    D-PATCH
    My Duet controlled machine
    10
    46
    3.7k
    • fškundefined
      fšk @taconite
      @taconite that's a cool design. Where did you get the tapered metal parts?
      • taconiteundefined
        taconite
        @fšk thank you 😉
        I designed the tool so, that it utalizes standard stock material. The tapered part was done by a friend of mine on a standard lathe.
        Custom ANET A8
        Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
        All I do here is under this license: CC BY-NC-SA
        • taconiteundefined
          taconite
          Tool Change Scripts
          Custom ANET A8
          • taconiteundefined
            taconite
            Tool Changing of two tools can be seen here:
            https://youtu.be/nLvNUum48fg
            upcoming is the first multi-material print
            Custom ANET A8
            JoergS5undefined 1 Reply Last reply Reply Quote 1
            • JoergS5undefined
              JoergS5 @taconite
              @taconite that's a nice tool changer!
              • HebigTundefined
                HebigT
                @taconite Hey any thoughts about preventing heat-creep after a (hot) tool is placed back on the carousel?
                • taconiteundefined
                  taconite
                  @JoergS5 Thank you
                  @jpomo10 of course ;). There are multiple options:
                  1. set the stand-by temperature so low, that a equilibrium is reached
                    (+ no additional fans, - long heat up time)
                  2. one fan for each tool in parking position
                    (+ sufficient cooling, - lot of fans with lots of noise)
                  3. one bigger fan with a fan-duct to direct the air to the heat sinks of the tools in parking position
                  For now I have no fans at all. So after the first prints I had not a lot of heat creep and no problems with jams. But I guess I will move on with option 3
                  BTW: I posted another video of the first dual color print on youtube
                  Custom ANET A8
                  HebigTundefined 1 Reply Last reply Reply Quote 4
                  • Vetiundefined
                    Veti
                    this looks like a sci fi attack hovercraft
                    • HebigTundefined
                      HebigT @taconite
                      @taconite Thanks for the reply!
                      Is the tool-changer "carriage" set up as an additional axis? How does it increment along with the Z-axis?
                      • taconiteundefined
                        taconite
                        @jpomo10
                        Yep it is set up as U axis. I wrote a custom post-processing script for cura 😉
                        Custom ANET A8
                        • taconiteundefined
                          taconite
                          Hey guys,
                          I keep posting small videos - some are not really special but I still want to share them with you: https://youtu.be/6-CR_1vN3cE
                          In this small video I print with my go-to 100mm/s-profile
                          And I just uploaded a video of the change of 4 tools
                          https://youtu.be/aJt_HRal5rY
                          Custom ANET A8
                          HebigTundefined 1 Reply Last reply Reply Quote 2
                          • HebigTundefined
                            HebigT @taconite
                            @taconite Thanks for the links!
                            Also, check out the posts about a TC Delta on this page: https://twitter.com/deltamaker
                            taconiteundefined 1 Reply Last reply Reply Quote 0
                            • taconiteundefined
                              taconite @HebigT
                              @jpomo10 Nice to see that others are thinking about options aswell.
                              To be honest these were my first attempts aswell. The first concept was magnets and the second one permanent-electromagnets after that, but after a lot of testing I decided not to use magnets.
                              Custom ANET A8
                              • taconiteundefined
                                taconite
                                Hello guys,
                                I went a new way for the cooling of the tools without some parts of the sci fi attack hovercraft.
                                I added a fan to each tool instead. The data shows that the cooling is sufficient.
                                Custom ANET A8
                                • taconiteundefined
                                  taconite
                                  Hey guys,
                                  so at the moment the printer is 99% finished. Just some minor modifications need to be done.
                                  If there is interest in the community I will put the files on thingiverse and a BOM and some instructions on github - just let me know.
                                  Custom ANET A8
                                  o_lampeundefined 1 Reply Last reply Reply Quote 1
                                  • o_lampeundefined
                                    o_lampe @taconite
                                    @taconite said in D-PATCH:
                                    I'm sure there is a big interest, but the custom CNC parts are cooling down my curiosity.
                                    Why not open a (kickstarter) campaign and sell the required parts?
                                    • taconiteundefined
                                      taconite
                                      @o_lampe
                                      Valid point but the good thing is the only custom CNC part necessary are the conical rings for the tools and those will not break the bank.
                                      The sheet metal parts are not needed for the system to work. Everything else can be 3d printed or not a problem to source.
                                      Currently I am working on an improved V3 which need more metal parts to be custom made, but this version should be a good option for the typical maker
                                      Custom ANET A8
                                      • o_lampeundefined
                                        o_lampe @taconite
                                        The pieces of the bayonet that lock the tool are angled so a downward force is created by the rotation of the bayonet. It is locking onto 3 zylindrical pins that are placed 120° apart from each other so that the locking is uniformly
                                        This part is the most interesting detail to me.
                                        I'm currently planning to make a tool changer for my CoreXY with a Titan extruder. I want to change the heatsink only and until now I'm on a magnetic twist & snap road. Your design looks much easier to implement, but a CoreXY can't lower the effector to release the heatsink.
                                        Anyway, I'll mention you in my Biography if I steal this idea from you 😉
                                        taconiteundefined 1 Reply Last reply Reply Quote 1
                                        • taconiteundefined
                                          taconite @o_lampe
                                          @o_lampe said in D-PATCH:
                                          What you could do is a C shaped bayonett so you open up the groove-mount and close it again. The C could hav a little bulk in the middle to press the groove into the correct position
                                          Custom ANET A8
                                          • o_lampeundefined
                                            o_lampe @taconite
                                            @taconite
                                            That's an option. I had a different idea last night:
                                            I use these two hotend pickup pins as twist&lock pins, too.
                                            The pins would be *U-*shaped and they are mounted into the heatsink-adapter. The tool changer would then connect with the pins and the guides inside the tool changer would twist the pins to unlock the hotend from the Titan housing. I have no idea how to design this twist in Fusion360. But I'll post it in my Blog
