    oozeBot Elevate
    My Duet controlled machine
    17
    92
    6.4k
      Well done. Looking forward to seeing more.
      • fcwiltundefined
        fcwilt
        Your height map is obscenely good - are you just trying to make the rest of us feel inadequate? 😉
        What I wouldn't give to have a bed that flat.
        And why doesn't your machine try to shake itself apart at those speeds?
        I've never tried speeds like that but I'm pretty sure my printers would disassemble themselves in protest.
        What printing speeds are you aiming for?
        oozeBotundefined 1 Reply Last reply Reply Quote 0
        • oozeBotundefined
          oozeBot @fcwilt
          @fcwilt said in oozeBot ele^gant:
          Thanks! I'd like to think the engineering has something to do with it not rattling itself apart.. 😉 and for the aluminum build plate, depending on our demand, we are considering making custom sizes available for sale to help subsidize the substantial cost of the industrial CNC machine we are purchasing.
          We only print in ABS and have found it does best between 60-80mm/s. And since we are focusing on the printed parts needed for our printers, that's our target. However, we've certainly pushed the prototypes harder.. and I truly believe the release candidates are a much more rigid design, so we shall see here very soon!
          • fcwiltundefined
            fcwilt @oozeBot
            @oozeBot
            Being able to purchase custom sized beds with appropriate mounting holes would be heaven on earth.
            I don't print ABS but I was under the impression that there were newer alternatives that had desirable specs. Yes? No?
            • oozeBotundefined
              oozeBot @fcwilt
              This is something we'd really like to help the community with once we get our design to market..
              As for other filaments, the only alternative we'd currently consider is ASA. There are plenty of other specialty filaments out there that have better characteristics, and we've tried most, but we always end up coming back to ABS as it checks all the boxes for our needs.
              • oozeBotundefined
                oozeBot
                One more quick video of our final motion system, this time isolated by each axis. Z is moving at 250mm/s and X&Y is moving at 400mm/s!
                https://vimeo.com/515982259
                • oozeBotundefined
                  oozeBot
                  A lot has been accomplished since I last posted to this thread. For starters, the codename "ele^gant" has been replaced. We are now branding our machines as the oozeBot Elevate! Our R&D is nearly complete but we have a ton of QA to do before our launch.
                  We will also be launching with an IDEX machine that I'm very excited about. Here is a photo of our 12x12x12" (305x305x305mm) IDEX, the tool heads, and a quick video directly from my workbench.
                  And here is a video of it moving at 200mm/s the first half and 400mm/s the second half. And yeah, it's jumping around on my workbench a bit as it's just sitting on the turntable.
                  https://vimeo.com/549007801
                  Sindariusundefined HebigTundefined 2 Replies Last reply Reply Quote 3
                  • Sindariusundefined
                    Sindarius @oozeBot
                    @oozebot I want one just to make them dance now 😄 that looks quite amazing!
                    • HebigTundefined
                      HebigT @oozeBot
                      @oozebot I really enjoy seeing your posts. Looking forward to the launch!
                      • oozeBotundefined
                        oozeBot
                        We have just wrapped up the design of our electronics control panel and thought it would be of interest. It features a Duet 3 (6HC) mainboard, a Duet breakout board (IDEX only), a 2gb RPi4b, two Omron SSRs for build plate and chamber heaters, and both a 5v and 24v Meanwell power supply. Hidden underneath the Duet 3 mainboard is a 92mm intake fan with air channels venting towards the power supplies and other electronics.
                        o_lampeundefined 1 Reply Last reply Reply Quote 4
                          That's slick!
                          • o_lampeundefined
                            o_lampe @oozeBot
                            @oozebot
                            I'm not comfortable with the PSUs close to the electronics. I also think the tool distribution board belongs closer to the tools.
                            Just my two cent
                            • oozeBotundefined
                              oozeBot
                              We should probably just let this old thread die as almost everything posted was during our prototyping phase and has been replaced and/or updated. However, we'll keep it going with new updates instead of littering up the forum.
                              Here is the near final version of our enclosure which takes some design hints from an 80's arcade machine. Yes, that's real t-molding. It will be sold as a flat pack with optional paint schemes and other extras such as side windows and a few other surprises.
                              Also, here is our new filament storage chamber design. This is the first of several we are building as we expand our farm. Each holds 12 mega-spools (10kg or 22lb) of ABS filament and feed 6 printers. It's controlled by a Raspberry Pi and a bank of relays to maintain ~20% humidity at 40~45c once stabilized.
                              And finally, I spent the previous weekend re-tuning both the machine and our filament profiles. Here is a part printed in ABS with the near-finalized profile:
                              Phaedruxundefined 1 Reply Last reply Reply Quote 4
                                Phaedrux Moderator @oozeBot
                                @oozebot said in oozeBot Elevate:
                                Nonsense. Feel free to start a new thread if you wish.
                                • HebigTundefined HebigT referenced this topic
                                • oozeBotundefined
                                  oozeBot
                                  We had the opportunity to deliver one of our first production machines to Slice Engineering yesterday for their testing! Check out this awesome video they posted this morning of it in action!
                                  https://youtu.be/1EPm8Xacrio
                                  T3P3Tonyundefined 1 Reply Last reply Reply Quote 3
                                    T3P3Tony administrators @oozeBot
                                    @oozebot nice 😄 especially like the thumbnail
                                    oozeBotundefined 1 Reply Last reply Reply Quote 1
                                    • oozeBotundefined
                                      oozeBot @T3P3Tony
                                      @t3p3tony We showcased the Duet3 as much as possible in the control panel!
                                      Sindariusundefined 1 Reply Last reply Reply Quote 2
                                        Sindarius @oozeBot
                                        @oozebot The machine looks awesome. I love the cabinet/enclosure you guys designed for the system.
                                        • oozeBotundefined
                                          oozeBot
                                          Check out this video Slice just posted of one of our machines in action! What they didn't mention is this 200mm tall Spider-man was printed in ABS at 100mm/s (50mm/s external perimeter) in ~8 hours!
                                          https://www.youtube.com/watch?v=gGw1ZOPIXSc
                                          1 Reply Last reply Reply Quote 5
