2 output from machine/status if needed.
                      i'm sure @PCR would do some testing for you
                      stuartofmtundefined 1 Reply Last reply Reply Quote 1
                        @jay_s_uk
                        That would be very helpful (much better than closing my eyes and imagining) - thanks!
                          jay_s_uk
                          {"boards":[{"bootloaderFileName":null,"canAddress":0,"directDisplay":null,"firmwareDate":"2021-01-05","firmwareFileName":"Duet3Firmware_Mini5plus.uf2","firmwareName":"RepRapFirmware for Duet 3 Mini 5\u002B","firmwareVersion":"3.2","iapFileNameSBC":"Duet3_SBCiap32_Mini5plus.bin","iapFileNameSD":"Duet3_SDiap32_Mini5plus.bin","maxHeaters":32,"maxMotors":7,"mcuTemp":{"current":-273.15,"min":-273.15,"max":-273.15},"name":"Duet 3 Mini 5\u002B","shortName":"Mini5plus","state":"unknown","supports12864":true,"supportsDirectDisplay":true,"uniqueId":"P2P4H-PA67A-G65J0-40TFU-L2D0Z-ZTS4L","v12":{"current":0,"min":0,"max":0},"vIn":{"current":12.3,"min":0,"max":12.3}}],"directories":{"filaments":"0:/filaments/","firmware":"0:/sys/","gCodes":"0:/gcodes/","macros":"0:/macros/","menu":"0:/menu/","scans":"0:/scans/","system":"0:/sys/","web":"0:/www/"},"fans":[{"actualValue":0,"blip":0.1,"frequency":0,"max":1,"min":0.1,"name":"","requestedValue":0,"rpm":-1,"thermostatic":{"heaters":[],"highTemperature":null,"lowTemperature":null}},{"actualValue":0,"blip":0.1,"frequency":0,"max":1,"min":0.1,"name":"","requestedValue":1,"rpm":-1,"thermostatic":{"heaters":[1],"highTemperature":45,"lowTemperature":45}}],"heat":{"bedHeaters":[0,-1],"chamberHeaters":[-1,-1],"coldExtrudeTemperature":160,"coldRetractTemperature":90,"heaters":[{"active":0,"current":15.4,"max":120,"min":-273.1,"model":{"deadTime":2.2,"enabled":true,"gain":114,"heatingRate":0.219,"inverted":false,"maxPwm":1,"pid":{"overridden":false,"p":1.5,"i":0.1,"d":2.2,"used":true},"standardVoltage":12.2,"timeConstant":520.5,"timeConstantFansOn":520.5},"monitors":[{"action":0,"condition":"tooHigh","limit":120},{"action":null,"condition":"disabled","limit":null},{"action":null,"condition":"disabled","limit":null}],"name":null,"sensor":0,"standby":0,"state":"off"},{"active":0,"current":15.9,"max":285,"min":-273.1,"model":{"deadTime":7,"enabled":true,"gain":407.9,"heatingRate":2.343,"inverted":false,"maxPwm":1,"pid":{"overridden":false,"p":0,"i":0,"d":0.2,"used":true},"standardVoltage":12.2,"timeConstant":174.1,"timeConstantFansOn":152.7},"monitors":[{"action":0,"condition":"tooHigh","limit":285},{"action":null,"condition":"disabled","limit":null},{"action":null,"condition":"disabled","limit":null}],"name":null,"sensor":1,"standby":0,"state":"active"}]},"httpEndpoints":[],"inputs":[{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"HTTP","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"Marlin","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Telnet","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"File","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"Marlin","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"USB","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Aux","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":true,"name":"Trigger","stackDepth":1,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Queue","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"LCD","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"SBC","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Daemon","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Aux2","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50,"inMacro":false,"name":"Autopause","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false}],"job":{"build":null,"duration":null,"file":{"filament":[],"fileName":null,"firstLayerHeight":0,"generatedBy":null,"height":0,"lastModified":null,"layerHeight":0,"numLayers":0,"printTime":null,"simulatedTime":null,"size":0,"thumbnails":[]},"filePosition":0,"firstLayerDuration":null,"lastDuration":0,"lastFileName":null,"lastFileAborted":false,"lastFileCancelled":false,"lastFileSimulated":false,"layer":null,"layerTime":null,"layers":[],"timesLeft":{"filament":null,"file":null,"layer":null},"warmUpDuration":null},"limits":{"axes":8,"axesPlusExtruders":8,"bedHeaters":2,"boards":5,"chamberHeaters":2,"drivers":14,"driversPerAxis":4,"extruders":5,"extrudersPerTool":5,"fans":16,"gpInPorts":16,"gpOutPorts":32,"heaters":32,"heatersPerTool":2,"monitorsPerHeater":3,"restorePoints":6,"sensors":56,"spindles":2,"tools":50,"trackedObjects":32,"triggers":16,"volumes":2,"workplaces":9,"zProbeProgramBytes":8,"zProbes":4},"messages":[],"move":{"axes":[{"acceleration":1000,"babystep":0,"current":1200,"drivers":["0.4"],"homed":false,"jerk":1000,"letter":"X","machinePosition":0,"max":270,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":0,"minProbed":false,"speed":6000,"stepsPerMm":100,"userPosition":0,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]},{"acceleration":1000,"babystep":0,"current":1200,"drivers":["0.3"],"homed":false,"jerk":1000,"letter":"Y","machinePosition":0,"max":260,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":0,"minProbed":false,"speed":6000,"stepsPerMm":100,"userPosition":0,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]},{"acceleration":200,"babystep":0,"current":1200,"drivers":["0.1","0.2"],"homed":false,"jerk":200,"letter":"Z","machinePosition":0,"max":350,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":0,"minProbed":false,"speed":300,"stepsPerMm":400,"userPosition":0,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]}],"calibration":{"final":{"deviation":0,"mean":0},"initial":{"deviation":0,"mean":0},"numFactors":0},"compensation":{"fadeHeight":null,"file":null,"meshDeviation":null,"probeGrid":{"xMin":15,"xMax":230,"xSpacing":20,"yMin":15,"yMax":230,"ySpacing":20,"radius":-1},"skew":{"compensateXY":true,"tanXY":0,"tanXZ":0,"tanYZ":0},"type":"none"},"currentMove":{"acceleration":0,"deceleration":0,"laserPwm":null,"requestedSpeed":0,"topSpeed":0},"daa":{"enabled":false,"minimumAcceleration":10,"period":0},"extruders":[{"acceleration":250,"current":1000,"driver":"0.0","filament":"","factor":1,"jerk":120,"microstepping":{"interpolated":true,"value":16},"nonlinear":{"a":0,"b":0,"upperLimit":0.2},"position":0,"pressureAdvance":0,"rawPosition":0,"speed":1200,"stepsPerMm":837}],"idle":{"timeout":30,"factor":0.3},"kinematics":{"forwardMatrix":[[1,0,0],[0,1,0],[0,0,1]],"inverseMatrix":[[1,0,0],[0,1,0],[0,0,1]],"tiltCorrection":{"correctionFactor":1,"lastCorrections":[0,0],"maxCorrection":10,"screwPitch":0.5,"screwX":[-130,400],"screwY":[150,150]},"name":"cartesian"},"printingAcceleration":10000,"speedFactor":1,"travelAcceleration":10000,"virtualEPos":0,"workplaceNumber":0,"workspaceNumber":1},"network":{"corsSite":null,"hostname":"duet3","interfaces":[{"activeProtocols":[],"actualIP":"192.168.1.31","configuredIP":"192.168.1.31","firmwareVersion":null,"gateway":"192.168.1.1","mac":"B8:27:EB:C9:9C:1A","numReconnects":null,"signal":null,"speed":null,"subnet":"255.255.255.0","type":"wifi"}],"name":"duet3"},"plugins":[{"dwcFiles":["GCodeViewer.10bd9549.js","GCodeViewer.88004336.css"],"sbcFiles":[],"rrfFiles":[],"pid":-1,"name":"GCodeViewer","author":"Juan Rosario","version":"0.11.1","license":"LGPL-3.0-or-later","sourceRepository":null,"dwcVersion":"3.2.0-beta4","dwcDependencies":[],"dwcWebpackChunk":"GCodeViewer","sbcRequired":false,"sbcDsfVersion":null,"sbcData":{},"sbcExecutable":null,"sbcExecutableArguments":null,"sbcOutputRedirected":true,"sbcPermissions":[],"sbcPackageDependencies":[],"sbcPluginDependencies":[],"rrfVersion":null}],"scanner":{"progress":0,"status":"D"},"sensors":{"analog":[{"lastReading":15.4,"name":"","type":"thermistor"},{"lastReading":15.9,"name":"","type":"thermistor"}],"endstops":[{"triggered":false,"type":"inputPin","probeNumber":null},{"triggered":false,"type":"inputPin","probeNumber":null},null],"filamentMonitors":[],"gpIn":[],"probes":[{"calibrationTemperature":25,"deployedByUser":false,"disablesHeaters":false,"diveHeight":2,"lastStopHeight":0,"maxProbeCount":5,"offsets":[-27.3,3.5],"recoveryTime":0,"speed":2,"temperatureCoefficient":0,"temperatureCoefficients":[0,0],"threshold":1000,"tolerance":0.02,"travelSpeed":333.3,"triggerHeight":3.553,"type":1,"value":[671]}]},"spindles":[{"active":0,"current":0,"frequency":0,"min":60,"max":10000,"tool":-1},{"active":0,"current":0,"frequency":0,"min":60,"max":10000,"tool":-1}],"state":{"atxPower":null,"beep":null,"currentTool":0,"displayMessage":"","dsfVersion":"3.2.0","gpOut":[{"pwm":0}],"laserPwm":null,"logFile":null,"logLevel":"off","messageBox":null,"machineMode":"FFF","msUpTime":503,"nextTool":0,"powerFailScript":"","previousTool":-1,"restorePoints":[{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[0,0],"toolNumber":-1}],"status":"idle","time":"2021-01-14T17:44:25","upTime":363424},"tools":[{"active":[0],"axes":[[0],[1]],"extruders":[0],"fans":[0],"filamentExtruder":0,"heaters":[1],"mix":[1],"name":"","number":0,"offsets":[0,0,0],"offsetsProbed":0,"retraction":{"extraRestart":0,"length":5,"speed":40,"unretractSpeed":40,"zHop":0.5},"standby":[0],"state":"active"}],"userSessions":[],"userVariables":[],"volumes":[{"capacity":29077254144,"freeSpace":20587024384,"mounted":true,"name":null,"openFiles":null,"path":"/","speed":null},{"capacity":2143281152,"freeSpace":2028986368,"mounted":true,"name":null,"openFiles":null,"path":"/boot","speed":null}]}
                            stuartofmt
                            Could someone please try this? It's a test script for the SBC calls. It's read only with the exception of a M117 'Test of SBC' which should show up in DWC.
                            Once its placed in a directory permissions will need to be changed.
                            chmod +x ./SBCTEST.py
                            it can then be run with the following command
                            python3 ./SBCTEST.py -duet <ipaddress of your SBC printer>
                            with a bit of luck it will report success, in any case - if the resultant SBCTEST.log file can be posted back, that would be a great help.
                            I've tested it on my non SBC duet - there may be some syntax errors in the unexercised code - but I hope not 🙂
                            If there are then a screen shot would be helpful.
                            [SBCTEST.py]
                            • PCRundefined
                              PCR
                              Can do it tomorrow! Thank you
                                @stuartofmt said in DuetLapse3:
                                localhost Determine API Version
                                localhost Testing: rr_model at address localhost
                                localhost http://localhost/rr_model?key=boards
                                localhost
                                localhost Testing: /machine/system at address localhost
                                localhost http://localhost/machine/status
                                localhost
                                localhost API model is: machine   Version is: 3
                                localhost Status is :idle
                                localhost Layer is :0
                                Traceback (most recent call last):
                                  File "./SBCTEST.py", line 147, in <module>
                                    logger.info('Send Gcode result: '+sendDuetGcode(apiModel, 'M117 Test of SBC'))
                                  File "./SBCTEST.py", line 122, in sendDuetGcode
                                    r = requests.get.post(URL, data=command)
                                AttributeError: 'function' object has no attribute 'post'
                                Nothing is displayed on DWC
                                  @jay_s_uk
                                  Aghhhh - A definite typo ... Try this please.
                                  The rest looks good.
                                  [SBCTEST.py]
                                  PCRundefined 1 Reply Last reply Reply Quote 0
                                  • PCRundefined
                                    PCR @stuartofmt
                                    @stuartofmt
                                    192.168.140.126 Determine API Version
                                    192.168.140.126 Testing: rr_model at address 192.168.140.126
                                    192.168.140.126 http://192.168.140.126/rr_model?key=boards
                                    192.168.140.126
                                    192.168.140.126 Testing: /machine/system at address 192.168.140.126
                                    192.168.140.126 http://192.168.140.126/machine/status
                                    192.168.140.126
                                    192.168.140.126 API model is: machine   Version is: 3
                                    192.168.140.126 Status is :processing
                                    192.168.140.126 Layer is :0
                                    --- Logging error ---
                                      File "/usr/lib/python3.7/logging/__init__.py", line 1034, in emit
                                        msg = self.format(record)
                                      File "/usr/lib/python3.7/logging/__init__.py", line 880, in format
                                        return fmt.format(record)
                                      File "/usr/lib/python3.7/logging/__init__.py", line 619, in format
                                        record.message = record.getMessage()
                                      File "/usr/lib/python3.7/logging/__init__.py", line 380, in getMessage
                                        msg = msg % self.args
                                    TypeError: not all arguments converted during string formatting
                                    Call stack:
                                      File "./sbctest.py", line 147, in <module>
                                      File "./sbctest.py", line 127, in sendDuetGcode
                                        logger.info("gCode command return code = ",r.status_code)
                                    Message: 'gCode command return code = '
                                    Arguments: (405,)
                                    Call stack:
                                    Arguments: (405,)
                                    192.168.140.126 Method Not Allowed
                                    TypeError: can only concatenate str (not "int") to str
                                      stuartofmt
                                      @PCR @jay_s_uk
                                      Thanks - there was a silly formatting error (now fixed) but underlying that it looks like there was an http 405 error returned.
                                      I've added a two more version of the send gcode function to try - hopefully one of them works. Unfortunately the documentation and other examples (which purport to work) are somewhat vague on this aspect ....
                                      ALSO - if you are running RRF3.2 the default behavior for CORS seems to have changed. With another program I am using (DueUI) - I had to add the following to config.sys (up front in the network section) - after the upgrade. BUT DuetLapse was unaffected. It MAY be different on SBC.
                                      I'd suggest first trying "as is" but if this script still does not work with one of the methods (depending on what the errors are) - the CORS thing may need to be looked into.
                                      M586 C"*"                                     ;enable CORS
                                      New Test Script is here
                                      [SBCTEST.py]
                                      • fractalengineerundefined
                                        fractalengineer
                                        Awesome Stuart, thanks for carrying on Danal's work
                                        Looks well documented too, I'll give it a shot over the weekend.
                                        Very neat of you to handle issues outside of your own setup too
                                        Do you think in it's current state this could realistically be implemented as a plugin in DWC for a possible GUI?
                                        Railcore II ZL
                                        stuartofmtundefined 1 Reply Last reply Reply Quote 2
                                          stuartofmt @fractalengineer
                                          @fractalengineer
                                          Thanks. As a plugin ? hmmm . I'll have to see what that means / entails. Let me put that as a priority 2 for right now.
                                          Priority 1 is getting SSB working and tidying up some of the logic / behavior surrounding pauses. I did not test that aspect much and its somewhat ambiguous - so stay tuned ...
                                            @stuartofmt
                                            192.168.1.31 Determine API Version
                                            192.168.1.31 Testing: rr_model at address 192.168.1.31
                                            192.168.1.31 http://192.168.1.31/rr_model?key=boards
                                            192.168.1.31
                                            192.168.1.31 Testing: /machine/system at address 192.168.1.31
                                            192.168.1.31 http://192.168.1.31/machine/status
                                            192.168.1.31
                                            192.168.1.31 API model is: SBC   Version is: 3
                                            192.168.1.31 Status is :idle
                                            192.168.1.31 Layer is :0
                                            192.168.1.31 ***Testing V0***
                                            405
                                            Method Not Allowed
                                            192.168.1.31 gCode command return code = 405
                                            192.168.1.31 Method Not Allowed
                                            192.168.1.31 Send Gcode result: 405
                                            192.168.1.31 ***Testing V1***
                                            200
                                            OK
                                            192.168.1.31 Send Gcode result: 0
                                            192.168.1.31 ***Testing V2***
                                            404
                                            Not Found
                                            192.168.1.31 gCode command return code = 404
                                            192.168.1.31 Not Found
                                            192.168.1.31 Send Gcode result: 404
