    RepRapFirmware 3.3beta1 now available
    Beta Firmware
    12
    36
    2.7k
      I've just released this at https://github.com/Duet3D/RepRapFirmware/releases/tag/3.3beta1. See https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3_Beta.md for the change list.
      If you encounter any new issues in the release that were not present in release 3.2.2, please start a new thread to describe it.
      User3Dundefined 1 Reply Last reply Reply Quote 1
      • Vetiundefined
        Veti
        when you create the zip file can you please include the old non 3.2 flashing iap files (3.0) files. this will help prevent a lot of problems that people are having?
          I don't do zip files for beta releases. Anyone who want to use 3.3beta1 should install 3.2.2 first if they haven't already, then install the new firmware and IAP files.
          • Vetiundefined
            Veti
            for the final release at least
              I'll add those files to the 3.2.2 zip.
              • Vetiundefined
                Veti @dc42
                thanks
                • Toastinatorundefined
                  Toastinator
                  Im Having issues with G1 XY Combined Movements, I Saw that this Beta Helps with Timing for the Expansion 1XD Boards.
                  Unfortunately after Updating, The Machine No Longer Homes and Gives an Error. Any Idea why that Might be? It worked on 3.2.2 Just had Combined Movement Issues.
                  • Vetiundefined
                    Veti @Toastinator
                    @Toastinator said in RepRapFirmware 3.3beta1 now available:
                    can you please specify the error
                      Toastinator
                      The Panel Due Says
                      Error: G0/G1: insufficent axes homed
                      When Using the Home All Command G28
                      • gloomyandyundefined
                        gloomyandy
                        @Toastinator Probably best to follow DC42's request and create a new thread for your problem.
                        • Nuramoriundefined
                          Nuramori
                          @dc42 does this beta also resolve the issue with updating the sammy21 firmware 2.2 on the toolboard? There was an issue of it not completing, and I believe you mentioned something with memory space.
                          • zaptaundefined
                            zapta
                            The new versions come fast and are typically not backward compatible which makes it a moving target.
                            Does Duet3d support also older versions? Any thoughts on declaring certain stable version and LTS?
                            https://en.wikipedia.org/wiki/Long-term_support
                            My personal interest is a LTS firmware version for the Duet2 Wifi such that if I will have a support issue I will not be asked to upgrade to latest version.
                              We don't have the resources to do an LTS version, however we do patch releases to older firmware versions sometimes, for example 2.05.1 and 3.2.2.
                              • tristanryerparkeundefined
                                tristanryerparke
                                This release has made sammyc21s not communicate with the main board. I couldn't find a sammy specific firmware file in the releases. I was previously running the 3.3 beta you shared on dropbox which had sammy specific files. Should I update them to a specific version other than where they are now?
                                Thanks,
                                T
                                  Users normally build the SAMMYC21 firmware themselves so they can modify it, however there is a prebuilt one for 3.3beta1 at https://www.dropbox.com/sh/mab3zs4h6bnwq3r/AABYyJanpjalGm2JA9WWUR3aa?dl=0.
                                    tristanryerparke
                                    @dc42 Thanks again,
                                    I am just using the SAMMYC21 for servo control, working now.
                                    • Nuramoriundefined
                                      Nuramori
                                      @dc42 For the toolboard v1.0, does the sam21 file need to be upgraded to 2.2? I haven't had luck with being able to update from 2.1 to 2.2
                                        dc42 administrators @Nuramori
                                        @Nuramori said in RepRapFirmware 3.3beta1 now available:
                                        If you mean the bootloader, it doesn't need to be updated.
                                        • oliofundefined
                                          oliof
                                          Has this been packaged for SBC builds? I am getting 3.2.2 still from the unstable feed.
                                            dc42 administrators @oliof
                                            @oliof said in RepRapFirmware 3.3beta1 now available:
                                            No, because currently it it intended to be used with DWC and DSF 3.2.2. That will change when we release a beta that needs a new DSF.
                                            Stephen6309undefined 1 Reply Last reply Reply Quote 1
