Duet maximum achievable step rates
47
6.2k
    Luke'sLaboratory
    Thank you for this!
    Its a nice reference point.
    Luke
    http://lukeslab.online
      deadwood83
      Might be a bit presumptive to ask since I do not know the heart of DSF very well, but would these rates conceivably be different with an SBC at a future date?
      I.e. is computational offload to SBC present/planned or will it remain as an alternative method of getting gcode to the board? Asking on behalf of my ~620step/mm extruder (duet 2).
      Also, good information though maybe on the high side? my duet2 cannot run a btech bmg at 417.29 steps/mm at 128 microstepping with 30mm/s retracts without accruing ~600 hiccups over a 2 hour print.
      Either way, this is some super good baseline information. Thanks.
      undefined 1 Reply Last reply 26 Sept 2020, 04:57 Reply Quote 0
        Phaedrux Moderator @deadwood83
        @deadwood83 said in Duet maximum achievable step rates:
        128 microstepping
        Such high microstepping is rarely beneficial. x16 with interpolation to x256 is definitely the way to go, especially for a Duet 2.
        undefined 1 Reply Last reply 26 Sept 2020, 06:14 Reply Quote 0
          deckingman @Phaedrux
          @Phaedrux said in Duet maximum achievable step rates:
          128 microstepping
          There is a usage case where higher micro stepping is desirable, as I have repeatedly pointed out. That is when using a mixing hot end whereby some of the filaments may be moving at single digit percentages of the total and therefore 16x does not give adequate resolution. There are other users who print highly detailed parts, using very small nozzles and layer heights. These users may need higher micro stepping and/or use highly geared extruders. Either way, a high step pulse frequency is required so it has been hugely disappointing to me that Duet3 has had a much lower step pulse frequency than Duet 2. I sincerely hope that the latest firmware will improve that situation but I'll wait until it moves out of the beta stage before I try it.
          undefined 1 Reply Last reply 26 Sept 2020, 06:15 Reply Quote 0
            Phaedrux Moderator @deckingman
            @deckingman yes I had your use case in mind when I said rarely.
            undefined 1 Reply Last reply 26 Sept 2020, 06:29 Reply Quote 0
              @Phaedrux Understood. BTW, with firmware 3.1 and extruders connected to expansion boards, I get extremely high hiccup count using 32X micro stepping. That's with 1.8 degree motors (roughly 400 steps per mm) and in non mixing mode. If I used 0.9 degree motors (800 steps per mm) which is not uncommon, then I would be seeing that high hiccup count using 16X micro stepping. That's how bad the step pulse frequency is with firmware 3.1.
              ? 1 Reply Last reply 20 Oct 2020, 11:54 Reply Quote 0
                A Former User @deckingman
                @deckingman
                What board do you use?
                Can you post more details e.g. the motor config section in config.g for others to better understand?
                undefined 1 Reply Last reply 20 Oct 2020, 12:20 Reply Quote 0
                  deckingman @A Former User
                  @LB I'm away from home at the moment but the low step pulse frequency is related to expansion boards and firmware version 3.1.1. The extruders are Bondtech BMGs with steps per mm of about 400 with 1.8 degree stepper motors. I can run these at only 16x microstepping and 30mm/sec retraction speed. Hopefully this situation will be improved with the 3.2 firmware but I'll wait for the beta testing phase to be completed before I attempt to install it.
                    deckingman
                    Resurecting this old thread because I've finally got around to testing the step pulse frequency on my 3HC expansion boards. Step pulse frequency is important to me because I use mixing hot ends and when one or more filaments are single digit percentages of the whole, the resultant extrusion amount can be less than one micro-step using 16X. Therefore it is necessary to use 128X micro-stepping but there is also a need to retract the filament at a reasonable fast speed.
                    Firmware is 3.2.2.
                    6 extruders in total, 3 connected to each of two expansion boards. Extruder setting - max speed 9000 mm/min, max instantaneous speed 3600mm/sec, acceleration, 6000 mm/sec^2. Other settings as per spread sheet.
                    Test method. No filament loaded. Retract/unretract distance set to 3mm. Run G10 - G11 - G10 - G11 then check hiccups using M122.
                    Results
                    RRF3.2.2 Expansion board step pulse frequency..ods
                    Please check my maths because my results are less than those shown on @dc42's spread sheet using 3.2 beta1 (the only value shown for 3 motors on a 3HC board). If they are correct, then it looks like the maximum "hiccup free" step pulse rate is around 131kHz or a tad higher (but no higher than 136kHz).
                    Conclusion. This is now on a par with Duet 2 - maybe a tad better. In any case, it allows me to run my extruders at 128x micro-stepping as is necessary with a mixing hot end, which is acceptable for me personally. So that's one gripe I can cross off my list 🙂
                    undefined 1 Reply Last reply 22 Feb 2021, 21:57 Reply Quote 3
                      That's good to hear Ian.
                      undefined 1 Reply Last reply 21 Feb 2021, 20:23 Reply Quote 0
                        I try to be balanced and give positive comments when something gets fixed, as well as hold your (as in the Duet team) feet to the fire when things are broken.
                          @deckingman I'd expect no less.
                            The SAME51 processor on the EXP3HC, SAME54 used on Duet 3 Mini and SAM4E used on Duet WiFi/Ethernet are all 120MHz ARM Cortex M4F processors. So it's expected that the maximum step rates should be similar. The SAME51 and SAME54 have more cache memory so they might be a little faster.
                              JoergS5 @deckingman
                              @deckingman said in Duet maximum achievable step rates:
                              I wonder why you used 128x, because with high microstepping of steppers you don't gain precision. I expect you need precision for mixing colors. I would expect to use a low microstepping with a high precision gear (1:16 or similar gear ratio). The low microstepping mode must have a high frequency then.
                              undefined dc42undefined 2 Replies Last reply 22 Feb 2021, 22:13 Reply Quote 0
                                engikeneer @JoergS5
                                @JoergS5 because he needs high accuracy not high precision. With a mixing hot end you want to still move the unused filaments forward slowly (Ian has written a lot about it on his blog and YouTube!). With that he needs higher microstepping to actually achieve a very slow, constant movement.
                                Granted, in most 3d printing anything more than 16x (with interpolation) is useless, but this is one of the exceptions
                                i3 clone with a bunch of mods
                                undefined 1 Reply Last reply 22 Feb 2021, 22:32 Reply Quote 0
                                  JoergS5 @engikeneer
                                  @engikeneer thank you for explaining. I'll check Ian's blogs.
                                    dc42 administrators @JoergS5
                                    @JoergS5 said in Duet maximum achievable step rates:
                                    I wondered that too, and I suspect that it isn't necessary now. However, it certainly was necessary a number of firmware versions ago, because RRF would throw away any commanded extrusion that was less than one microstep. Later firmware versions remember the amount of accumulated extrusion that has been commanded but not done, and do it when it reaches at least a whole microstep.
                                    undefined 1 Reply Last reply 23 Feb 2021, 09:28 Reply Quote 0
                                      deckingman @dc42
                                      @dc42 I documented it in my blog years ago. When I get chance, I'll post a link which includes the maths and spread sheets.
                                      In a nutshell, if one or more filaments are moving forward as single digit percentages of the whole, at 400 steps per mm (Bondtech or Titan 3:1) for short segments, that can result in an extruder move which is in the order of 1 tenth (IIRC) of a micro step.
                                      So even with carry over of fractions, one would have a series of moves with no extrusion, followed by one move with around 5 times too much.
                                      If you use a 5 input hot end and happened to be using single digit percentages of mixing on 4 if those inputs, the overall under/over extrusion amount can be a significant proportion of the whole.
                                      I did a later blog post, accompanied by a video which clearly showed the improvement that 128x micro stepping gives under those conditions (and that was with carry over of the fractions due to rounding).
                                      dc42undefined ? 2 Replies Last reply 23 Feb 2021, 09:50 Reply Quote 0
                                        dc42 administrators @deckingman
                                        Thanks Ian, I'll accept your word that it does make a difference. I am surprised though, because my expectation was that stiction in the extruder mechanism, gearing and Bowden tube would cause the filament to move in small jerks rather than continuously.
                                        undefined 1 Reply Last reply 23 Feb 2021, 11:00 Reply Quote 0
                                          JoergS5
                                          Another thought was, the 6HC and 3HC boards run firmware separately, linked by CAN. A kind of a server farm. Communication through CAN becomes a bottleneck for high step rates. By implementing a common RTC (to sync the boards without the need to communicate it by CAN), it would be possible to use lower interrupt times and higher step rates to dedicated boards, decoupling the timers of the boards. E.g. sending one board compressed instructions how to generate signals for mixed extrusion. 3HC could make the movements and 6HC at high step rates produce the extrusions. Maybe something to think about for RRF4+.
