    G32 ERROR
    5.3k
      And if you check M119 what does the endstop status say?
      If it says the z endstop is triggered but the switch isn't pressed, then you would need to add the ! again to invert the signal.
      moe.adams9093undefined 1 Reply Last reply Reply Quote 0
      • moe.adams9093undefined
        moe.adams9093 @Phaedrux
        @Phaedrux yes thats what I got
        2/1/2021, 1:30:18 PM: M119: Endstops - X: not stopped, Y: not stopped, Z: at max stop, Z probe: not stopped
          moe.adams9093 @moe.adams9093
          I'm going to put ! back and see what's going on
            moe.adams9093
            The only one is communicating probably is e6stop
              moe.adams9093
              Its not working. when I added this code
              M574 Z2 S1 p"!duex.e6stop+!duex.e5stop+!duex.e3stop+!duex.e4stop";
              and run M119
              M119
              Endstops - X: at min stop, Y: at min stop, Z: no endstop, Z probe: not stopped
              but If I remove any one of any of the above endstops
              example:
              M574 Z2 S1 p"!duex.e6stop+!duex.e5stop+!duex.e3stop";
              my M119 will show Z end stop is available I don't know what's causing this issue to not take all 4endstops. also when I press any of the endstops they all stop automatically not individually. I don't know whats happening maybe my duex 5 is bad or if you guys know any solution around please let me know. thank you
                moe.adams9093
                I believe somehow some of my end stop input on my duex 5 is not responding correctly. can I use stall detection to stop each motor at Zmax. please share your thoughts
                fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                • alankilianundefined
                  alankilian
                  @dc42 I hate to jump in and be an idiot, but is it because MaxAxes is set to six in the firmware?
                  • fcwiltundefined
                    fcwilt @moe.adams9093
                    @moe-adams9093 said in G32 ERROR:
                    I have the same board setup as you - Duet 2 WiFi + Duex5.
                    On my printer I only have 3 Z steppers so my end stop configuration command is:
                    M574 Z1 S1 P"!duex.e2stop + !duex.e3stop + !duex.e4stop"
                    As an experiment I entered this on the DWC Console
                    M574 Z1 S1 P"!duex.e2stop + !duex.e3stop + !duex.e4stop + !duex.e5stop"
                    and got this error message:
                    Error: M574: Unknown pin name 'duex.e5sto'
                    Notice the last character, the p, is missing.
                    I then took that same text and created a gcode file with it in my sys directory.
                    I executed the file with the M98 command and got the same error.
                    I then used this text to create another gcode file with it in my sys directory:
                    M574 Z1 S1 P"!exp.4 + !exp.9 + !exp.14 + !exp.19"
                    which are alternate names for the pins.
                    I executed the file with the M98 command and got NO error.
                    Then I executed from the DWC console a M574 and got this:
                    Endstop configuration:
                    X: low end switch connected to pin xstop
                    Y: high end switch connected to pin ystop
                    Z: low end switches connected to pins !(exp.e2stop,exp.4) !(exp.e3stop,exp.9,spi.cs6,duex.cs6) !(exp.e4stop,exp.14,spi.cs7,duex.cs7) !(exp.e5stop,exp.19,spi.cs8,duex.cs8)
                    Notice for Z that all four pins are now present - albeit with all possible names for each pin.
                    It looks like there may be some sort of command length limitation causing the problem.
                    I tried this test with both 3.1.1 and 3.2.0.
                    Try the alternate names and see if they work for you.
                      Phaedrux Moderator @fcwilt
                      @fcwilt Do you get the same error with the original pin names he had used?
                      M574 Z2 S1 P"!exp.e2stop+!exp.e3stop+!exp.e5stop+!exp.e6stop"
                      fcwiltundefined 2 Replies Last reply Reply Quote 0
                      • fcwiltundefined
                        fcwilt @Phaedrux
                        @Phaedrux said in G32 ERROR:
                        Hold on and I will try.
                          Phaedrux Moderator @alankilian
                          @alankilian said in G32 ERROR:
                          It shouldn't because in RRF3 you can use multiple endstops on a single axis. No need to create additional axis anymore.
                          • fcwiltundefined
                            fcwilt @Phaedrux
                            That works.
                              @fcwilt Hmm, wonder why it didnt work for him the first time?
                              • fcwiltundefined
                                fcwilt @Phaedrux
                                I have no idea - this topic has gotten rather long and it's hard to remember it all.
                                Those names you suggested are shorter by one character each which tends to reinforce the idea of a command length limitation.
                                Perhaps you could speed verification of this possibility with direct communication with dc42?
                                Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                  Phaedrux Moderator @moe.adams9093
                                  Yes. M574 Z2 S4. But you'll have to do the usual stall detection tuning.
                                    @fcwilt said in G32 ERROR:
                                    He's aware. But also asleep at the moment I'd wager.
                                    • fcwiltundefined
                                      fcwilt @Phaedrux
                                      I have little idea of who lives where.
                                      My hours are so erratic I'm not sure what time zone I'm supposed to be in. 😉
                                        moe.adams9093
                                        Sorry It's US central Time Here maybe we are 8 hours difference.
                                        it's not working at all.
                                          Can you try testing on 3.1.1?
                                          It's easy to switch between. Upload this zip file to the system tab. No need to change the config file.
                                          https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
                                            moe.adams9093
                                            so you dont thing the duex 5 is bad
                                            and run m119 it will show the endstop is triggered at max
