    D-PATCH
    My Duet controlled machine
    10
    46
    3.8k
    • taconiteundefined
      taconite
      Hey guys,
      I keep posting small videos - some are not really special but I still want to share them with you: https://youtu.be/6-CR_1vN3cE
      In this small video I print with my go-to 100mm/s-profile
      And I just uploaded a video of the change of 4 tools
      https://youtu.be/aJt_HRal5rY
      Custom ANET A8
      Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
      All I do here is under this license: CC BY-NC-SA
      HebigTundefined 1 Reply Last reply Reply Quote 2
      • HebigTundefined
        HebigT @taconite
        @taconite Thanks for the links!
        Also, check out the posts about a TC Delta on this page: https://twitter.com/deltamaker
        taconiteundefined 1 Reply Last reply Reply Quote 0
        • taconiteundefined
          taconite @HebigT
          @jpomo10 Nice to see that others are thinking about options aswell.
          To be honest these were my first attempts aswell. The first concept was magnets and the second one permanent-electromagnets after that, but after a lot of testing I decided not to use magnets.
          Custom ANET A8
          • taconiteundefined
            taconite
            Hello guys,
            I went a new way for the cooling of the tools without some parts of the sci fi attack hovercraft.
            I added a fan to each tool instead. The data shows that the cooling is sufficient.
            Custom ANET A8
            • taconiteundefined
              taconite
              Hey guys,
              so at the moment the printer is 99% finished. Just some minor modifications need to be done.
              If there is interest in the community I will put the files on thingiverse and a BOM and some instructions on github - just let me know.
              Custom ANET A8
              o_lampeundefined 1 Reply Last reply Reply Quote 1
              • o_lampeundefined
                o_lampe @taconite
                @taconite said in D-PATCH:
                I'm sure there is a big interest, but the custom CNC parts are cooling down my curiosity.
                Why not open a (kickstarter) campaign and sell the required parts?
                • taconiteundefined
                  taconite
                  @o_lampe
                  Valid point but the good thing is the only custom CNC part necessary are the conical rings for the tools and those will not break the bank.
                  The sheet metal parts are not needed for the system to work. Everything else can be 3d printed or not a problem to source.
                  Currently I am working on an improved V3 which need more metal parts to be custom made, but this version should be a good option for the typical maker
                  Custom ANET A8
                  • o_lampeundefined
                    o_lampe @taconite
                    The pieces of the bayonet that lock the tool are angled so a downward force is created by the rotation of the bayonet. It is locking onto 3 zylindrical pins that are placed 120° apart from each other so that the locking is uniformly
                    This part is the most interesting detail to me.
                    I'm currently planning to make a tool changer for my CoreXY with a Titan extruder. I want to change the heatsink only and until now I'm on a magnetic twist & snap road. Your design looks much easier to implement, but a CoreXY can't lower the effector to release the heatsink.
                    Anyway, I'll mention you in my Biography if I steal this idea from you 😉
                    taconiteundefined 1 Reply Last reply Reply Quote 1
                    • taconiteundefined
                      taconite @o_lampe
                      @o_lampe said in D-PATCH:
                      What you could do is a C shaped bayonett so you open up the groove-mount and close it again. The C could hav a little bulk in the middle to press the groove into the correct position
                      Custom ANET A8
                      • o_lampeundefined
                        o_lampe @taconite
                        @taconite
                        That's an option. I had a different idea last night:
                        I use these two hotend pickup pins as twist&lock pins, too.
                        The pins would be *U-*shaped and they are mounted into the heatsink-adapter. The tool changer would then connect with the pins and the guides inside the tool changer would twist the pins to unlock the hotend from the Titan housing. I have no idea how to design this twist in Fusion360. But I'll post it in my Blog
                        • taconiteundefined
                          taconite
                          Hey guys,
                          just a quick update. Here you can see a printed spur-gear with different functionalities.
                          Custom ANET A8
                          JoergS5undefined 1 Reply Last reply Reply Quote 1
                          • JoergS5undefined
                            JoergS5 @taconite
                            Can you please explain the different functionalities? Seems you mixed different material to get different properties (stiffness, flexibility/compliance?)
                            • taconiteundefined
                              taconite
                              So of course the functionalities come with the multi-material print
                              1. reduced friction and therefor wear
                              2. increased strength/stiffness
                              3. flexible material for compliance/dampening of torque peaks
                              4. Sensor element for the detection of wear
                              Custom ANET A8
                              • JoergS5undefined
                                JoergS5 @taconite
                                @taconite thank you for explaining! Do you use some of those BF350 as sensor or something different?
                                • taconiteundefined
                                  taconite
                                  Better 😉 conductive filament
                                  Custom ANET A8
                                  • JoergS5undefined
                                    JoergS5 @taconite
                                    @taconite clever idea!
                                    • taconiteundefined
                                      taconite
                                      Here you can see some better pictures of the D-PATCH
                                      Custom ANET A8
                                      HebigTundefined PCRundefined 2 Replies Last reply Reply Quote 3
                                      • HebigTundefined
                                        HebigT @taconite
                                        @taconite Happy to see this project alive and well!
                                        • PCRundefined
                                          PCR @taconite
                                          @taconite would IT be possible to get the Files for rebuilding? Best
                                          • taconiteundefined
                                            taconite
                                            @HebigT slow and steady 😄
                                            @PCR Sure if there is demand I will put all the files plus BOM on Github (or similar). The one you see is lets say the "maker" version where you need close to no custom parts.
                                            At the moment I work on another version with some improvements (which can be easily implemented in the maker version)
                                            Custom ANET A8
                                            PCRundefined 2 Replies Last reply Reply Quote 2
