    D-PATCH
    My Duet controlled machine
    10
    46
    3.8k
    • Vetiundefined
      Veti
      this looks like a sci fi attack hovercraft
      • HebigTundefined
        HebigT @taconite
        @taconite Thanks for the reply!
        Is the tool-changer "carriage" set up as an additional axis? How does it increment along with the Z-axis?
        • taconiteundefined
          taconite
          @jpomo10
          Yep it is set up as U axis. I wrote a custom post-processing script for cura 😉
          Custom ANET A8
          Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
          All I do here is under this license: CC BY-NC-SA
          • taconiteundefined
            taconite
            Hey guys,
            I keep posting small videos - some are not really special but I still want to share them with you: https://youtu.be/6-CR_1vN3cE
            In this small video I print with my go-to 100mm/s-profile
            And I just uploaded a video of the change of 4 tools
            https://youtu.be/aJt_HRal5rY
            Custom ANET A8
            HebigTundefined 1 Reply Last reply Reply Quote 2
            • HebigTundefined
              HebigT @taconite
              @taconite Thanks for the links!
              Also, check out the posts about a TC Delta on this page: https://twitter.com/deltamaker
              taconiteundefined 1 Reply Last reply Reply Quote 0
              • taconiteundefined
                taconite @HebigT
                @jpomo10 Nice to see that others are thinking about options aswell.
                To be honest these were my first attempts aswell. The first concept was magnets and the second one permanent-electromagnets after that, but after a lot of testing I decided not to use magnets.
                Custom ANET A8
                • taconiteundefined
                  taconite
                  Hello guys,
                  I went a new way for the cooling of the tools without some parts of the sci fi attack hovercraft.
                  I added a fan to each tool instead. The data shows that the cooling is sufficient.
                  Custom ANET A8
                  • taconiteundefined
                    taconite
                    Hey guys,
                    so at the moment the printer is 99% finished. Just some minor modifications need to be done.
                    If there is interest in the community I will put the files on thingiverse and a BOM and some instructions on github - just let me know.
                    Custom ANET A8
                    o_lampeundefined 1 Reply Last reply Reply Quote 1
                    • o_lampeundefined
                      o_lampe @taconite
                      @taconite said in D-PATCH:
                      I'm sure there is a big interest, but the custom CNC parts are cooling down my curiosity.
                      Why not open a (kickstarter) campaign and sell the required parts?
                      • taconiteundefined
                        taconite
                        @o_lampe
                        Valid point but the good thing is the only custom CNC part necessary are the conical rings for the tools and those will not break the bank.
                        The sheet metal parts are not needed for the system to work. Everything else can be 3d printed or not a problem to source.
                        Currently I am working on an improved V3 which need more metal parts to be custom made, but this version should be a good option for the typical maker
                        Custom ANET A8
                        • o_lampeundefined
                          o_lampe @taconite
                          The pieces of the bayonet that lock the tool are angled so a downward force is created by the rotation of the bayonet. It is locking onto 3 zylindrical pins that are placed 120° apart from each other so that the locking is uniformly
                          This part is the most interesting detail to me.
                          I'm currently planning to make a tool changer for my CoreXY with a Titan extruder. I want to change the heatsink only and until now I'm on a magnetic twist & snap road. Your design looks much easier to implement, but a CoreXY can't lower the effector to release the heatsink.
                          Anyway, I'll mention you in my Biography if I steal this idea from you 😉
                          taconiteundefined 1 Reply Last reply Reply Quote 1
                          • taconiteundefined
                            taconite @o_lampe
                            @o_lampe said in D-PATCH:
                            What you could do is a C shaped bayonett so you open up the groove-mount and close it again. The C could hav a little bulk in the middle to press the groove into the correct position
                            Custom ANET A8
                            • o_lampeundefined
                              o_lampe @taconite
                              @taconite
                              That's an option. I had a different idea last night:
                              I use these two hotend pickup pins as twist&lock pins, too.
                              The pins would be *U-*shaped and they are mounted into the heatsink-adapter. The tool changer would then connect with the pins and the guides inside the tool changer would twist the pins to unlock the hotend from the Titan housing. I have no idea how to design this twist in Fusion360. But I'll post it in my Blog
                              • taconiteundefined
                                taconite
                                Hey guys,
                                just a quick update. Here you can see a printed spur-gear with different functionalities.
                                Custom ANET A8
                                JoergS5undefined 1 Reply Last reply Reply Quote 1
                                • JoergS5undefined
                                  JoergS5 @taconite
                                  Can you please explain the different functionalities? Seems you mixed different material to get different properties (stiffness, flexibility/compliance?)
                                  • taconiteundefined
                                    taconite
                                    So of course the functionalities come with the multi-material print
                                    1. reduced friction and therefor wear
                                    2. increased strength/stiffness
                                    3. flexible material for compliance/dampening of torque peaks
                                    4. Sensor element for the detection of wear
                                    Custom ANET A8
                                    • JoergS5undefined
                                      JoergS5 @taconite
                                      @taconite thank you for explaining! Do you use some of those BF350 as sensor or something different?
                                      • taconiteundefined
                                        taconite
                                        Better 😉 conductive filament
                                        Custom ANET A8
                                        • JoergS5undefined
                                          JoergS5 @taconite
                                          @taconite clever idea!
                                          • taconiteundefined
                                            taconite
                                            Here you can see some better pictures of the D-PATCH
                                            Custom ANET A8
                                            HebigTundefined PCRundefined 2 Replies Last reply Reply Quote 3
