    Error M587:Failed to add SSID to remembered list.
    Duet Web Control
    1.0k
    • Hiroakiundefined
      Hiroaki
      Hello.
      Yesterday when I tried to print from SD card, suddenly the light of the wifi module started to blink very fast.
      After that I appeared that the wifi module doesn't work.
      I have once Erased the Firmware from the board and re-installed.
      The version is 2.05.1.
      Then I sent M552 S1 and M587 S"ooxx" P"ooxx"
      Unfortuantely the error "M587:Failed to add SSID to remembered list." came back.
      I have sent only M587.
      Then I see, "Failed to retrieve network list"
      Maybe the wifi module has got a problem ???
      Please help!
        jay_s_uk
        i suggest reflashing the wifi firmware first
        https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_WiFi_firmware
        https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/DuetWiFiServer-1.23.bin
        Hiroakiundefined 1 Reply Last reply Reply Quote 0
          droftarts administrators @Hiroaki
          @Hiroaki Connect via USB, send M552 S-1 to turn WiFi off, then M552 S0 to turn it on, but in idle mode, then add the SSID with M587. Finally, enable WiFi with M552 S1.
          • Hiroakiundefined
            Hiroaki @jay_s_uk
            @jay_s_uk Hello Thank you for your comment.
            I have done it, but still the same...
            • Hiroakiundefined
              Hiroaki @droftarts
              @droftarts Hello. Thank you for your comment, I did it.
              When I send M552 S-1, the light of the wifi module was turned off.
              When I sent M552 S0, it's turned on again.
              But when I sent M587 S"ooxx" P"ooxx" it's still the same...
              Only One I can't get is "Idle mode" I put....
              • Hiroakiundefined
                Hiroaki @Hiroaki
                @Hiroaki Sorry "Idle mode" you put.
                  @Hiroaki Can you send M122 and post full reply. How old is the Duet?
                  And what board revision? eg 1.02, 1.04c
                  • Hiroakiundefined
                    Hiroaki @droftarts
                    @droftarts
                    Hello The board is quite new.
                    I bought it about two months ago, but as I have been building the machine, it's still like new.
                    The answer of M122 is as floows. Thank you.
                    === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later + DueX5<LF>Board ID: 08DJM-956GL-M43T0-6JKDL-3S86P-994YQ<LF>Used output buffers: 1 of 24 (2 max)<LF>=== RTOS ===<LF>Static ram: 25712<LF>Dynamic ram: 93980 of which 84 recycled<LF>Exception stack ram used: 264<LF>Never used ram: 11032<LF>Tasks: NETWORK(ready,1884) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3824) IDLE(ready,160)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:00:14 ago, cause: power up<LF>Last software reset time unknown, reason: User, spinning module GCodes, available RAM 10896 bytes (slot 2)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 50.4, current 52.0, max 56.3<LF>Supply voltage: min 0.5, current 0.5, max 0.8, under voltage events: 0, over vol[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
                    • Hiroakiundefined
                      Hiroaki @Hiroaki
                      @Hiroaki The version is 1.04.
                        @Hiroaki The M122 reply has been cut off, and the WiFi diagnostics is missing. If you are connecting with YAT:
                        Set YAT to use <LF> as the end of line character. This will improve the readability of the messages coming from the Duet. Click "Text Settings" in the "Terminal Settings" and change "EOL sequence:" to <LF>. Click "OK" to close Text Settings. Click "OK" again to close Terminal Settings.
                        Hiroakiundefined 2 Replies Last reply Reply Quote 0
                        • Hiroakiundefined
                          Hiroaki @droftarts
                          @droftarts Thank you.
                          This is it.
                          Static ram: 25712
                          Tasks: NETWORK(ready,1884) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3836) IDLE(ready,160)
                          Owned mutexes:
                          Last reset 00:06:48 ago, cause: power up
                          Error status: 0
                          MCU temperature: min 29.5, current 32.0, max 65.8
                          Supply voltage: min 0.0, current 0.5, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
                          Driver 0: ok, SG min/max not available
                          Driver 1: ok, SG min/max not available
                          Driver 2: ok, SG min/max not available
                          Driver 3: ok, SG min/max not available
                          Driver 4: ok, SG min/max not available
                          Driver 5: ok, SG min/max not available
                          Driver 6: ok, SG min/max not available
                          Driver 7: ok, SG min/max not available
                          Driver 8: ok, SG min/max not available
                          Driver 9: ok, SG min/max not available
                          Cache data hit count 681994076
                          Slowest loop: 1.58ms; fastest: 0.05ms
                          Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                          === DDARing ===
                          Heater 1 is on, I-accum = 0.0
                          Segments left: 0
                          Movement lock held by null
                          http is idle in state(s) 0
                          telnet is idle in state(s) 0
                          file is idle in state(s) 0
                          serial is ready with "M122" in state(s) 0
                          aux is idle in state(s) 0
                          daemon is idle in state(s) 0
                          queue is idle in state(s) 0
                          Code queue is empty.
                          === Network ===
                          Slowest loop: 0.84ms; fastest: 0.00ms
                          HTTP sessions: 0 of 8
                          • WiFi -
                            Network state is starting
                            WiFi module is disabled
                            ok
                          • Hiroakiundefined
                            Hiroaki @droftarts
                            @droftarts
                            M552 s-1
                            WiFi module stopped
                            ok
                            M552 s0
                            ok
                            M122
                            then it was still
                            • WiFi -
                              ok
                              @Hiroaki Send M552 S-1, then M122, M552 S0, then M122, and M552 S1, then M122. This is what the response from my Duet 2 WiFi looks like (you can just copy the WiFi part at the end):
                              M552 S-1
                              WiFi module stopped
                              ok
                              M122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later
                              Board ID: 08DGM-9T6BU-FG3SD-6JKD4-3S86N-KAMHF
                              -WiFi -
                              Network state is disabled
                              ok
                              M552 S0
                              ok
                              WiFi module started
                              M122
                              -WiFi -
                              Network state is running
                              WiFi module is idle
                              WiFi firmware version 1.23
                              WiFi MAC address a0:20:a6:31:b4:b9
                              WiFi Vcc 3.36, reset reason Turned on by main processor
                              WiFi flash size 4194304, free heap 30176
                              ok
                              M552 S1
                              ok
                              WiFi module is connected to access point BTWholeHome-XXX, IP address 192.168.0.12
                              M122
                              -WiFi -
                              WiFi Vcc 3.37, reset reason Turned on by main processor
                              WiFi flash size 4194304, free heap 25568
                              WiFi IP address 192.168.0.12
                              WiFi signal strength -43dBm, reconnections 0, sleep mode modem
                              ok
                              If you're not getting something similar, I'd guess that the WiFi module has failed. The usual reason for this is a power surge on the 3.3V line; the WiFi board and SD card are often the first to fail if this has happened, but can protect the main processor from failing.
                              It is possible that the WiFi module firmware has not flashed correctly. Try downloading a fresh DuetWiFiServer-1.23.bin from https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1 and upload it to the 'sys' folder on the SD card, then send M997 S1.
                              • beachtecundefined
                                beachtec
                                Hello @Hiroaki... I have had this issue myself a few times. The advice here did solve it; but I had to do it a couple of times. Re-flashing the firmware more than once might be necessary. I also found that in BOSSA, using the setting "erase all" seemed to yield the best results. Good luck to you!
                                • Hiroakiundefined
                                  Hiroaki @droftarts
                                  @droftarts Thank you. As it's getting late night, I will do it tomorrow.
                                  By the way do you think it's possible to change the wifi module ?
                                  • Hiroakiundefined
                                    Hiroaki @beachtec
                                    @beachtec Thank you. I will try tomorrow. It's 0:21AM ...
                                    Best Regards
                                    • Hiroakiundefined
                                      Hiroaki @droftarts
                                      @droftarts
                                      One question .
                                      Upload Duetwifiserver-1.23.bin to the SYS not WWW folder?
                                      Regards
                                        @Hiroaki said in Error M587:Failed to add SSID to remembered list.:
                                        One question .
                                        Yes, firmware updates go in the 'sys' folder. The 'www' folder is for DWC components.
                                        • Hiroakiundefined
                                          Hiroaki @droftarts
                                          @droftarts ok Thank you.
                                            I think you'll need to rename the file and remove the -1.23 part so that the final file name is just DuetWiFiServer.bin
