    RepRapFirmware 3.3beta1 now available
    Beta Firmware
    12
    36
    2.7k
      I don't do zip files for beta releases. Anyone who want to use 3.3beta1 should install 3.2.2 first if they haven't already, then install the new firmware and IAP files.
      • Vetiundefined
        Veti
        for the final release at least
          I'll add those files to the 3.2.2 zip.
          • Vetiundefined
            Veti @dc42
            thanks
            • Toastinatorundefined
              Toastinator
              Im Having issues with G1 XY Combined Movements, I Saw that this Beta Helps with Timing for the Expansion 1XD Boards.
              Unfortunately after Updating, The Machine No Longer Homes and Gives an Error. Any Idea why that Might be? It worked on 3.2.2 Just had Combined Movement Issues.
              • Vetiundefined
                Veti @Toastinator
                @Toastinator said in RepRapFirmware 3.3beta1 now available:
                can you please specify the error
                  Toastinator
                  The Panel Due Says
                  Error: G0/G1: insufficent axes homed
                  When Using the Home All Command G28
                  • gloomyandyundefined
                    gloomyandy
                    @Toastinator Probably best to follow DC42's request and create a new thread for your problem.
                    • Nuramoriundefined
                      Nuramori
                      @dc42 does this beta also resolve the issue with updating the sammy21 firmware 2.2 on the toolboard? There was an issue of it not completing, and I believe you mentioned something with memory space.
                      • zaptaundefined
                        zapta
                        The new versions come fast and are typically not backward compatible which makes it a moving target.
                        Does Duet3d support also older versions? Any thoughts on declaring certain stable version and LTS?
                        https://en.wikipedia.org/wiki/Long-term_support
                        My personal interest is a LTS firmware version for the Duet2 Wifi such that if I will have a support issue I will not be asked to upgrade to latest version.
                          We don't have the resources to do an LTS version, however we do patch releases to older firmware versions sometimes, for example 2.05.1 and 3.2.2.
                          • tristanryerparkeundefined
                            tristanryerparke
                            This release has made sammyc21s not communicate with the main board. I couldn't find a sammy specific firmware file in the releases. I was previously running the 3.3 beta you shared on dropbox which had sammy specific files. Should I update them to a specific version other than where they are now?
                            Thanks,
                            T
                              Users normally build the SAMMYC21 firmware themselves so they can modify it, however there is a prebuilt one for 3.3beta1 at https://www.dropbox.com/sh/mab3zs4h6bnwq3r/AABYyJanpjalGm2JA9WWUR3aa?dl=0.
                                tristanryerparke
                                @dc42 Thanks again,
                                I am just using the SAMMYC21 for servo control, working now.
                                • Nuramoriundefined
                                  Nuramori
                                  @dc42 For the toolboard v1.0, does the sam21 file need to be upgraded to 2.2? I haven't had luck with being able to update from 2.1 to 2.2
                                    dc42 administrators @Nuramori
                                    @Nuramori said in RepRapFirmware 3.3beta1 now available:
                                    If you mean the bootloader, it doesn't need to be updated.
                                    • oliofundefined
                                      oliof
                                      Has this been packaged for SBC builds? I am getting 3.2.2 still from the unstable feed.
                                        dc42 administrators @oliof
                                        @oliof said in RepRapFirmware 3.3beta1 now available:
                                        No, because currently it it intended to be used with DWC and DSF 3.2.2. That will change when we release a beta that needs a new DSF.
                                        Stephen6309undefined 1 Reply Last reply Reply Quote 1
                                        • Stephen6309undefined
                                          Stephen6309 @dc42
                                          @dc42 On my 6HC with a PI 4, did a update/upgrade and 3.3beta1 didn't install.
                                          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law.
                                          pi@CXY-MSv1:~ $ sudo apt-get update
                                          Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.8 kB]
                                          Get:2 http://packages.microsoft.com/repos/code stable InRelease [10.4 kB]
                                          Get:3 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
                                          Get:4 http://packages.microsoft.com/repos/code stable/main arm64 Packages [14.2 kB]
                                          Get:5 http://packages.microsoft.com/repos/code stable/main armhf Packages [14.2 kB]
                                          Get:6 http://packages.microsoft.com/repos/code stable/main amd64 Packages [13.7 kB]
                                          Hit:7 https://pkg.duet3d.com unstable InRelease
                                          Get:8 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
                                          Get:9 http://archive.raspberrypi.org/debian buster/main armhf Packages [364 kB]
                                          Fetched 13.5 MB in 8s (1,661 kB/s)
                                          Reading package lists... Done
                                          pi@CXY-MSv1:~ $ sudo apt-get upgrade
                                          Building dependency tree
                                          Reading state information... Done
                                          Calculating upgrade... Done
                                          The following packages were automatically installed and are no longer required:
                                          ffmpeg libjpeg8 rpi-eeprom-images
                                          Use 'sudo apt autoremove' to remove them.
                                          The following packages have been kept back:
                                          libpulse-mainloop-glib0 libpulse0 libpulsedsp pulseaudio
                                          pulseaudio-module-bluetooth pulseaudio-utils python-rpi.gpio
                                          The following packages will be upgraded:
                                          libssl1.1 openssl rpi-eeprom rpi-eeprom-images
                                          4 upgraded, 0 newly installed, 0 to remove and 7 not upgraded.
                                          Need to get 2,520 kB of archives.
                                          After this operation, 488 kB of additional disk space will be used.
                                          Do you want to continue? [Y/n] y
                                          Get:1 http://archive.raspberrypi.org/debian buster/main armhf rpi-eeprom armhf 11.7-1 [442 kB]
                                          Get:2 http://mirror.us.leaseweb.net/raspbian/raspbian buster/main armhf libssl1.1 armhf 1.1.1d-0+deb10u5 [1,263 kB]
                                          Get:4 http://archive.raspberrypi.org/debian buster/main armhf rpi-eeprom-images armhf 11.7-1 [7,824 B]
                                          Get:3 http://mirror.us.leaseweb.net/raspbian/raspbian buster/main armhf openssl armhf 1.1.1d-0+deb10u5 [807 kB]
                                          Fetched 2,520 kB in 2s (1,650 kB/s)
                                          Reading changelogs... Done
                                          Preconfiguring packages ...
                                          (Reading database ... 84232 files and directories currently installed.)
                                          Preparing to unpack .../libssl1.1_1.1.1d-0+deb10u5_armhf.deb ...
                                          Unpacking libssl1.1:armhf (1.1.1d-0+deb10u5) over (1.1.1d-0+deb10u4+rpt1) ...
                                          Preparing to unpack .../openssl_1.1.1d-0+deb10u5_armhf.deb ...
                                          Unpacking openssl (1.1.1d-0+deb10u5) over (1.1.1d-0+deb10u4+rpt1) ...
                                          Preparing to unpack .../rpi-eeprom_11.7-1_armhf.deb ...
                                          Unpacking rpi-eeprom (11.7-1) over (11.6-1) ...
                                          Preparing to unpack .../rpi-eeprom-images_11.7-1_armhf.deb ...
                                          Unpacking rpi-eeprom-images (11.7-1) over (11.6-1) ...
                                          Setting up libssl1.1:armhf (1.1.1d-0+deb10u5) ...
                                          Setting up rpi-eeprom (11.7-1) ...
                                          Setting up rpi-eeprom-images (11.7-1) ...
                                          Setting up openssl (1.1.1d-0+deb10u5) ...
                                          Processing triggers for man-db (2.8.5-2) ...
                                          Processing triggers for libc-bin (2.28-10+rpi1) ...
                                          • oliofundefined
                                            oliof
                                            @Stephen6309 see just the two posts above yours. This is by design, you need to upgrade to 3.3b1 manually.
